Should the text setup and be removed from Rule #10 in order to remove the requirement that a contestant must have personally set up the gear used in the contest?
Rule #10 currently reads:
Entries must represent the work of a single individual. You must setup and operate all equipment yourself, capture all exposures (or perform any sketching) yourself and process the resulting entry yourself.
Should the setup requirement be removed? Users may choose only one (57 total votes)
