twhite
Reged: 01/28/06
Loc: Broken Arrow, Oklahoma, USA
Denkmeier I accessories question... I've forgotten
      #4897977 - 11/04/11 08:17 PM
I have a Denk I system customized with Borg helical focusers that I don't use very much... need to correct that. However, I've forgotten what the three 'accessory' lenses I have do... or at least I think I have.
Oh, and this is all 1.25", by the way. I may buy a 2" nosepiece and accessories at some point, but not yet.
One is not marked that appears to be a straight telenegative amplifier.
One is marked "S" and appears very similar to the unmarked one.
One is marked "Refractor OCS" and is very different. I believe this is simply a relay lens like most OCSs -- provides slight magnication but mostly allows the binoviewer to be used in non-shortened optical systems at something approaching prime power (1.2x, if I read it right).
I tried doing a little searching on Denkmeier's site but found nothing specific to these products. Of course, they're old enough now that they probably no longer even sell them.
As a completely off-the-wall side question -- has anyone ever tried to use an old thread-on Rich Field Adapter like the Vixen-made f/5 to increase the FOV? I have one that threads on to the Denk but I've never tried it.
I'm going to try to get back to doing more binoviewing -- my big scope isn't set up for it currently, but one of my planned projects for the coming year is a complete rebuild of the structure that will allow binoviewing, for one thing (the other being an adaptation for StellarCAT).
Hate to sound like such a n00b but it's been years since I've used them and I just flat forgot what they all do...
Tony
faackanders2
Reged: 03/28/11
Re: Denkmeier I accessories question... I've forgotten new [Re: twhite]
      #4898102 - 11/04/11 10:12 PM
Obviously the refractor OCS works for refractors (only) and powers should be listed on the denk site.
I have the "S" OCS and it works with my solar max 40 in front of the diagonal, and it also works with a 1.25" (~3" LONG) tube extension FOR MY 1.25" fOCUSER IN my 10" Dobsonian reflector (at 1.4x, 2.0x, and 2.5x with my power switches)
rick rianAdministrator
Seeker of Truth(s)
Reged: 08/03/04
Loc: Upper Mid West
Re: Denkmeier I accessories question... I've forgotten new [Re: faackanders2]
      #4898173 - 11/04/11 11:03 PM
Hi Tony,
See the Bigeasy manual. The Denk standard, Bigeasy, and Denk I are essentially the same unit. I think you'll find the info you need if you scroll through the manual.
I hope this helps.
twhite
Reged: 01/28/06
Re: Denkmeier I accessories question... I've forgotten new [Re: rick rian]
      #4898243 - 11/05/11 12:03 AM
Rick,
Thanks; I looked at a few things but not the Big Easy, I guess.
I may be calling Denkmeier on Monday as I think I'm needing some parts that I don't have, like the spacer tube.
EdZ
Professor EdZ
Reged: 02/15/02
      #4902086 - 11/07/11 06:44 AM
I answered this 3-4 years ago and found it. Copied it here.
This relates to all the 1.25" parts:
put the parts together in this order
body + 1st part that screws into body + next + next
It is important to differentiate between the OCS (the OCS has the Denkmeier emblem embossed on it) and the optical nose (has the 0 embossed on it).
SCT
The body + optical nose (1.25" part 0) is a "reducer" for use in the SCT. States 0.66x. Mine comes out to be 0.8x.
The body + hollow nose (hollow sleeve) is approx 1.25x in an SCT. States 1.15x. Mine comes out to 1.27x.
The body + hollow nose + OCS (Denk emblem) is approx 2.25x in an SCT.
NEWTONIAN
The body + optical nose + spacer + OCS is approx 1.4x in an Newt.
The Hollow nose + spacer + OCS is approx 2.5x in a Newt.
REFRACTOR
If using a 1.25" diagonal in your refractor then these combinations apply:
(Denk body + optical nose "O") inserted into (1.25" diagonal + OCS) = stated 1.4x
(Denk body + hollow nose) inserted into (1.25" diagonal + OCS) = stated 2.5x
The following relates to the 2" T and the 1.25" OCS in the 2" diagonal
screwed into the front of the diagonal
Generally these arrangements are for a refractor.
with the OCS screwed onto the T and OCS facing INSIDE the diag when the T is attached to the diagonal, = Lower power option
with the OCS screwed onto the T and OCS facing OUTSIDE the diag when the T is attached to the diagonal, = Higher power option
When using the T in a 2" diagonal, the BV would then be used with the hollow nose (body + hollow nose) inserted behind "into" the diagonal just like eyepieces. In a 2" diagonal all the power changes are out in front of the diagonal.
There is no part S or part SR with the Denk Standard or the Denk Big Easy, only the parts I listed above. There is a part S, but I'd have to refer you to the instructions for its proper use. I think part S is used in shortened refractors in lieu of the OCS. But you'd still need to see its proper location in the instruction sheets.
edz
twhite
Reged: 01/28/06
Re: Denkmeier I accessories question... I've forgotten new [Re: EdZ]
      #4905257 - 11/08/11 08:58 PM
Ed -- that's perfect. Thanks very much!
faackanders2
Reged: 03/28/11
      #4905558 - 11/09/11 12:17 AM
Part S is for Solarmax and you put it in front of the diagonal to be able to get binoviewer to focus, without any other extension. This S part can also be used in a 1.25" newtonian focuser with a 3" extension between it and the binoviewer.
1 registered and 2 anonymous users are browsing this forum.
Moderator:  Geo557, panhard
