john-AZ
Reged: 11/06/03
Royce 8" f/6 Ultimate Newtonian Performance new
      #4829439 - 09/26/11 09:32 PM
I wanted to write a short note on my recent experiences with the Royce Ultimate Newtonian I bought several months ago...
Living in Florida, I have been enjoying exceptional seeing recently for Jupiter and lunar observing. I have also enjoyed being friends with some very high caliber lunar and planetary observers (two are nationally known names many of you would recognize).
Without getting into a lengthy review, I will simply say I, and my observing buddies, have been very impressed with the 8" f/6 Royce (conical mirror, curved spider, innovative secondary support, etc.). My scope was an early prototype that was made with a Blacklight phenolic tube.
On one evening, we had six high resolution optics in the field: An eight inch f/9 newtonian, a 10" f/9 newtonian, my 8" f/6 newtonian, a 4" Nikon refractor, a six inch Intes f/12 MCT, and a custom figured high resolution SCT. When Jupiter rose near the zenith, the seeing became excellent and the instruments were all pointed at Jupiter. The Royce Ultimate Newtonian produced as fine (in some cases better) image as the other optimized high resolution instruments. Color, contrast, and resolution were top notch.
I like the Blacklight tube a lot. It does not have a rotating focuser like the new aluminum version, but it is super light, and has excellent thermal properties. Heck, the whole 8" telescope is only 15 Lbs! It definitely wins the award for most lightweight, easy to setup and use planetary scope I have owned. And being light weight, it is really held solid on my CGEM mount.
Although my scope came with a fan, it isn't needed. There just isn't much mass to cool, and the conical mirror ventilates well. I have tried the scope with the fan on, and off. Back and forth...the fan just is not needed (in Florida). In fact, I seal the back end of the tube to prevent currents from entering the back of the telescope. I have not had any problems with tube currents and cool down time is maybe 10 min.
I have owned and enjoyed many fine instruments including high end retractors, maksutovs, and other fine newtonians. The Royce telescope is among the best I have owned and observed with. I have seen first hand, and agree with, the comments in the formal Royce 8" f/6 review found in the CN reviews section.
Highly Recommended,
John
AlBoning
Reged: 03/06/11
Re: Royce 8" f/6 Ultimate Newtonian Performance new [Re: john-AZ]
      #4829583 - 09/26/11 10:39 PM
Thanks for your comments. That scope is tied with a similar one from Parallax Instruments as my first purchase as soon as the mortgage is paid off. Five years and counting ...
Daniel Mounsey
Vendor (Woodland Hills)
Reged: 06/12/02
      #4829667 - 09/26/11 11:37 PM
Glad you finally shared this John. I like to hear hands on experiences. I know we had a lot of discussions on this telescope and to see you get out with it and put it to the test is the best reference one could ask for.
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
Re: Royce 8" f/6 Ultimate Newtonian Performance [Re: john-AZ]
      #4829890 - 09/27/11 05:50 AM
...in Florida, as you quite rightly pointed out. In Grandpré in France n a night in which the temperature dropped from 20°C to 1°C, you might have come to a different conclusion.
Life isn't fair. We have to fight the latitude, bad seeing, scope thermals,...and you're getting a free lunch (well, apart from the odd hurricane, that is).
dvb
different Syndrome.
Reged: 06/18/05
Loc: Vancouver, Canada
Re: Royce 8" f/6 Ultimate Newtonian Performance new [Re: sixela]
      #4830168 - 09/27/11 10:34 AM
Thanks very much for the report.
I've been very interested in the 8" F/6 Royce.
My own scope is built around 10" f/4.5 Royce conical, which has performed wonderfully.
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
Re: Royce 8" f/6 Ultimate Newtonian Performance new [Re: dvb]
      #4831075 - 09/27/11 07:33 PM
I am on my 4th Royce mirror, two of which have been conical. All wonderful performers. In Pickering 5 conditions last Tuesday the 12.5 had no trouble resolving the the four large moons of Jupiter as disks. I can only imagine what it could do in Florida conditions.
john-AZ
Reged: 11/06/03
      #4831095 - 09/27/11 07:43 PM
You might be right. As a generalization, I am finding the conical mirror shape, and reduced mass, are functionally important. I did have the telescope in New York for two months in the spring and would run the fan for a few min. during initial cooldown, and then seal the back of the tube. From that point, I felt the mirror tracked the air temperature very well.
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #4831185 - 09/27/11 08:47 PM
I have experimented with fans on my two conicals and have found that I can do without them, despite the large temperature drops typical of the high desert. I suspect that the thinner outer section of the conical acts as a radiator to pull heat from the center and rapidly disperse it.
The dominant issue I have in my local area is atmospheric (fast) seeing, so there is the possibility it could be masking thermal issues on the scope.
5 registered and 26 anonymous users are browsing this forum.
