Pages: << 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | >> (show all)
TG
Reged: 11/02/06
Loc: Latitude 47
Re: Meade's new LX800... new [Re: Stew57]
      #5066555 - 02/11/12 01:05 AM
The munt looks good, the specs are good, and I am sure it will be a capable mount in the right hands. The fly in the ointment is service and parts. I for one do not want to send the entire mount back because of a bad bearing, motor, controler etc. Losmandy, AP and others will sell you what you need and will send out parts under warranty when nedded. That is worth a lot in my book.
I recently had Scott Losmandy re-machine my Losmandy-made pier extension that wasn't even being used for a Losmandy mount (but had trouble fitting) at no charge. Just because of this experience, I'd be inclined toward Losmandy mounts before any others were I in the market.
Tanveer.
budman1961
Reged: 02/25/11
Loc: Springfield, MO
Re: Meade's new LX800... new [Re: budman1961]
      #5066586 - 02/11/12 01:34 AM
Looks like Jack Newton is one of their beta testers:
https://www.facebook.com/meadetelescopes#!/meadetelescopes
Ohhh yeah, I forgot...I got mine a while back.....forgot to tell you all!
What......no laughs?????
DaveJ
Reged: 01/07/05
Loc: NE Ohio
      #5066735 - 02/11/12 07:46 AM
So...what version of Photoshop are you using!?
Awesomelenny
Reged: 05/02/04
Loc: Long: 81.42 W Lat: 41.21 N
      #5066770 - 02/11/12 08:32 AM
Too funny!!!
Reged: 07/06/07
      #5066771 - 02/11/12 08:33 AM
budman1961
Reged: 02/25/11
Re: Meade's new LX800... new [Re: rmollise]
      #5066920 - 02/11/12 10:31 AM
I thought this thread needed a little levity.......
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
      #5067020 - 02/11/12 11:24 AM
We now return to our usual pointless speculation.
Micheal
Reged: 02/28/10
Loc: Corona, CA
      #5067060 - 02/11/12 11:38 AM
The parts on the LX800 are modular. No need to ship the whole thing back.
PatHolland
Reged: 10/11/09
Loc: Clever, Missouri
      #5068191 - 02/12/12 01:41 AM
I thought it was funny Andy...
P.S. Congrats on being the beta tester for Photoshop CS6
mmalik
Reged: 01/13/12
Loc: USA
Re: Meade's new LX800... new [Re: herrointment]
      #5068319 - 02/12/12 06:25 AM
Enough has already been speculated about resemblance between LX800 and Mach1GTO; following are some specs to look at which would make one think why they may ‘actually’ be the same mounts (in terms of raw materials I mean), difference only being certain beefier components (motors etc.) of LX800 that may account for bigger weight carrying capacity. So I guess it is a good thing…
Functional Similarities:
..........................................LX800.................................Mach1GTO
Main Gear-RA/Dec:................5.8”/225 tooth aluminum..........5.9”/225 tooth aluminum
Worm Gear-RA/Dec:...............0.68” brass..........................0.70” brass
Non-functional Differences:
............................................LX800..............................Mach1GTO
Mount body weight:.................55 lbs.............................32.1 lbs.
Mount capacity:.......................90 lbs.............................45 lbs.
Counterweight shaft diameter:.......1.75".............................1.125"
Moderator's note: Please provide a link to images that arte not your personal property.
Adding your initials to stock manufacturers images does not count. Thanks
Edited by rick rian (02/15/12 08:26 PM)
skybsd
Reged: 02/01/08
Re: Meade's new LX800... new [Re: mmalik]
      #5068336 - 02/12/12 06:52 AM
Enough has already been speculated about resemblance between LX800 and Mach1GTO; ...
Ummm.., of the resemblance, there IS no speculation - merely observation..,
If applicable, you may want to peruse the Yahoo AP-GT user groups for AP's own reaction and (rather) informed opinions on the matter..,
skybsd
barasits
Reged: 06/12/11
Loc: Chicago
      #5068653 - 02/12/12 11:19 AM
Just so. Now, how many LX800s can dance on the head of a pin?
Geoff
Reged: 07/06/07
Re: Meade's new LX800... new [Re: skybsd]
      #5068885 - 02/12/12 01:30 PM
And I say the Mach 1 bears more than passing resemblance to the Criterion RV-6 GEM. Coincidence or CONSPIRACY?! Hmmm?
alrosm
Reged: 07/27/10
      #5069939 - 02/13/12 03:27 AM
We know now, that people at meade like AP designs a lot
ion
Reged: 04/26/08
Loc: Bortle Scale 2
Re: Meade's new LX800... new [Re: alrosm]
      #5072337 - 02/14/12 03:49 PM
Why is the counterweight shaft threaded? It's hard to imagine a more tedious method of installing (and uninstalling) counterweights than having to screw them on to a long bolt. What's the point?
Jared
Reged: 10/11/05
Re: Meade's new LX800... new [Re: ion]
      #5072525 - 02/14/12 06:08 PM
I can only assume it's a "safety measure." You can't accidentally drop a counterweight on your toe by not tightening the set screw and leaving off the toe saver if your counterweights are threaded. Never mind the fact that you are probably more likely to drop the counterweight on your toe while threading it onto the shaft in the first place...
Could by wrong. Perhaps someone else has an idea why one might set it up this way...
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: Meade's new LX800... new [Re: Jared]
      #5072626 - 02/14/12 07:19 PM
I like the fact that the weight can't accidentally be dropped while adjusting its position. I also like the ease and precision of adjusting the weights with one hand.
Alph
Reged: 11/23/06
Loc: Melmac
      #5072697 - 02/14/12 08:10 PM
For easy and precision balancing.
Oh forgot to mention. The CW has a button. When you push it in then you can slide the CW.
Edited by Alph (02/14/12 08:12 PM)
ion
Reged: 04/26/08
Loc: Bortle Scale 2
Re: Meade's new LX800... new [Re: Alph]
      #5074202 - 02/15/12 06:00 PM
Thanks for explaining. I read the marketing brochure too but am not really buying it. In my experience counterweights don't fly off the shaft often enough to require screwing them on to a long bolt over 20 times to mount them (according to the stock photo) and another 20 spins to take off--every single setup. Also one spends so little time balancing that the extended setup and teardown don't seem worth any ease and precision gained in an already simple task.
My two cents...
yweln
Reged: 08/05/11
      #5074212 - 02/15/12 06:04 PM
There's a quick release button on the counterweights that allow you to slide them up and down the shafts quickly. The threading allows for small adjustments with one hand. There's already a safety cap that goes on the end of the shaft, so the "dropping it on your toe" issue is already addressed.
Personally I like the threaded shaft approach. Allows for very small adjustments without a lot of effort.
Edit: It's the same quick release button on the counterweights that Meade already uses with the Maxmount.
Edited by yweln (02/15/12 06:06 PM)
15 registered and 32 anonymous users are browsing this forum.
Moderator:  cbwerner, Starman27, kkokkolis
