macona
Reged: 05/18/11
Loc: Beaverton, OR
Re: QUANTIX HELP.........
[Re: macona]
#4648437 - 06/20/11 02:19 AM
I drew up made the adapter plate for the shutter. It turns out two of the holes in the existing bolt pattern for the lens mount match up with two of the holes on the Ilex shutter. If anyone want the drawing for the adapter plate or the hole layout on the shutter, let me know.
IMG_0531 by macona, on Flickr
Chewed the part out on the cnc mill and counterbored and tapped the needed holes. We are having some stuff heading out to anodizing at work so I will throw the plate in with the rest.
Edited by macona (06/20/11 02:21 AM)
macona
Reged: 05/18/11
Loc: Beaverton, OR
[Re: macona]
#4649840 - 06/20/11 08:10 PM
I got the little DC/DC converter this afternoon. It looks like it is going to work great. I just breadboarded it with a bunch of jumper wires and it triggers it real nice. The converter has an unregulated output. The 48 v line floats about 80v with no load so it charges a capacitor real nice. The pulse opens it and one of the micro switches in the shutter switches the coil to 5 volts to hold. Now I just need a tiny little relay to get it all in the shutter.
gnabgib
Reged: 06/05/05
Loc: Fall River MIlls Ca.
[Re: macona]
#4651134 - 06/21/11 02:26 PM Attachment (31 downloads)
A few picts of my shutter housing.
gnabgib
Reged: 06/05/05
[Re: gnabgib]
#4651141 - 06/21/11 02:29 PM Attachment (27 downloads)
The new parts compared to the "plate" that came with camera.
sullij1
Reged: 11/08/08
[Re: gnabgib]
#4651165 - 06/21/11 02:38 PM
Got a face on and internal shot? Quite a difference!
sullij1
Reged: 11/08/08
[Re: sullij1]
#4651171 - 06/21/11 02:39 PM
Never mind. Thanks!
sullij1
Reged: 11/08/08
[Re: sullij1]
#4651198 - 06/21/11 02:50 PM
Very clean, looks like the way to go.
kw6562
Authoritative Ignoramus
Reged: 06/25/08
Loc: MA
[Re: sullij1]
#4651524 - 06/21/11 05:56 PM
That's definitely the way to go, in my opinion - much cleaner than my hack. Very nice! --Keith
jsigone
Reged: 12/27/08
Loc: Escondido--> San Diego, CA
[Re: kw6562]
#4651537 - 06/21/11 06:08 PM
man this thing will never work with my mak-newt!!
sullij1
Reged: 11/08/08
[Re: jsigone]
#4651583 - 06/21/11 06:37 PM
That's ok, you can borrow my 5 inch.
sullij1
Reged: 11/08/08
[Re: sullij1]
#4651588 - 06/21/11 06:42 PM
Happy 1st day of summer and clear skies to all!
macona
Reged: 05/18/11
Loc: Beaverton, OR
[Re: sullij1]
#4653930 - 06/23/11 01:30 AM
Got my docking station for the thinkpad today. Got the card installed and ready to go.
Almost had my shutter working. Goofed somewhere and shorted out the dc/dc converter. Another is on its way. grrr...
sullij1
Reged: 11/08/08
[Re: macona]
#4654401 - 06/23/11 11:17 AM
Got the German shutter yesterday, hooked it up and sure nuff, worked like a charm.
macona
Reged: 05/18/11
Loc: Beaverton, OR
[Re: sullij1]
#4659036 - 06/26/11 01:47 AM
Got my shutter together today and it works nice. Still have not hooked it to the quantix but there should be no problem. Heres a pic and a video. The wiring in the shutter turned out to be a mess. Oh well.
http://www.youtube.com/watch?v=uL2c0EoPM8c
IMG_0674 by macona, on Flickr
seryddwr
Innocent Bystander
Reged: 02/19/10
Loc: I don't know, you tell me.
[Re: macona]
#4659040 - 06/26/11 01:48 AM
That's pretty cool.
sullij1
Reged: 11/08/08
[Re: macona]
#4659990 - 06/26/11 03:23 PM
Thanks.
I still have this shutter. the vid and pic will prove usefull if I need to go this route.
sullij1
Reged: 11/08/08
[Re: sullij1]
#4660003 - 06/26/11 03:33 PM
Here is how I am now, ready to go. Thanks largely to Kevin and his awsome housing. I am including pic of the camera connector, The shutter and housing (I blacked every thing to avoid internal reflection), and the complete assembly. Working on an old PC to run the cam for now. My son got me the ITX motherboard and a hard drive for fathers day, so I will persue that build when money permits.
 5121 by Sullij1, on Flickr
 5122 by Sullij1, on Flickr
 5123 by Sullij1, on Flickr
It all works fine. Thanks Kevin for yor support!
macona
Reged: 05/18/11
Loc: Beaverton, OR
[Re: sullij1]
#4660669 - 06/26/11 11:10 PM
I decided to make some chips today. I had drawn up the modifications to the old lens flange I needed to make and plugged them into my CAM software and made up some toolpaths for the mill. First I made a fixture plate to mount the lens adapter to. Took a chunk of used 1/2" aluminum and faced it off and drilled and tapped the 4 holes that the plate mounts with. Mounted the adapter down and loaded the g-code and crossed my fingers.
First with a 1/2" variable flute end mill the machine faced off the nose to the new height (Which was calculated with the index of refraction of the quartz window on the camera to be the same as the standard Nikon flange focal distance), then the inner clearance was cut away and the lever clearance was cut.
Next a 3/16" 3 flute was used to cut the remaining profiles needed for the Nikon flange.
Last the 4 mounting holes were spotted and drilled #55 for the 1.6mm screws that hold on the flange.
Looks like everything is where it is supposed to be. I dont have a tap for the flange screws nor do I have long enough screws to mount everything to the camera so that will have to wait.
Here is some cnc porn:
http://www.youtube.com/watch?v=S9VhJkG036I
And a couple pics:
 Quantix lens flange by macona, on Flickr
 Quantix lens flange machined for nikon adapter by macona, on Flickr
 Quantix lens flange with Nikon adapter by macona, on Flickr
kw6562
Reged: 06/25/08
Loc: MA
[Re: macona]
#4660773 - 06/27/11 12:59 AM Attachment (32 downloads)
Wow, nice work!
I'm sorry I haven't been much help lately, been busy with non-astronomy matters, like work...One thing that I did was I bought a new PC to run the camera. But I didn't want to spend a lot so I bought an "off-lease" IBM Lenovo 3GHz Pentium 4 with 2GB of RAM and Windows XP Pro SP3 for about $250. from TigerDirect. I ended up replacing the hard drive with a 1 TB drive and partitioned it to run Ubuntu Linux as well as XP. I found that I had to use an older driver from the Photometrics website in order to connect to the camera but it works great (my old machine wouldn't always connect, but maybe I should have tried an older driver on that one as well). RSImage works fine but MicroManager doesn't (it can read the camera but doesn't operate the shutter). For the moment I'll use RSImage but it will only take 10 exposures in a sequence due to limited memory allocation (and I haven't figured out if there is a way to change that).
When you take a sequence and save it as a tif file the images are saved as individual frames. To break the file into individual 16-bit tifs I wrote a macro for ImageJ (which is freeware and I highly recommend downloading it). The macro:
open(); dir = File.directory Stack.getDimensions(width,height,channels,slices,frames) run("Stack to Images")
for (i=0; i<slices; i++) { name = getTitle(); saveAs("tiff",dir+name); wait(500); close(); }
(Please note here that I am as much of a hack programmer as I am a hack machinist...Pros please don't laugh too hard...)
DSS and Nebulosity work fine with the 12-bit data. I scale the data by 16x in Nebulosity to make it a little easier to use the sliders but it isn't necessary to do that.
This is 25m total of LHaGB of M57 at f/10 in the EdgeHD:
CCD temp. -30C L: 10X30s no binning R(Ha): 2X300s 2X2 bin G,B: 10X30s 2X2 bin
Only slightly cropped for channel misalignment. Some dust rings are visible. Didn't take enough blue data but this was only a test anyway. Full image at Flickr. --Keith
sullij1
Reged: 11/08/08
[Re: kw6562]
#4660784 - 06/27/11 01:14 AM
oooOOOOOooo! to both of you, very nice! And BRAVO to the first well done LHaGB. FOV is killer!
