General Astronomy >> General Observing and Astronomy
stratocaster
Reged: 10/27/11
Legacy research scopes vs today's hobby scopes new
      #5138007 - 03/23/12 11:08 PM
Most of us today would probably agree that as amateurs the hobby of astronomy has never had it so good. There's a lot of great equipment out there. I started wondering how good some of this equipment might be compared to the old research scopes that were manufactured around the late 1800s or early 1900s.
Our astronomy club has a tentative 'field trip' planned for Lowell observatory, so I started reading up a bit. I read about the 24" refractor at Lowell (circa 1896) and was wondering if anyone had any thoughts on the capability of scopes built "back then" to today's better hobby scopes. I have no idea what type of glass those historic scopes were made of or how well such huge lenses could be manufactured given the technology of the day. I suspect the long focal lengths were used to limit CA and perhaps allowed for easier making of the lens, but I really have no idea.
While obviously there are no 24" refractor hobby scopes out there, I'm wondering how a scope such as that might compare to perhaps a 24" or 30" reflector of today - or perhaps even to some of the larger APOs of today - say a 6" APO.
Many years ago while visiting Griffith Park Observatory I took a look at Jupiter thru the 12" Zeiss scope there (circa 1935). I remember thinking Jupiter didn't look any different than what I'd seen in hobby scopes and walked away a bit disappointed.
So I was wondering if there might be some scope historians out there, or perhaps just some general thoughts.
derangedhermit
Reged: 10/07/09
Loc: D/FW, TX
Re: Legacy research scopes vs today's hobby scopes new [Re: stratocaster]
      #5141540 - 03/26/12 02:05 AM
I can't say in general, but I can comment about the Lowell refractor in specific. I spent a couple of hours with it one night maybe a decade ago.
The field of view is unnecessarily narrow (due to the long focal length) according to today's standards for telescope design (one eyepiece we used was a custom eyepiece of about 100mm focal length). Visual observing was cumbersome. My understanding is that the "circular bleachers" arrangement there today is similar to what was used then, so you were moving slowly up and down and around in an arc of the huge (15 foot radius?) part of a sphere that is the viewing position. I'm sure they became familiar with the physical routine and thought little of it, having access to what was a world-class instrument at the time.
The instrument and facility (dome, mount, etc.) wasn't well maintained for actual use when I visited. Brian Skiff was encouraging the management to fund improvements. I hope they have been made - it's a historic resource that should be preserved.
I didn't do critical observing, but I have little doubt that a decent 24" Newtonian of today would be superior in every way.
stratocaster
Reged: 10/27/11
Re: Legacy research scopes vs today's hobby scopes new [Re: derangedhermit]
      #5144371 - 03/27/12 05:38 PM
Thanks derangedHermit. I found your comments interesting.
TexasRed
Reged: 05/17/11
Loc: East Texas
      #5144640 - 03/27/12 08:22 PM
I'd be interested in knowing about what year a given one of today's hobby telescopes would be the equivalent of one of the finest telescopes in use about that time. My 12" Newtonian would roughly equal the best available about... when?
tezster
Reged: 07/14/09
Loc: Missisauga, Canada
Re: Legacy research scopes vs today's hobby scopes new [Re: TexasRed]
      #5144832 - 03/27/12 10:53 PM
Probably not until fairly recently if you include the goto
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
      #5145072 - 03/28/12 06:07 AM
A number of reflectors were built in the 18th century that could probably outperform a modern 12-inch reflector in most regards. Of those, William Herschel's 18-incher is the most important by far. The list of deep-sky objects that he discovered with it speaks for itself.
Tony Flanders
Reged: 05/18/06
      #5145079 - 03/28/12 06:16 AM
In terms of construction quality, those giant old refractors are magnificent.
However, they did use conventional crown and flint glass, resulting in whopping enormous chromatic aberration. CA is proportional to the square of the aperture divided by the focal length. A conventional 4-inch refractor needs a focal length around 60 inches to have relatively imperceptible CA. To equal that in a 24-inch achromat would require a focal length of 180 feet, which is impractical.
Nonetheless, those grand old refractors make amazing planetary instruments. Obviously, they're restricted by seeing conditions, just like any other scope.
Of course, a good modern 24-inch amateur reflector also makes an amazing planetary instrument.
Reged: 06/16/04
Re: Legacy research scopes vs today's hobby scopes new [Re: Tony Flanders]
      #5145107 - 03/28/12 07:02 AM
Herschel lived before the invention of the silvered glass mirror, he used Speculum metal mirrors. Speculum reflects 66% of the light at best and tarnishes quickly. His 18 inch scope probably had the light thru-put similar to a modern 12 inch. His discoveries are impressive.
Tony Flanders
Reged: 05/18/06
Re: Legacy research scopes vs today's hobby scopes new [Re: Jon Isaacs]
      #5145156 - 03/28/12 08:14 AM
Probably a bit better than that, I think. The 66% figure is at the low end of the estimates, and even assuming that it's correct, you still end up with the 18-inch delivering 50% more light than a 12-inch scope with 100% reflective mirrors. And of course, even the best modern coatings don't reflect 100% of the incident light!
On the other hand, Herschel was stuck with completely uncoated eyepieces. He made his own eyepieces as well as his own mirrors.
As for tarnishing -- yes, Herschel did indeed spend a big chunk of his life repolishing and refiguring that mirror. No wonder he got to be the world's best telescope maker!
Taking it all together, I would guess that Herschel's 18-inch was roughly equivalent to a modern 14- or 15-inch scope.
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
      #5145297 - 03/28/12 10:37 AM
William Hershel also did all of his oberservations before the invention of the LIGHT BULB.
He had the darkest skies on Earth, compared to most modern observers.
I have not been to a blue, grey or black zone yet, but the difference between my orange home skies and a green site 40 miles away is tremendous. At that green site I have stumbled on NGC's by accident with a 10', they seem to jump right out at me, probably because I spend so much time trying to tease objects out of the light pollution at home.
With a mediocre 18" at a black site, I'm sure by eye would bleed from pure pleasure.
Edited by shawnhar (03/28/12 10:39 AM)
Reged: 06/16/04
Re: Legacy research scopes vs today's hobby scopes new [Re: shawnhar]
      #5145360 - 03/28/12 11:31 AM
It is my understanding that the skies were not all that black, there were still lights, fires and the like. The skies were smoky though since wood and coal were the only forms of heat and power. Add in the English weather, I don't think he had it all that great...
Don't know though, that was before my time.
Herschel's scopes were built before the invention of the Foucault test which is really one of the two things that made reflectors practical. Without bench tests to determine the progress of the mirror, figuring a quality mirror was hit and miss, my guess is that mirrors were not very good by today's standards.
Silvering of the mirrors allowed for the use of glass as a material, it tarnished more quickly but had a much higher reflectivity and recoating was relatively easy. The silvering of mirrors and the Foucault test were both develeped around 1860 and marked the end of the speculum mirrors and the rise of the modern reflector both in amateur astronomy and research. I believe aluminization was developed in the 1930's.
It's difficult to say exactly how effective Herschel's scopes were but if you add it all up, the poor reflectivity of the mirror, the heavy metal mirror, the crude eyepieces (probably 2 element), the lack of optical coatings, whether his 18 inch performed as like a 14-15 inch or a 12 inch, or less, I sure glad I observing today with all the modern conveniences and lightweight portable scopes.
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
Re: Legacy research scopes vs today's hobby scopes [Re: Jon Isaacs]
      #5145513 - 03/28/12 01:07 PM
DOH! I didn't even think about all the wood and coal burning, my own fireplace has ruined my session more than once.
0 registered and 9 anonymous users are browsing this forum.
Moderator:  cildarith, droid, tecmage
