Dennis_S253
Reged: 11/22/11
Loc: West Central Florida
eta cas question
      #4986270 - 12/26/11 11:18 PM
Seperation is listed at 12". When using stellarium I set up a test scope, a ETX 125. Using a 3.2 MM Ep which give close to 600X mag I can't see the split. Does stellarium not show double's correctly when using ocular view?
rookie
Good Night Nurse
Reged: 01/14/06
Loc: St. Petersburg, FL
Re: eta cas question new [Re: Dennis_S253]
      #4986280 - 12/26/11 11:28 PM
It's possible that your high power setting has made the field of view is too small to see both components. Try reducing the power and see what happens.
Dennis_S253
Reged: 11/22/11
Re: eta cas question new [Re: rookie]
      #4986686 - 12/27/11 09:59 AM
At the close to 600x mag I can see a peanut shape.
Upon doing some research... Simbad says eta cas is a Spectroscopic binary. Then doing some research on Spectroscopic binary, It says the 2 stars are so close that you can't split them with a telescope. There seems to be some confusion here.
Ziggy943
Reged: 08/11/06
Loc: Utah
      #4986872 - 12/27/11 12:19 PM
Eta Cass is an easy visual binary.
At 600x you're way over magnifying. It would still easily fit into the FOV. Try it at about 100x and look for the deep magenta companion. The companion is a dwarf M0 star.
You should not be having any trouble seeing this with a 5". Just be sure you're on the right star.
blb
Reged: 11/25/05
Loc: Piedmont NC
      #4986916 - 12/27/11 12:53 PM
What is the confusion? You can not see a spectroscopic binary without a spectroscope and the training to read the information. This is an easy visual pair at 12 seconds seperation. The fact that one of the stars is a spectroscopic binary and isn't visible with a telescope isn't a problem for me.
Dennis_S253
Reged: 11/22/11
Re: eta cas question new [Re: blb]
      #4987006 - 12/27/11 01:46 PM
So, if it isn't visible with a telescope, how can you split it? There must be another member of this system people are looking at and spliting.
blb
Reged: 11/25/05
Loc: Piedmont NC
      #4987041 - 12/27/11 02:12 PM
YES! that is correct. They are NOT looking at the spectroscopic pair, they can't. They are looking at the visual pair. The stat's in Sissy Haas's book, Double Stars for Small Telescopes has it listed this way;
Magnitude: A=3.5, B=7.4
Seperation = 13.0"
Position Angle = 319 degrees
Year of Obs = 2003
These two stars can be seen with a small telescope as a showcase pair that are a striking yellow and ruddy-purple or garnet color. Just look at this pair with your telescope and not a computer screen and you will see.
You failed to read beyond the first sentance in your quote. You did not read that I said:
...This is an easy visual pair at 12 seconds seperation. The fact that one of the stars is a spectroscopic binary and isn't visible with a telescope isn't a problem for me.
archer1960
Reged: 07/26/11
      #4987154 - 12/27/11 03:38 PM
Kind of like Rigel. It's easy to split A from B. Many people don't know that B is itself a spectoscopic binary, which cannot be split visually (AFAIK).
piyro
Reged: 05/14/10
Loc: Canary Islands, Spain
      #4987227 - 12/27/11 04:39 PM
[...]The stat's in Sissy Haas's book, Double Stars for Small Telescopes has it listed this way;
Seperation = 13.0"
Year of Obs = 2003
These two stars can be seen with a small telescope as a showcase pair that are a striking yellow and ruddy-purple or garnet color. [...]
Eta Cas is easy with my trash 60 mm f/12 refractor even an 35x. Not so easy with my 76 mm f/4 Celestron Firstscope.
Pedro.
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
Re: eta cas question new [Re: archer1960]
      #4987298 - 12/27/11 05:40 PM
It was the A component of Eta that was once thought to a spectroscopic binary, although after more detailed study (C.L. Morbey and R.F. Griffin, 1986), there is considerable doubt now that either star is one. Visually, they are quite an easy pair that are visible at 59x and look great at around 100x. The primary is an off-white color, while the companion is a dim reddish-orange hue (at least to my eyes using my 9.25 inch SCT) . Clear skies to you.
JIMZ7
Reged: 10/22/05
Loc: S.E.Michigan near DTW
      #4987368 - 12/27/11 06:35 PM
Are we talking about the same star? In a 4" f/9.8 refractor it splits easy at 42x but nicer at higher powers.
Dennis_S253
Reged: 11/22/11
Re: eta cas question new [Re: David Knisely]
      #4987373 - 12/27/11 06:39 PM
Thanks for the info guys. Last night I was out and thought I seen it at 80x and 103x. I was just confused about the way stellarium shows it not spliting.
David Knisely
Reged: 04/19/04
      #4987939 - 12/28/11 03:02 AM
Stellarium is basically "eye candy", and without a lot of modification often may not be all that useful as a rigorous tool for the die-hard amateur. Even Megastar doesn't show the companion to Eta-A, although when I switch the double star markers on, it does indicate that Eta is indeed a double, and when clicked on will show the WDS data on the double. Clear skies to you.
RLTYSModerator
Reged: 12/18/04
Loc: New York (Long Island)
      #4987983 - 12/28/11 05:58 AM
With my 10" refl using magnifications rangeing from 38-174x Eta appears, primary white, secondary org/yellow.
Rich (RLTYS)
piyro
Reged: 05/14/10
Re: eta cas question new [Re: RLTYS]
      #4988696 - 12/28/11 03:47 PM
Rich (RLTYS)
With my 60mm f/12 refractor at 56x it was easy, primary light yellow, secondary blue/white.
Pedro.
David Knisely
Reged: 04/19/04
Re: eta cas question new [Re: piyro]
      #4988914 - 12/28/11 06:06 PM
Rich (RLTYS)
Pedro.
Well, in such a small scope, the color estimates might not be all that good. The primary is a brighter 3rd magnitude G0 V star which generally is an off-white or vague yellowish-white color, while the companion is a dim magnitude 7.5 K7 V class dwarf star that is definitely reddish-orange (color index 1.39) and not really blue at all. Clear skies to you.
Dennis_S253
Reged: 11/22/11
      #4989257 - 12/28/11 10:44 PM
I thought I posted but I guess I didn't. Still need to learn this Quote stuff I quess. What I said was, tonight I was out and at 66.7X I could see a yellowish/white star and a orangish dimmer star. I opened up an old program I have called redshift 2. It says Eta Cas has (8) components. I can't believe I'm seeing Hip 3821A and Hip 3821B. Which makes me wonder why Sally list the A and B star Mags. I think I'm seeing a 8+ mag and there are a lot of other stars in the FOV.
David Knisely
Reged: 04/19/04
      #4989405 - 12/29/11 01:19 AM
Redshift was never known for its accuracy. There are at least seven stars brighter than 13th magnitude within about six arc minutes radius from Eta-A, but only one (Eta-B Cas) is a real physical companion (the rest are just fainter background stars). The nearest bright one other than Eta-B is 10th magnitude T 3663:1792:1 which sits about 1.7' arc to the southeast of Eta. Clear skies to you.
7331Peg
Sirius Observer
Reged: 09/01/08
Loc: North coast of Oregon
      #4989432 - 12/29/11 01:53 AM Attachment (15 downloads)
I covered this about a month ago, but I'll do it here again.
The WDS lists ten components for Eta Cass, but as Dave says in the post following yours, only one (B) is known to be gravitationally linked.
I came across the WDS listing by accident one evening, and was intrigued enough with the idea of seeing if I could hunt down all the components that I gave it a try. I located all of them without too much problem, and wrote up the whole affair here:
Another Look at Eta Cassiopeiae, in which We Return in Search of All Ten Components
And here's a sketch from that website showing the ten components:
John
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: eta cas question new [Re: 7331Peg]
      #4989521 - 12/29/11 04:30 AM
John, excellent observing report. I had fun attempting it and managed all but "J." Well, I think I glimpsed it in Stellarium.
3 registered and 2 anonymous users are browsing this forum.
Moderator:  PJ Anway, RLTYS
