Privacy Policy |
Please read our Terms
of Service | Signup and
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
PDF files for Degree Circles (patterns)
#4594123 - 05/21/11 11:04 AM
PDF patterns for degree circles
GregBuchholz
Reged: 02/13/12
Loc: Kennewick, WA
Re: PDF files for Degree Circles (patterns)
[Re: csa/montana]
#5268858 - 06/12/12 11:17 PM Attachment (278 downloads)
I had such great success with the setting circle pattern for my 8" Dob, I also created an azimuth version for my 3" Celestron First Scope (see attached). If you are printing out the PDF on 8.5" x 11" paper using the Adobe PDF Reader, you'll need to make sure when you hit the print button to select "None" for "Page Scaling:", otherwise it'll shrink the output size a bit.
GregBuchholz
Reged: 02/13/12
Loc: Kennewick, WA
[Re: GregBuchholz]
#5268863 - 06/12/12 11:42 PM Attachment (256 downloads)
...and here's the source code for the PostScript program I used to generate that setting circle. The programmers in our midst can see how to modify that to generate graduated circles of any diameter. (see the attached, or below)
%%%%%%%%%%%%%%%%%%%% %!PS-Adobe-2.0 %%Title: Setting Circles for 195mm diameter Celestron First Scope %%Creator: Greg Buchholz %%CreationDate: 2012Jun10 %%EndComments
/inch {72 mul} def /mm {inch 25.4 div} def
/long_mark 10 mm def /short_mark 5 mm def /radius 195 mm 2 div def /choose_mark {dup 5 mod 0 eq {long_mark 1} {short_mark 0.5} ifelse setlinewidth} def /Courier findfont 10 scalefont setfont /inner_radius radius 2 mm sub (360) stringwidth pop sub long_mark sub def
%center mark and outer circles 8.5 inch 2 div 11 inch 2 div translate % assume 8.5"x11" paper 0 0 short_mark 4 div 0 360 arc stroke 0 0 radius 0 360 arc stroke 1 300 div inch setlinewidth 0 0 inner_radius 0 360 arc stroke 0 short_mark 2 div neg moveto 0 short_mark rlineto short_mark 2 div neg 0 moveto short_mark 0 rlineto stroke
%degree marks 0 0 moveto 0 1 359 { 1 rotate radius neg 0 moveto choose_mark 0 rlineto dup 10 mod 0 eq {( ) cvs 1 mm -3 rmoveto show} if stroke } for
showpage
10 registered and 17 anonymous users are browsing this forum.
Moderator: Jarad, tecmage
