Bart
Reged: 05/28/06
Loc: Somewhere near Charlottesville...
Longer counterweight bar or more counterweights.
      #4557204 - 05/02/11 01:40 PM
Should I lengthen the counterweight bar or add more counterweights. What are the pros and cons?
Anyone know where I can get reasonably priced counterweights?
Midnight Dan
Reged: 01/23/08
Re: Longer counterweight bar or more counterweights. new [Re: Bart]
      #4557225 - 05/02/11 01:53 PM
The mounts are rated at a certain maximum load - which is usually in addition to the included counterweights. So if you add counterweights, you'll have less of your weight budget left for your payload. So to me, a longer counterweight bar seems like the right way to go.
I'm no expert, but that's my 2 cents.
-Dan
skywolf856
Reged: 01/25/08
Loc: SE Michigan
Re: Longer counterweight bar or more counterweights. new [Re: Midnight Dan]
      #4557815 - 05/02/11 07:47 PM
The total weight of the c'weights used do not in any way add into the payload limits of the mount. For example on the CG5, theoretically you could have a 35 lb. telescope using 35 lbs of counterweights to balance at the maximum payload.
To answer the OP's first question, a longer bar would allow you to use your existing weights more efficiently, but you need to be aware of any mount swing clearances that may come into play with extreme positions.
Mary B
Reged: 05/21/10
Loc: Minnesota
Re: Longer counterweight bar or more counterweights. new [Re: skywolf856]
      #4558300 - 05/03/11 01:11 AM
I would think vibration could creep in with a longer shaft.
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: Longer counterweight bar or more counterweights. new [Re: Mary B]
      #4558603 - 05/03/11 09:04 AM
You're right, Mary; it does. I've tested this with my G11 (when I had it), my CGE and my LXD650. In all tests, I balanced perfectly with one weight at the extreme end of the counterweight shaft and then tested damping time at high power following a light tap on the focuser. I then balanced perfectly using two weights considerably closer to the fulcrum and tested again. With all three mounts, the damping time was noticeably less with two weights closer to the mount head. As far as I'm concerned, that proved the point for me. I'm now stuck with carrying more counterweights.
Bart
Reged: 05/28/06
Re: Longer counterweight bar or more counterweights. new [Re: DaveJ]
      #4558697 - 05/03/11 09:54 AM
Until I decide on which new mount I'll be purchasing, I'm going with the extension. It's cheaper than buying additional weights for a mount that I might not have for much longer.
22 registered and 36 anonymous users are browsing this forum.
