Pages: 1 | 2 | 3 | (show all)
gapalp
Reged: 02/16/10
Loc: Georgia
AT65EDQ and triangle stars
      #5001067 - 01/04/12 03:15 PM
There have been some recent posts regarding "pinched optics" and the AT65EDQ:
link1
link2
The stars in my AT65EDQ images look awfully similar. I chalked it up to guiding but now that I re-reviewed these posts, I think I might have the same problem. Any thoughts? I am going to email the vendor about it too.
One of the suggestions is to "loosen the retaining ring slightly", which fixed a previous users problem. I am not sure what that means though.
Edited by gapalp (01/04/12 03:24 PM)
LLEEGE
True Blue
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: AT65EDQ and triangle stars new [Re: gapalp]
      #5001114 - 01/04/12 03:46 PM
The incoming side of the optic has a retaining ring which holds the glass in the cell.
First, extend the dew shield and unscrew it from the sliding ring and set aside. Next, unscrew the outer ring from the lens cell. This is just a ring to protect the threads of the lens cell. Inside, you will see a second retainer ring which holds the optics in place. There are two slots on either side which of this ring which allow the use of a spanner. You should re able to unscrew this with just your finger nails in the slots. Loosen this retainer ring 1/2 turn and re tighten it until it just touches the outer optic. Revers operation to put back together.
gapalp
Reged: 02/16/10
Loc: Georgia
Re: AT65EDQ and triangle stars new [Re: LLEEGE]
      #5001138 - 01/04/12 04:05 PM
Astronomics says to do it at the focuser end:
"Remove the focuser, unscrew the blue or black ring which has the housing the tight element is in. There is a silver ring with 2 notches in it that you can use a spanner wrench to loosen. Loosen it and then tighten it slightly and everything should be fine."
So which end is it? Plus, where do I get a spanner wrench?
Edited by gapalp (01/04/12 04:10 PM)
LLEEGE
True Blue
Reged: 03/03/05
      #5001172 - 01/04/12 04:35 PM
I guess it depends on which element is pinched. As far as where to get a spanner, you can make one or pick one up from a hardware store. I doubt you will need one. I can loosen mine with my fingers. You need to be careful not to slip and scratch the optic with any tools. Finger/fingernail is best.
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
      #5001173 - 01/04/12 04:35 PM
A "spanner" is a generic name for a wrench.
What you are looking for is a pin spanner or pin wrench. There are a number of commercial sources (specialty tool suppliers that will show up on an online search for "pin spanner") for these but you can also make your own from a piece of wood and two nails. You drive the nails in at the same distance as the diameter of the ring you want to move. You then file down the ends of the nails so that they are narrow and squared so that they fit snugly into the little slots on the ring you want to move. If you're careful you can often build a pin spanner that will be an effective tool (no slipping) and will last for years of use.
kw6562
Authoritative Ignoramus
Reged: 06/25/08
Loc: MA
      #5001329 - 01/04/12 05:57 PM
Astronomics told me the same thing, but I did not see a ring at the focuser side, so I loosened the objective side as LLEEGE mentioned. I used a screwdriver, which is risky, but in my case a fingernail could not provide enough torque to turn the ring. As LLEEGE said, it doesn't take much - just a slight movement to correct the problem.
Please be careful - you might want to send it back to Astronomics if you are not comfortable using tools around the lens. As Mark pointed out, you can make a serviceable pin spanner with a couple of nails and a piece of wood; I've done that in the past for another optical assembly with success. Good luck --Keith
gapalp
Reged: 02/16/10
Loc: Georgia
Re: AT65EDQ and triangle stars new [Re: kw6562]
      #5001366 - 01/04/12 06:16 PM
Thanks guys. I will loosen the objective side and see what I can do without a tool or with a screwdriver.
CapnRon
Reged: 03/03/09
Loc: NC
      #5001830 - 01/04/12 11:28 PM Attachment (37 downloads)
I received my AT65EDQ in October and have only had a few outings with it, but I think I may be experiencing the same issue. This is a 30 second exposure, where I paid attention to focus and polar alignment set up, it is a cropped region from an image of M33. The 2 minute exposure of the same region looks nearly identical, but with brighter stars.
I believe I should contact OPT and get their opinion on this, but I thought I would ask here first.
thanks for looking.
gapalp
Reged: 02/16/10
Loc: Georgia
Re: AT65EDQ and triangle stars new [Re: CapnRon]
      #5002389 - 01/05/12 10:58 AM
Looks like the same problem as mine and the others. I haven't tried the fix yet but will report back when I do.
gapalp
Reged: 02/16/10
Loc: Georgia
      #5002515 - 01/05/12 12:14 PM
Just got done making the adjustment to the objective retaining ring. I had to use a screwdriver to loosen it since it was so tight. I tightened it back with my hand until it just touched the outer optics. All in all a fairly easy process, just don't let the screwdriver slip!
The next night I get out I will test then post the results. That may be tonight.
David Ault
Reged: 09/25/10
Loc: Georgetown, TX
      #5003142 - 01/05/12 06:53 PM
After talking with several people about the triangular stars I got with my AT65EDQ I tried loosening the retaining ring on the primary optics first without any improvement. Both OPT and Astronomics thought it was the flattener ring that was too tight and I finally got a good description of how to access it. First, unscrew the focuser assembly from the scope (it just twists off). The flattener is in a separate assembly screwed into the main OTA. Mine was quite tight and took some force to unscrew. Once removed you should be able to loosen the flattener retaining ring just like the one on the primary optics. The retaining ring on my flattener was VERY tight, even when the scope was warm. I had to use a screwdriver to loosen it which also took some force and a lot of care to not touch the optics when it gave way. I must have gone a little too far and unseated the flattener as the ring gave way because I now see potato shaped stars (David B in NM suggested this was the cause).
Good luck with yours.
David
gapalp
Reged: 02/16/10
Loc: Georgia
Re: AT65EDQ and triangle stars new [Re: David Ault]
      #5003243 - 01/05/12 08:16 PM
Thanks for the info. I am seeing the same results with triangle stars even after adjusting the objective side. I see it with 5 and 10 second exposures without autoguiding so I know it is the optics. I will try the focuser side next. If that doesn't work I will have to send it back to the vendor to resolve.
Did you ask the vendor to take yours back since you still have distorted stars?
David Ault
Reged: 09/25/10
Loc: Georgetown, TX
      #5003357 - 01/05/12 09:49 PM
I purchased the scope from OPT and had actually started a return with them when David B in NM PM'd me and suggested I make sure the flattener was seated properly. I'm just about to test that now. If I get nice round stars I'll ask them to cancel the return tomorrow.
David B in NM just received his AT65EDQ and noticed that his Quality Control card was blank. I went and checked mine and it was blank as well, so you might check yours too.
David
gapalp
Reged: 02/16/10
Loc: Georgia
      #5003486 - 01/05/12 10:54 PM
OK. I adjusted the flattener retaining ring, twice actually. The first time I did it then mounted the scope and did some test images. I was getting potatoe stars instead of triangle stars, similar to David's description.
So I thought it must need tightening some more, maybe I loosened it too much. So I got in there again and tighted it more than hand tighten but not as much as a spanner wrench would (was using a screwdriver) or as much as it was from the factory.
Here are my current results:
10sec
5sec
I believe there is still some distortion, but it is about 90% better than what it was. Do you think I should continue trying to perfect this?
David B in NM
Reged: 09/05/10
      #5003494 - 01/05/12 11:00 PM
gapalp,
That looks very good to me even zoomed to 400 percent. Most stars really appear as almost perfect circles through my eyes.
I'd suggest taking a couple real images and see what you think before you make any re-adjustment.
David B in NM
zerro1
Reged: 08/02/09
Loc: Smokey Point , 48.12°N 122.25...
      #5003523 - 01/05/12 11:25 PM
it looks like there might still be a small amount. obviously you're on the right track. that flattener is a chunk of glass, isn't it. One thing I did find on mine after quite a bit of use; the 4 screws in the bottom of the focuser mechanism came loose, caused some issues.
I've had mine apart for different reasons but never encountered these distortions that you guy's are experiencing. I had the cell completely dis-assembled and removed the flattener. When I re-assembled, I just "lightly snugged" the retainer ring's. enough to be certain it wouldn't shift but not so much to really put tension on anything.
gapalp
Reged: 02/16/10
Loc: Georgia
Re: AT65EDQ and triangle stars new [Re: zerro1]
      #5004009 - 01/06/12 10:29 AM
Yeah I notice a small amount of distortion left. I may have a go at another imaging run but if these 5/10 sec exposures are showing, surely longer, stacked images will.
I could make more adjustments to perfect it, but I am at the point of wanting to send it back. It is only a 3 month old scope. If one or two user adjustments doesn't fix it, what is the customer really supposed to do? I am waiting on the opinion of the vendor to see what they say.
gapalp
Reged: 02/16/10
Loc: Georgia
      #5004052 - 01/06/12 10:59 AM
The vendor (Astronomics) responded feeling the images show I have the element tightened properly. I do trust their opinion in this as they are one of the best vendors I and others have dealt with.
The slight distortions I currently see in these recent images could be from focus/fogging up/ambient temp problems since I had to take the scope inside/outside several times last night while making the adjustments.
I will proceed with an imaging session without any more adjustments. I think I will be satisified with the results. It is a huge improvement over the triangle stars!
Edited by gapalp (01/06/12 11:10 AM)
David Ault
Reged: 09/25/10
Loc: Georgetown, TX
      #5004363 - 01/06/12 02:38 PM
No ammount of loosening or tightening of retaining rings or attempting to get the flattener seated properly removed my 'potato' stars. Maybe someone more experience than I could correct this, but I decided if it's so fiddly in the first place it's not the right scope for me at this point in time and with my experience. So, mine is going back.
Needless to say I'm a little disappointed, but I can't complain too much. I've gotten a crash course in optics and the overall learning experience should prove invaluable with the rest of my astronomy.
I hope the rest of you come away with more than just education
David
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #5004401 - 01/06/12 03:05 PM
David
Me, too. It's really a sweet little imager when working properly (mine required no fiddling).
sample
4 registered and 13 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, fishonkevin, WOBentley, rflinn68
