MessiToM
Reged: 12/21/09
Loc: Huntingdon PA
CG3 R.A drive on a CG5...SUCCESS
      #4826850 - 09/25/11 01:11 PM
Hello, figured Id post if anyone in the future wanted to know if this cheap mod would work.
this variable speed RA drive was only $30 and will do all the "tracking" i need for high power planetary web-camming.
Was pretty simple. I left the bracket on that came with it, made a small 90* bracket to connect it to an existing hole on my cg5.
was that simple
clear skies,
Don Trinko
Reged: 07/05/09
Loc: Ohio
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: MessiToM]
      #4827042 - 09/25/11 03:10 PM
where did you buy the drive? Thanks; Don T.
SteveNH
Reged: 07/10/11
Loc: Millbrae, CA
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: Don Trinko]
      #4827058 - 09/25/11 03:18 PM
That's also what I'd like to know - I just bought one that looked like yours for $20, but without the speed control! What model # is it?
Steve
AlBoning
Reged: 03/06/11
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: SteveNH]
      #4827107 - 09/25/11 03:48 PM
Kudos for a remarkably clean installation. I ordered one of those motors from telescopes.com last year along with the purchase of a CG3 mounted beginner newt.
David B in NM
Reged: 09/05/10
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: AlBoning]
      #4827195 - 09/25/11 04:41 PM
At the present time the motor is backordered at Astronomics:
Variable Speed Motor
David B in NM
Brian Risley
Reged: 09/04/06
Loc: SW Florida
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: David B in NM]
      #4827264 - 09/25/11 05:12 PM
I see this has part #93514. What is the difference between it and the 93511? It has variable speed too.
Brian
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
      #4827274 - 09/25/11 05:17 PM
I bought one several years ago from a vendor on eBay. It also has a variable speed dial. Mine has a further refinement: the word "SLOW" and a counterclockwise arrow above the speed dial. I put the drive on my CG-3 clone.
David B in NM
Reged: 09/05/10
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: Brian Risley]
      #4827309 - 09/25/11 05:33 PM
Brian
They are most likely the same motors.
The model numbers are different because they adapt to different Celestron "package" mounts.
I can only guess, the difference is, the mounting hardware you'd receive in the packages.
David B in NM
MessiToM
Reged: 12/21/09
Loc: Huntingdon PA
      #4827580 - 09/25/11 08:20 PM
4 left!
http://www.amazon.com/gp/aw/d/B002UEE136/ref=mp_s_a_1?qid=1316996140&sr=8-1
And thanks "David B" for the idea
David B in NM
Reged: 09/05/10
      #4827595 - 09/25/11 08:30 PM
MessiTom,
No problem on the idea.
As you said it is an easy mod that provides one with cheap motorized (variable speed) tracking so you no longer have to manually turn the knob on the old CG-5 mounts.
Now you can enjoy your planetary imaging more.
I am very pleased I could assist you.
Clear Skies and have fun imaging!
David B in NM
Adam Taylor
insignificant bystander
Reged: 11/11/10
Loc: Arizona
      #4827952 - 09/26/11 01:29 AM
Doesn't the CG-5 have a 1:144 ratio RA gear, versus a 1:130 on the CG-2/CG-3? Does it track correctly? Do you have to adjust the speed control all the way to one side?
MessiToM
Reged: 12/21/09
Loc: Huntingdon PA
Re: CG3 R.A drive on a CG5...SUCCESS new [Re: Adam Taylor]
      #4828314 - 09/26/11 10:14 AM
Honestly iam still waiting for a clear night ^
Adam Taylor
Reged: 11/11/10
Loc: Arizona
      #4828426 - 09/26/11 11:26 AM
I'm interested to know how it works out for you. Looks like a simple mod, and clean install. Good job!
Brian Risley
Reged: 09/04/06
Loc: SW Florida
      #4829401 - 09/26/11 08:56 PM
The variable control allows you to adjust the speed, so you can adjust for the different gear ratios. (You can even use the variable speed /hemisphere control to fine control things at high powers.)
I have put these on a variety of EQ-2 style mounts.
Brian
MessiToM
Reged: 12/21/09
Loc: Huntingdon PA
      #4829666 - 09/26/11 11:36 PM
Well iam standing behind my cg5 and chinese 6" achro with my webcam taking nice long avis!
This motor has plenty of speed. Iam only about a quarter turn up from the lowest setting.
AWSOME how sweet it is
SteveNH
Reged: 07/10/11
Loc: Millbrae, CA
      #4829762 - 09/27/11 01:07 AM
Hi Adam, just as a side note, I've counted my CG-3 to have 138 teeth, so it does seem close to the 144 on the CG-5, especially with all that reported speed control - now I've got one on order for my CG-3!
Steve
Brian Risley
Reged: 09/04/06
Loc: SW Florida
      #4831362 - 09/27/11 11:19 PM
Yes, they are amazing little motors. No real clutch, just the thumbscrew (which can get into positions that are hard to get to) but they track well once adjusted. In testing on some of my eq-2's I could keep planets in for well over an hour (had dec drift, but that's just alignment). I am considering trying to mod one to allow remote control on direction/speed to allow one to use it as a drive corrector/fine adjust so I don't have to deal with the thumbscrews. I found several a while back at $10 shipped!
Brian
SteveNH
Reged: 07/10/11
Loc: Millbrae, CA
      #4838133 - 10/01/11 07:33 PM
Brian
If you ever end up doing this modification in the future, please be sure to post it! I would be very interested to know where to tap in ...
Steve
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #4839415 - 10/02/11 02:09 PM
I'm not surprised it has the speed to deal with the CG-5. It must have a pretty wide range to deal with both the EQ-1 and the EQ-2. The angled brackets on these vary depending on the mount they are intended for.
The heart of the circuit is a Hitachi HA17358 Dual Operational Amplifier. From the Datasheet:
"Description: HA17904 and HA17358 are dual operational amplifiers which, provide internal phase compensation and high gain, and mono power source operation is possible. It can be widely applied to control equipment and to general use.
Features: Wide range of operating supply voltage and mono power source operation is possible. Wide range of common mode input voltage possible to operate with an input around 0V, and output around 0V is available. Frequency characteristics and input bias currrent are temperature compensated.
For a discussion of the use of dual op amps for motor speed control see: http://www.ti.com/lit/an/sboa043/sboa043.pdf
Judah
Reged: 10/01/12
      #5459831 - 10/07/12 08:37 PM
MessiTom
I would greatly appreciate a small tutorial or even a parts list for this mod - I'm thinking if giving it a go since the CG-5 single axis motor is $70. Have you tried this for astrophotography or what are your thoughts on it working or not?
Many thanks!
11 registered and 35 anonymous users are browsing this forum.
