Telescope Specific Forums >> Meade Computerized Telescopes
Jerry238
journeyman
Reged: 04/23/11
Newbie question about Meade Classic LX-200
      #4575192 - 05/11/11 12:13 PM Attachment (47 downloads)
Hi, Just received my new (used) tele and have a couple of very basic questions. It came without a power supply. It says 18 Volt on the electronics box, but from the internet I get that alot of people sell and use 12V adapters with this scope. Is this OK? It is missing the spreader in between the tripod legs. Is seems that this is necessary to actually tighten the the scope to the tripod. Is that accurate. Anybody have one to sell? The tripod has 3 silver colored allen head screws sticking out of top of tripod. Looks wrong to me. I removed them. They are sitting on right side of tripod Base. Does the telescope base sit on these bolt heads? This thing is Huge, and Heavy, (what have I done)? I'm used to my 8". It was sold as parts/not working. I was excited to see if it works at all so I hooked up a generic 12vdc adapter and the hand control lit and says Meade, then Telescope. When I plug declination cable in the hand control lights go out and it doesn't respond. Any ideas? Thanks for any input. Jerry
lambermo
Reged: 07/16/07
Loc: .nl
Re: Newbie question about Meade Classic LX-200 new [Re: Jerry238]
      #4575670 - 05/11/11 04:28 PM
12V will work, it's just slower. I have that when I use a car battery.
The scope does not sit on the bolts, i think the previous owner just stored them there.
Your dec. might have a short somewhere, others can help you further on this
Naturlich
Reged: 10/30/09
Loc: Dukinfield, Cheshire, UK
Re: Newbie question about Meade Classic LX-200 new [Re: lambermo]
      #4575908 - 05/11/11 06:40 PM
Hey Jerry, welcome to CN forums
Lets see:
Voltage: 12v will be fine aslong as you're pusing enough amps (think you need about 2amps), as said it'll just be a little slower, not a bad thing, these are LOUD at full speed.
Spreader: Yes thats typically used to lock the mount to the tripod, and help lock the legs in place for stability. You might get away with it IF the last owner modified the locking screw to the mount so it can tighten up, if not I'd be pretty nervous about using it. (dunno where you can get them though )
Allen Bolts: This is probably how the pervious owner locked the mount to the tripod. If you put the mount on the tripod, there are 3 holes that should line up around the edge, put the bolts up through the bottom on the tripod head and bolt into the bottom of the mount to hold it inplace.
If it wasn't bust before, theres a good chance it is now. You should never plug in/remove the Dec cable with the system powered up. Never plug anything in after turning the power on infact. Still with that said, plug it all together and power up, Have a look at the lights on the handsetkeys, they should all light up. Make sure the scope will move in all directions. Do a fake alignment just to make sure it can actually do one, I have a feeling you could be looking at atleast a dead hand controller given he was selling it as repairs. They are hard to get hold of and not cheap, and a very very very common failure on the Classic.
IF you find you have problems with the electroinics/handset, please do get in touch with George Dudas at this link: http://tech.groups.yahoo.com/group/LX200Autostar/ Have a look there and see whats on offer and see if George has any suggestions for you to check the condtion of your scope, he's a great guy and will help all he can, and if it can't be fixed, he has a nice alternative to trying to repair the now very old and dated Classic control system.
Nat
ps keep us posted with how your getting on!
Jerry238
journeyman
Reged: 04/23/11
Re: Newbie question about Meade Classic LX-200 new [Re: Naturlich]
      #4576997 - 05/12/11 10:06 AM
thanks Nat, very helpful, Jerry
Skywatchr
Reged: 06/03/06
Loc: North-Central Pa.
      #4580944 - 05/14/11 08:46 AM
Hi Jerry. Yes, use at least 16 volts because with that scope, 12 volts is under powering it and can cause damage. The power supply you used is not big enough. That is why it went "lights out".
Those 3 screws are for attaching the wedge to the tripod. A spreader can be made from plywood if you cannot find one. Just put a wanted ad in the S&S forum. I am sure you will find one.
Jeff
Naturlich
Reged: 10/30/09
Re: Newbie question about Meade Classic LX-200 new [Re: Skywatchr]
      #4581889 - 05/14/11 06:22 PM
I doubt very much that 12v is underpowered, since "in the field" it's hard to find a 16-18v supply, most people use a 12v supply or? I'd much more say that the amperage counts. Thats what I always though anyway and seems to make sense.
imjeffp
Aluminum Falcon
Reged: 09/30/03
Loc: Cedar Park, Texas
      #4582237 - 05/14/11 10:09 PM
My Kensington PowerPack has an 18v outlet; it's the only thing I've ever used in the field.
Naturlich
Reged: 10/30/09
Re: Newbie question about Meade Classic LX-200 new [Re: imjeffp]
      #4582268 - 05/14/11 10:26 PM
cool Jeff Just never heard of the LX200 having issues with 12v, it's not an issue ofcourse for my system, but I thought they were always OK with 12 anyway
lambermo
Reged: 07/16/07
Loc: .nl
      #4582691 - 05/15/11 06:04 AM
I can confirm that at least my LX200-classic is fine in the field with a plain 12V car battery
George D
Vendor
Reged: 04/13/10
Loc: So Cal
      #4587753 - 05/17/11 10:15 PM
Well, a "12 volt" battery, that's healthy, probably reads a little over 13 volts most of the time. But it could easily dip below ten volts as it drains in use. And not to contradict Skywatchr but I think higher voltages are the bigger problem than a lower one. Most of the circuitry is regulated to five volts on the board and the power that isn't is what goes to the motors themselves. They can certainly handle lower voltages.
Now, it's possible that the old system had loading issues and deficiencies in the power regulation circuits that made it vulnerable to operation faults at lower than 18 volts. If that is the case, it would make sense. Skywatchr knows these scopes and their circuits like the back of his hand, so I hesitate to question his statements about them... But I did :-)
privateeradventu
Reged: 02/23/08
Loc: moab utah
Re: Newbie question about Meade Classic LX-200 new [Re: George D]
      #4602532 - 05/25/11 03:25 PM
I am very interested in this also, as i have an lx200 that i got recently and the guy ripped me off for thr 18v converter but i have been using my 12v unit and have wondered if it will be ok or not, so i would sure like to hear more on this one!!
George D
Vendor
Reged: 04/13/10
Loc: So Cal
Re: Newbie question about Meade Classic LX-200 new [Re: privateeradventu]
      #4602622 - 05/25/11 04:06 PM
As I see it, there are two potential points of concern, regarding the use of a lower voltage power supply. The first is, do I have enough current to run the electronics at a voltage that is lower than the 18 volt unit supplies, and second, am I going to meet Meades perfomance specs for the unit.
I can certainly imagine that, in order to truthfully publish a slew speed specification for their unit, Meade might have had to up the input power to get the motors to go faster. That might be one reason that some LX200 Classics came with 18VDC input specs.
There may be other possibilities here as well. The on-board circuits appear to be regulated to a five volt level. That means an input voltage of less than say seven volts, may become a problem for the reliable operation of the unit.
Has Meade ever posted any warning about using battery power or operating the telescope at lower voltages than 18 VDC? I don't think so.
Most of the catastrophic failures I have heard about, deal with tantalum capacitors literally burning up and catching on fire. That is often attributed to the fact that the capacitors on most of the Meade circuit boards are rated for a 25 VDC maximum. I have measured voltages from the UNREGULATED Meade 18 VDC supply, as high as 28 VDC! So it's my opinion that it's the higher voltages that present the greatest threat of damage and not the lower ones.
Am I missing something?
"Anyone?...Anyone?.. Bueller?... Bueller?"
privateeradventu
Reged: 02/23/08
Loc: moab utah
      #4608116 - 05/28/11 06:41 PM
Thanx this is great! i use the celestron 12v power tank 17 but have not done much yet with it, would prefer a starizona piggyback unit, but want to check things out first!!
Arctic_Eddie
Reged: 12/30/07
Loc: St. Petersburg, FL
      #4608963 - 05/29/11 10:16 AM
If you really need 18VDC in a portable situation then get a DC/DC switching converter for a laptop. The one for my Acer netbook is rated at 19VDC @ 3.6A. Many others are designed for 18VDC with plenty of current capacity. You will need to check the output plug for the correct size, 5.5mm x 2.5mm x 9mm.
Skywatchr
Reged: 06/03/06
      #4612350 - 05/31/11 06:09 AM
For the LX200 Classic that is labeled 18v, using a 12v PS will cause it to draw more current during high-speed slews, which in turn causes the PS to overload and drop voltage. That puts a strain on the motors and voltage regulators. It worsens as the temperature drops and the grease thickens. It was a workaround for the design that in the beginning was labeled 12v and a lot of warranty repairs were done. However Meade never changed the tantalum capacitors that began failing to at least 36v instead of the 25v "stock" ones.
Me? I use an AC adapter for the older IBM Thinkpads that put out 16v @ 3.36A or 4.5A depending on the model. They even have the correct plug.
Skywatchr
Reged: 06/03/06
      #4612354 - 05/31/11 06:14 AM
HA! Unregulated AC adapters will read high when not under load. A healthy 12v battery will have 13.8 volts at no load also, but can drop to around 12.6 on average under load. These classic LX200 scopes are a bit power hungry.
And you are right about the deficiencies of the old circuits.
Naturlich
Reged: 10/30/09
      #4612639 - 05/31/11 10:21 AM
Thanks for that! My system is 12v so personaly it's not an issue, but good information, I don't wanna be giving out any bad advice so it's good to cover this
George D
Vendor
Reged: 04/13/10
Loc: So Cal
      #4615985 - 06/02/11 01:51 AM
Now WHO can argue with THAT? I'd like to thank Gabby Johnson.... Er; I mean Skywatchr for clearly stating his observations about this product.
Well; I could probably argue a little but I think this time I'll just say.... RUGGER!
Hamsterdam
Reged: 03/23/11
Loc: smack dab in the middle of the...
      #4647282 - 06/19/11 11:02 AM
Gabby Johnson is right. Not only was that authentic frontier gibberish, but 12v batteries dont stay at 12 all night. I bought a powertank for my LX200. It has 2 12v cigarette outlets and 2 120v outlets. The screen reads 13.8 most of the time, better at others. I am in agreement with amps being the killer. Mine has the bonus of also being a jumpstarter, so I can charge it via the car battery, should it weaken....but first time out, it never moved a bar off of full power in 6+ hours, but never mind that *BLEEP*, here comes Mongo!
budman1961
Reged: 02/25/11
Loc: Springfield, MO
Re: Newbie question about Meade Classic LX-200 new [Re: Hamsterdam]
      #4647297 - 06/19/11 11:12 AM
Got to love that movie...Howard Johnsons had only 1 flavor, and Harvey Korman......what a classic! Brook's quote "Always remember affairs of state, will always take precedence over affairs of state" How appropriate today!
0 registered and 3 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
