Privacy Policy |
Please read our Terms
of Service | Signup and
peter clark
Reged: 09/25/07
Re: The South Cave Collimator System
[Re: nirvanix]
#5011073 - 01/10/12 05:52 PM
What success have you found with the South Cave Collimator?
peter clark
Reged: 09/25/07
[Re: Jason D]
#5535795 - 11/23/12 04:03 PM
Hi Jason, Good drawings shown in optical desire progress from A to C. However B and C need to swop positions because to produce a concentric star at slightly de-focussed image the reflection angle needs to be something other than 90 degrees. Your B is fine for the completion of bench testing and so ready for a star test to produce any off-set needed to complete collimation. 3 telescopes now with no image shift when going from one side of focus to the other. Best regards, Peter
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
[Re: peter clark]
#5535984 - 11/23/12 06:15 PM
I have gone back and re-read the original article for the tenth time. It is obvious the originator does not speak English as a native speaker, or has gone to the "Yoda" school of Buddhist Obtuse Sayings, because I simply cannot make sense of what he is describing. Also, none of the attachments or photos in this thread download correctly, and I get "damaged file" messages on most of them. From what I do understand, though, the alignment method is similar to the techniques you might use on an f/10-f/15 scope, though oddly backwards from how it is currently done, but will not be successful on an f/4.5 newtonian.
peter clark
Reged: 09/25/07
[Re: Jason D]
#5536989 - 11/24/12 10:35 AM
Hello again Jason, I benefitted from your drawings 3 years ago nearly. However,I now your B & C drawings need to change positions because B is more like the mechanical set up when optically collimated by a star, owing to 90 degrees not being the best reflection angle. So the new order suggest A needs collimating. B (your C) shows completion of bench collimating. I've a drawing to show. Best regards, Peter Clark
1 registered and 2 anonymous users are browsing this forum.
Moderator: droid, iceblaze
