remuscj
Reged: 04/05/06
Loc: Singapore
Tripod for Paramount MX
      #4633257 - 06/11/11 05:42 AM
Hi!
Just a curious question: for those who ordered the MX, did u choose the stock tripod option? any other alternatives?
jmiele
Patron Saint?
Reged: 12/04/10
Re: Tripod for Paramount MX new [Re: remuscj]
      #4633902 - 06/11/11 12:47 PM
I have several of Rob Millers tripods. I can't say enough about what a pleasure he is to work with. The product is top notch and he uses the same anodizing vendor as Bisque. His tripods are the lightest of even picked up. They are as stable and rated as high in capacity as anything else out there. I have a couple of the Tri36H (h= heavy) here but I think the MX goes on the M version. The L version weights 8 pounds! I think the M is in the low teens.
http://www.catamountsystems.com/contact-us
Shoot him an email and he will get back to you. PM if you want pics, however, I think someone here posted some in a thread also.
Did you get a ship date for your MX?
Joe
frolinmod
Reged: 08/06/10
Loc: Southern California
Re: Tripod for Paramount MX new [Re: jmiele]
      #4634279 - 06/11/11 04:45 PM Attachment (136 downloads)
Some alternatives:
1. Rob Miller TRI36M tripod made specifically for the MX.
2. Astro-physics portable pier (8-inch or 10-inch diameter) with locally fabricated aluminum top plate adapter.
3. Software Bisque's MX tripod which is more than twice as expensive as the above two alternatives.
Here's a picture of Rob Miller's TRI36L, TRI36M and TRI36H tripods:
PascalN
Reged: 04/13/08
Loc: Plano, Texas
Re: Tripod for Paramount MX new [Re: frolinmod]
      #4636307 - 06/12/11 10:43 PM
I chose the TRI36M red anodized tripod from Rob Miller. A beautiful, amazingly stable, and very light tripod. Now - for the MX to arrive.
Pascal
jmiele
Patron Saint?
Reged: 12/04/10
Re: Tripod for Paramount MX new [Re: PascalN]
      #4636373 - 06/12/11 11:47 PM
Did you order the levelers? Also a very handy option for fine adjustment in leveling the tripod. Gives you a 3" round footpad with an additional 1" of adjustment.
Alph
Reged: 11/23/06
Loc: Melmac
      #4636474 - 06/13/11 01:40 AM
Pascal
Does the base rotate 360 degrees?
jmiele
Patron Saint?
Reged: 12/04/10
Re: Tripod for Paramount MX new [Re: Alph]
      #4636476 - 06/13/11 01:41 AM
The base plate in dovetailed on with 6 set screws. It's greased and yes does rotate 360.. Joe
frolinmod
Reged: 08/06/10
      #4636774 - 06/13/11 09:58 AM
When I asked Rob if it was possible to have those six hex head set screws for the rotating base be "knobs" instead, he said no.
jmiele
Patron Saint?
Reged: 12/04/10
      #4636845 - 06/13/11 11:03 AM
Yeah the ME plate hangs over 4 of them on the E and W sides and I don't think there is much clearance in there. The MX plate/mount base are the came so I'm thinking it will be the same as on the H tripod.
See now if you replaced the 4 that are underneath with teflon tipped ends (like those holding a finder scope), they could be snugged up and still allow movement on the greased bearing. The two that protrude on the N and S could be knobs to lock it down after you had it set.
Joe
Edited by jmiele (06/13/11 11:03 AM)
remuscj
Reged: 04/05/06
Loc: Singapore
      #4636934 - 06/13/11 11:59 AM
thanks for the input guys! no, i have not ordered my MX yet, but it would be a member in a list of mount upgrades from my current decade-old G11. The RM tripods certainly look good, and with the rotatable base, i will assume the head can be positioned in such a way that the weight shaft can be between any of the two tripod legs when used at 0 degree latitude? Thanks!
jmiele
Patron Saint?
Reged: 12/04/10
      #4637093 - 06/13/11 01:57 PM
Remus,
"i will assume the head can be positioned in such a way that the weight shaft can be between any of the two tripod legs when used at 0 degree latitude?"
That is correct. Joe
Alph
Reged: 11/23/06
Loc: Melmac
      #4637106 - 06/13/11 02:07 PM
Can it be rotated while doing the polar alignment?
frolinmod
Reged: 08/06/10
      #4637192 - 06/13/11 03:14 PM
It can be rotated at any time by first loosening six Allen head set screws. You loosen the screws with an Allen wrench, rotate the plate, then tighten them back up. The top plate rotates smoothly and easily. The screws are distributed around the circumference. Some can be reached with the short side of the wrench and some require the long side of the wrench. Therefore some can be torqued more than others. Probably not a good idea to loosen the set screws with an unbalanced mount sitting on top of the tripod. So I'd say at least balance the mount first.
Alph
Reged: 11/23/06
Loc: Melmac
      #4637378 - 06/13/11 06:14 PM
Is the SB tripod any better in this regard?
jmiele
Patron Saint?
Reged: 12/04/10
      #4637406 - 06/13/11 06:40 PM
Looks like the top plate is similar. The only differences I see from the CG image on the SB site is the built in levelers. They appear to be long threaded rods. They may produce more adjustment not sure.
Joe
PascalN
Reged: 04/13/08
Loc: Plano, Texas
      #4637565 - 06/13/11 08:35 PM
No. I did not get the levelers. They were not yet available when I ordered mine. Rob was still working out the details. I may get them in the future.
Edited by PascalN (06/13/11 08:43 PM)
jmiele
Patron Saint?
Reged: 12/04/10
      #4637600 - 06/13/11 09:09 PM
You still have adjustment in the legs anyway. That's where you get the most adjustment. Up to 4" I believe. The levelers give you 1" of fine adjustment.
Thing that most impressed me was the first time I picked it up. These things weigh next to nothing.. Joe
M13 Observer
Reged: 12/09/06
      #4637950 - 06/14/11 01:06 AM Attachment (50 downloads)
They are $200 a set of three and worth every penny. Gorgeous works of art which work.
PascalN
Reged: 04/13/08
Loc: Plano, Texas
Re: Tripod for Paramount MX new [Re: M13 Observer]
      #4638199 - 06/14/11 08:38 AM
Oh boy! Now I have to get those levelers.
Thanks for posting the picture and comment.
Pascal
Nick Black
journeyman
Reged: 05/05/08
Loc: Amarillo, TX
      #4638774 - 06/14/11 02:36 PM
Joe,
Which tripod are you referring to? I picked up a Tri36M from Rob, which is what he recommends for the MX, and the length of the legs is not adjustable.
Nick
28 registered and 40 anonymous users are browsing this forum.
