Privacy Policy |
Please read our Terms
of Service | Signup and
chrisrnuttall
Professor Emeritus
Reged: 12/29/10
Loc: York, England
Saturn Drawing 22nd April 2011
#4539214 - 04/23/11 05:13 PM Attachment (44 downloads)
Hello again
This is a drawing of Saturn made from last nights observations.
I started observing at half past ten British Summer Time, (21:30 UT), the first 40 minutes of my session were spent adjusting the collimation of the main mirror, and then checking the magnification provided by my Eyepiece with my Binoviewer and Optical Corrector. At about twenty past eleven (22:30 UT) I turned my attention to Saturn.
The first thing I did was to compare the views through my Televue 8mm plossl and 2X Televue Barlow, with the view through my Binoviewer setup, this was just to confirm to myself that I am happier using two eyes, and the answer was 'Yes I am', it's way better!
I observed Saturn for around an hour before making my drawing, features noted from top to bottom are as follows;
South Polar Region was dark Grey-Blue
South temperate region was a paler Grey-Blue
South tropical zone was noted as a softly defined slightly paler narrow strip a little way above the rings.
Southern equatorial belt was seen peeking out both above and below the rings, it was a brownish grey.
Equatorial zone was a bright golden colour, and seemed whiter along its centre line.
Northern equatorial belt was a very warm brown, both its edges were slightly darker than the main portion of the belt, these are the NEBn and the NEBs. They were not crisp but had soft edges which blended into the neighbouring areas.
The Northern tropical zone was much paler than the surrounding regions, but to my eye it has more colour that over recent weeks, specifically it is now more of a golden / tan colour rather than the grey it has been. I had timed my observation to make sure the head of the storm would be well presented and I wasn't disappointed, I first noted the dark wedge shaped column to the right hand side of the central meridian, further to the right of this the zone is quite pale. Shortly after this I noticed a small bright oval patch to the left of the dark wedge, upon closer inspection this bright patch was seen to have a pair of diverging tails flowing away from it to the left hand limb of the disc. This is the head of the storm; not so bright as it has been but still going strong.
North temperate region was a similar colour to the NEB but slightly less intense in tone.
North polar region was a darker / greyer version of this same colour.
The A ring was a tan / brown colour.
The B ring was a paler than the A ring, and showed a bright outer edge, and a dark inner edge
The C ring was easy at the ansae, becoming harder to see nearer the disc, it was slightly paler as it crossed Saturn's face.
Cassini was dark but only seen at the ansae.
A dark brown-grey area was noted on the left had ansa, a spoke?
The shadow of the rings on the disc was thinner in the centre that at the ends, making its upper edge almost a perfectly straight line.
The belts were generally much darker than they were at opposition, and were at least as dark as the disc.
I first observed in integrated light, then with a W21 filter which helped me to notice some of the details in the drawing, although upon returning to the view without a filter I found I could still see all these things, some of them more clearly.
The seeing started as AntIII, and improved through the session to AntII. Transparency started moderate to poor, but improved greatly through the session. By one in the morning British Summer Time, a breeze started to blow and the seeing worsened so I packed up.
Edited by chrisrnuttall (04/23/11 05:18 PM)
Reged: 06/13/06
Loc: Illinois
Re: Saturn Drawing 22nd April 2011
[Re: chrisrnuttall]
#4539260 - 04/23/11 05:35 PM
Chris,
Great sketch and excellent report.
Frank
Paul G. Abel
Reged: 01/28/10
Loc: UK
[Re: frank5817]
#4539556 - 04/23/11 08:08 PM
Hi Chris, a most excellent drawing and a complete report!
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
[Re: Paul G. Abel]
#4540257 - 04/24/11 04:09 AM
Just beautiful!
chrisrnuttall
Professor Emeritus
Reged: 12/29/10
Loc: York, England
[Re: Paul G. Abel]
#4540266 - 04/24/11 04:18 AM
thanks Paul and Frank, my report was rather complete (long!) this time wasn't it?
Rutilus
Reged: 12/17/10
[Re: chrisrnuttall]
#4540394 - 04/24/11 07:09 AM
Very nicely done. I like the grey-blue color tone in the south, and the slightly darker edges to the NEB, both features that I observed on my last outing.
CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
[Re: Rutilus]
#4542333 - 04/25/11 12:57 AM
Chris,
An outstanding observation and report on Saturn and the current state of the storm. Your report describes the colors over the globe and rings very nicely and they agree with my own. You have captured the delicate view of the storm very nicely as well. Thank you for sharing it with us all.
Carlos
chrisrnuttall
Professor Emeritus
Reged: 12/29/10
Loc: York, England
[Re: CarlosEH]
#4542473 - 04/25/11 04:37 AM
Thank you both for your kind comments, I was not sure if I had rendered some of these features too subtly, it is hard to get the balance right sometimes. regards
mikesemmler
Reged: 06/01/09
[Re: chrisrnuttall]
#4542655 - 04/25/11 08:22 AM
this is great, a scetch like a photo
Michael
CatalinMT
Reged: 12/12/10
Loc: Turda, Romania
[Re: mikesemmler]
#4542704 - 04/25/11 09:04 AM
Great sketch, love the subtle color tones.
0 registered and 2 anonymous users are browsing this forum.
Moderator: Undermidnight, cildarith
