Pages: << 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | >> (show all)
veil
journeyman
Reged: 04/20/08
Loc: Bathurst Australia
Re: QUANTIX HELP......... new
      #5051002 - 02/02/12 03:37 AM
I just bought one of the quantix cameras and I thought I would share some things I have learned about its use. It has the shutter and machining done by the fine gentleman on this forum.
Firstly it runs fine on windows 7 32bit. It does not work with win 7 64 bit as much as I tried. As my main obs computer with all the automation software was 64 bit, that's kinda annoying. I have run it only in maxim. I did have an error with one of my windows 7 machines with an error on every second exposure. I cannot remember the exact code but it was a camera error in maxim dl. Because it worked fine with my other win 7 machine without issue, I think that it may have been caused by the power supply of one of the computers not having enough juice(350 vs 600w).
I do have use of a an sbig stl6303 that I am planning on doing some comparisons with. Without a lot of testing being done, the quantix noise characteristics are looking very good in comparison.
I am fortunate to have 2 observatories, one remote and one for 'testing' at home. I have the quantix mounted at the home obs on a vixen vc200l, run by ccdap5. Unfortunately we have had 3 weeks of cloudy nights so I haven't got the testing that I have wanted to get done.
Stayed tuned for some comparisons.
Regards
Brett
sullij1
Reged: 11/08/08
Re: QUANTIX HELP......... new [Re: veil]
      #5051854 - 02/02/12 02:40 PM
I wondered who got that camera. Is it the one that appeared on Astromart? I will be looking forward to the comparisons. Thanks.
sullij1
Reged: 11/08/08
Re: QUANTIX HELP......... new [Re: sullij1]
      #5051874 - 02/02/12 02:52 PM
BTW, you may want to blacken the inside of the shutter housing. The metal finish is pretty sparkly. Might cause internal reflection issues.
sullij1
Reged: 11/08/08
      #5051883 - 02/02/12 02:56 PM
Please continue to let us know how well the cam continues to function in Maxim. A lot of users are leaning toward Maxim when finances permit. It would be nice to have an eval on performance befor laying out buy in on Maxim.
veil
journeyman
Reged: 04/20/08
      #5052028 - 02/02/12 04:21 PM
It's very stable in maxim. I am away from home at the moment, but the one trick you need to know is that the camera has to be 'identified' by the roper software first, I just can't remember which part of the software does it!
Also in maxim in advanced I had to click the button 'has shutter'. It would not identify the camera without that button checked.
Also maxim has the feature use filter wheel as shutter.
Yes I bought the one off of Amart. My plan is to mill out the t thread to a sct thread, to stop vignetting on faster scopes. The long term plan for the camera is to have it mounted on my ap130 f6.
Brett
sullij1
Reged: 11/08/08
      #5052285 - 02/02/12 07:08 PM
Thanks for the contribution to the thread.
Ed J
Reged: 05/31/07
Loc: Tujunga, California
      #5065695 - 02/10/12 03:22 PM
To all, "HELP" is what I need, as I've been looking for a camera, decided that 6303 would be good for my use. Searched and found this string. The price is (or was) right. The shutter and lens mounting would be no problem.
A good use for this camera would be attached to: http://edhiker.50webs.com/SSCT_flyer/SSCT_flyer_of_100918.htm
Am I too late to find one?
Ed Johnson
sullij1
Reged: 11/08/08
Re: QUANTIX HELP......... new [Re: Ed J]
      #5065846 - 02/10/12 04:58 PM
Ed Johnson
Too late for the time being unless someone here sees your post and wants to part. The last one that went on sale from a user here didn't last long. They pop up every now and then. Good luck.
AITech
Vendor
Reged: 07/01/11
Re: QUANTIX HELP......... new [Re: poita]
      #5070823 - 02/13/12 04:53 PM
We should have more cameras tested and ready to sell by next week, but we are crazy busy with our normal business. There is a separate box of cameras that look like they have shutters FYI.
Edited by AITech (02/13/12 06:15 PM)
Jim Chung
Vendor - Icodome
Reged: 12/07/05
Loc: Toronto
Re: QUANTIX HELP......... new [Re: AITech]
      #5072347 - 02/14/12 03:52 PM
Has anybody encountered shutter problems? Mine will occasionally misfire and not hold open the shutter for the duration of the exposure.
jsigone
Reged: 12/27/08
Loc: Escondido--> San Diego, CA
Re: QUANTIX HELP......... new [Re: Jim Chung]
      #5072394 - 02/14/12 04:17 PM
is the voltage to the solenoid clean? Maybe spikes in the PS are causing the shutter problems.
gnabgib
Reged: 06/05/05
Loc: Fall River MIlls Ca.
      #5072781 - 02/14/12 09:00 PM
I had the same problem a solved it by reducing the spring tension on my shutter. I bent the leg of the spring that was resting against the solenoid. No issues since this mod.
Being unemployed and still looking for work has left little time for astronomy BUT I have found a few evenings to use the camera. Trying to have some fun when I can!!
Kevin
sullij1
Reged: 11/08/08
      #5072968 - 02/14/12 11:05 PM
I want one!!!!!! Please PM me! I am in your area!
sullij1
Reged: 11/08/08
      #5072981 - 02/14/12 11:17 PM
I had that problem my last 2 outings when it was cold. it happened during my 1 minute framing process. I did a few 1 sec focus shots to warm things up a bit and that seemed to fix the problem. I had one frame that seemed to get stuck and repeated the 1 sec focus shot routine. Haven’t had problems since. It may be temperature related.
I think we are doing stuff to components that was not in their original design plan. Ya know!
sullij1
Reged: 11/08/08
Re: QUANTIX HELP......... new [Re: gnabgib]
      #5072986 - 02/14/12 11:22 PM
Kevin
Kevin,
Good to hear from you. Hope things work out on the job front.
Best,
Joe
sullij1
Reged: 11/08/08
      #5072994 - 02/14/12 11:26 PM
AIT you still rock!!! I sent Ed J a pm letting him know, just in case he is still interested.
AITech
Vendor
Reged: 07/01/11
      #5073636 - 02/15/12 12:15 PM
Put a couple of cameras on eBay. One is a little older with a temp display on the body, the other one fell over and hit a clamp ring and got a small ding. It still tests fine though. Price is lower for that one. These are cameras from the first batch.
We haven't taken control of the new batch yet but should happen any day now when our vender has the time to give us the keys.
Someone was asking about thread pitch and size. We are working to answer that. Will post when we got it figured out. The lens itself is a standard lens that you can get from Thorlabs, but the end was threaded tightly to give a better focus.
poita
Reged: 07/25/11
      #5074861 - 02/16/12 02:26 AM
I tried to buy the dinged one on eBay, but can't as an Australian buyer. I would love to buy it though and have both US and Canadian addresses available for it to be shipped to. Please let me know if there is any way I can purchase it.
Thanks.
sullij1
Reged: 11/08/08
      #5075261 - 02/16/12 10:46 AM
PM AIT, They will probably help you out.
AITech
Vendor
Reged: 07/01/11
Re: QUANTIX HELP......... new [Re: seryddwr]
      #5081980 - 02/20/12 01:07 PM
The threads look like either 40 tpi or 1.5 metric
5 registered and 14 anonymous users are browsing this forum.
Moderator:  BRisley, bilgebay
