WayneJ
Reged: 08/20/09
Loc: West Chester, PA
Mars - animation of high-altitude ice cloud
      #5133763 - 03/21/12 02:10 PM
Hi all,
Here's a 5-frame animation in green-light of something I imaged on the evening of March 20 (2:15-2:51ut, March 20) -- that's two nights ago. I had no idea what this was and after receiving information from a number of sources, it's most likely a high-altitude water-ice cloud over the Acidalia region. These are not particularly uncommon and have been imaged on occasion before.
Also, I know of at least one other imager in the eastern U.S. that captured the phenomena last night, so if you captured this CM in your images, you should check careful to see if you got it too. Note that it shows up best in green and blue light and becomes nearly invisible in IR (at least from my images.)
Click here for the Animation (750k)
Also, here's an RGB image (around 2:51ut) showing the feature on the upper right side. I haven't processed all the data from the 20th or from last night (when I captured it again), but I think I have some better images showing the cloud over the limb with a slight separation from the planet. The seeing was running in the 8-9/10 range on the evening of the 19th and 7-8/10 last night.
Wayne
john rozakis
Reged: 01/09/11
Loc: ATHENS GREECE
Re: Mars - animation of high-altitude ice cloud new [Re: WayneJ]
      #5133804 - 03/21/12 02:30 PM
Wow Wayne ! Great capture !
James W.
Reged: 05/14/07
Loc: Maryland
Re: Mars - animation of high-altitude ice cloud new [Re: john rozakis]
      #5133820 - 03/21/12 02:38 PM Attachment (298 downloads)
Here is my blue channel image from last night (21st) taken at 0258UT that shows your cloud at about the 12 O'clock posistion. I stretched it with levels some to bring it out better.
swalker
Imaging Editor - Sky & Telescope
Reged: 01/22/07
Loc: 42.9225°N, 71.2242°W
Re: Mars - animation of high-altitude ice cloud new [Re: James W.]
      #5133828 - 03/21/12 02:45 PM
Excellent Wayne- very odd phenomena.
James W.
Reged: 05/14/07
Loc: Maryland
Re: Mars - animation of high-altitude ice cloud new [Re: swalker]
      #5133853 - 03/21/12 03:03 PM Attachment (123 downloads)
Here is another blue channel taken at 0307UT on the 21st and a link to an animation of both the 0258 and 0307 images.
http://howardastro.info/halgal/main.php?g2_itemId=12082&g2_imageViewsIndex=1
CPellier
Reged: 08/07/10
      #5133899 - 03/21/12 03:35 PM
Wayne and James : very good work ! Especially, good B images
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
Re: Mars - animation of high-altitude ice cloud new [Re: CPellier]
      #5133961 - 03/21/12 04:10 PM
Incredible resolution! Wow!
Rutilus
Reged: 12/17/10
Re: Mars - animation of high-altitude ice cloud new [Re: Space Cowboy]
      #5134096 - 03/21/12 05:24 PM
Very good captuere, interesting feature.
Edited by Rutilus (03/21/12 05:27 PM)
Yuri_18
Reged: 07/29/07
Loc: Minsk, Belarus
Re: Mars - animation of high-altitude ice cloud new [Re: Rutilus]
      #5134119 - 03/21/12 05:34 PM
Incredible!!
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Mars - animation of high-altitude ice cloud new [Re: Yuri_18]
      #5134204 - 03/21/12 06:08 PM
I measured the height of the cloud based on the known diameter of the planet and the number of pixels that the cloud extends above the surface. The height is approximately 100 kilometers which is interesting because that's the maximum height to which particulate matter rises during planet wide dust storms. From what I've read gaseous clouds don't rise to anywhere near that altitude which is the very top of the Martian atmosphere.
Pete Nerbun
Edited by lcd1080 (03/21/12 06:10 PM)
Kecktastic
Reged: 01/16/10
Loc: Broken Hill NSW Australia
      #5134207 - 03/21/12 06:09 PM
Very impressive Wayne & I see James has also captured the same feature, well done James.
Most excellent "G" channel data Wayne and nice animation, thinking back, I recall Asi also captured a similar feature a few weeks ago, though not as prominent as in your "G" channel.
Top Stuff.
Regards
Trevor
JimP
Reged: 04/22/03
Loc: South Carolina
Re: Mars - animation of high-altitude ice cloud new [Re: Kecktastic]
      #5134218 - 03/21/12 06:12 PM Attachment (217 downloads)
Here is one of my images from last night plus the blue channel just to confirm.
best,
Jim Phillips
JimP
Reged: 04/22/03
Loc: South Carolina
Re: Mars - animation of high-altitude ice cloud new [Re: JimP]
      #5134220 - 03/21/12 06:14 PM Attachment (208 downloads)
Here's the color image.
TMB 8" F/9
Good seeing.
JimP
Reged: 04/22/03
Loc: South Carolina
      #5134224 - 03/21/12 06:16 PM
Not sure what it is. Ice cloud? Perhaps but if it is it certainly is not usual nor is it common. This would be Highly unusual for an ice cloud.
best,
Jim Phillips
JimP
Reged: 04/22/03
Loc: South Carolina
      #5134240 - 03/21/12 06:22 PM
Here is what Richard McKim of the BAA e-mailed me after I sent him my images:
"If it's real then it's staggering! I am looking for other images at the same time but thanks in advance. A dust storm at that location at this season would be unheard of. Have you eliminated the possibility of some filter defect by rotation during the session, perhaps, or was it only noticed at processing?
All the best
Richard"
Lsummers
Reged: 07/08/11
Loc: Dover, DE
      #5134242 - 03/21/12 06:22 PM
We've seen high-altitude water-ice clouds on Mars in the past. Never to my knowledge has one so clearly been captured in ground-based amateur imagery. Certainly a rare and exciting event.
Well done Wayne! Thank you for spotting this and bringing it to everyone's attention!
Larry
Bird
Reged: 08/07/03
Loc: Murrumbateman, Australia
Re: Mars - animation of high-altitude ice cloud new [Re: Lsummers]
      #5134248 - 03/21/12 06:25 PM
Well done to Wayne and the others that captured this phenomenon! Shows that there is still a lot to be discovered on nearby planets...
cheers, Bird
JimP
Reged: 04/22/03
Loc: South Carolina
Re: Mars - animation of high-altitude ice cloud new [Re: Bird]
      #5134274 - 03/21/12 06:45 PM
Whoops, here is a second e-mail from Richard McKim:
"Dear Jim:
Thank you. In fact I misunderstood your ......-18LTL image, as I was looking more at the large light area you had artificially highlighted rather than the terminator projection. Before your blue image arrived on its own I had assumed, from quickly reading, that the artificial area was the new feature! It is all perfectly reasonable-looking now that I have your blue image and, although we don't see much phase visually yet there will be a slight and growing phase defect on the following side.
Although quite evident the projection is no doubt standing out even more because the processing of any image has caused the terminator to darker somewhat (and in the case of Venus to recede) to leave the projection more visible. There is a history of high latitude martian projections. I am thinking of certain HST images from the 1990s, and visual observers have certainly detected many, and I can recall quite a few examples even in my own Mars reports. I don't think our amateur images were good enough to catch them before 2003. I have examples in the 2003 BAA Mars report which is posted as a pdf at www.britastro.org\mars...............
This particular one you have caught so nicely is certainly on the large side, and I hope you will get the chance to repeat the observation at the same CM over several nights. And that brings me to ask if you can compute the CM and put it on each image because it does save looking it up. From the position of Propontis with regard to the morning terminator I would say that the attached image by Efrain Morales is really pretty similar to yours in CM but is dated two days earlier (March 19d 02h 31m UT). I notice that he shows the same effect but it is less visible. It is easily missed unless one enlarges the image.
I will of course search for others. I receive a lot of material which is not uploaded to any of the image archiving websites.
Let me know what you think.I am off to bed as it is getting late here and I must teach first thing in the morning!
With regards
Richard"
Jim Chung
Vendor - Icodome
Reged: 12/07/05
Loc: Toronto
      #5134300 - 03/21/12 07:01 PM Attachment (159 downloads)
Just wanted to confirm that I also captured this strange feature last night which I thought was a processing artefact.
Edited by Jim Chung (03/21/12 07:03 PM)
rumples riot
Reged: 07/01/04
Loc: South Australia
Re: Mars - animation of high-altitude ice cloud [Re: Jim Chung]
      #5134353 - 03/21/12 07:31 PM
Yet another land mark breached in planetary imaging. Well done guys impressive work.
17 registered and 17 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
