Dave Ponder
Reged: 04/12/06
Loc: Greenville, SC
Question for UniStar Mount Owners
      #5146615 - 03/29/12 07:35 AM
I received the UniStar Deluxe Mount recently, but have some concerns how "smooth" its motions should be. I do balance my scope, an EON 120, but the motions mainly in altitude show "stick-tion" (if that is the right word). I constantly move past the object being viewed when trying to center it at higher powers (200x plus). There is some play in effect before the friction kicks in to hold the scope. I have tried to adjust the tension knob but if I tighten it enough to take out the play, it increses the stick-tion factor. From reviews I have read, I was expecting this mount to very smooth at high powers and not having to bob the scope up and down trying to keep the object in the field of view. Hope this all makes sense. How does your UniStar Mount perform with respect to its motions, sticky or smooth?
Jeff Bennett
Reged: 10/30/05
Loc: Clayton, California
Re: Question for UniStar Mount Owners new [Re: Dave Ponder]
      #5147024 - 03/29/12 12:11 PM
I use a Unistar Deluxe with my SV115T and find it to be very smooth with virtually no play. I find that I can adjust the altitude friction from almost nothing to something a lot tighter and get the same smooth performance.
What you describe does not sound like my experience at all, and I would suggest calling Larry at UA. He is a great guy to deal with, and he will make it right in my experience.
Jeff Bennett
Edited by Jeff Bennett (03/29/12 12:14 PM)
Phil Frederick
Reged: 12/19/05
Loc: Seattle, WA & La Paz MX
      #5147056 - 03/29/12 12:24 PM
Dave,
I've got the same setup as you (EON120/Unistar Dlx/SV Stablelock tripod) and don't seem to have an issue with either stiction or backlash. Panning is very smooth and I don't have an issue overrunning my target. I wonder if you might have an problem with a bad bearing surface??? Perhaps you might want to contact Larry at UA and describe the problem--maybe he'd have a solution for you. Or perhaps someone else here has experienced the problem and has a fix for you.
Bummer, as this certainly seems to be a nice mount at least in my experience...
Phil
Dave Ponder
Reged: 04/12/06
Loc: Greenville, SC
Re: Question for UniStar Mount Owners new [Re: Phil Frederick]
      #5147103 - 03/29/12 12:42 PM
Any you guys are using, say, 200x or higher power and do not experience any stiction, backlash or overruns??
Much thanks,
Dave
Jeff Bennett
Reged: 10/30/05
      #5147203 - 03/29/12 01:37 PM
I routinely run my SV115T at 160X and sometimes at 228X (with 5 and 3.5mm XWs) On the Unistar with no backlash or sticking.
Jeff
Edited by Jeff Bennett (03/29/12 01:38 PM)
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #5147238 - 03/29/12 01:56 PM
I bought a Unistar for my heavy as a stock C11 C9.25 2 months ago. I'm having the same sticktion-backlash problem with both axis. I called Larry and he said the mount will get smoother after a breakin period. I've only used the mount a few times so that hasn't happened yet. My main taget now is Mars which is all about high power. I observed Mars once using the Unistar it was frustating to say the least. After Mars leaves the scene I'll breakout the Unistar. The Moon will make a good high power practice object given it's size. David
Edited by dscarpa (03/29/12 01:57 PM)
Jim7728
Reged: 04/10/05
      #5147243 - 03/29/12 01:57 PM
190x has been very manageable with my MN-66 and Unistar Deluxe/CG-5 tripod. Some settling occurs after tracking at that high power, but is acceptable to me. Key with any manual alt/az is good balance of the ota especially on the altitude axis which then requires that the tension knob be only snug , not tight which can lead to sticktion.
I should also add the Unistar was bought used or "broken in".
Edited by Jim7728 (03/29/12 02:01 PM)
Scott in NCAdministrator
80mm Refractor Fanatic
Reged: 03/05/05
Loc: NC
      #5147247 - 03/29/12 02:00 PM
That would be my guess as well. Fortunately, this is a very easy (and inexpensive) thing to fix. I'd definitely give Larry at UA a call.
Reged: 03/05/05
Loc: NC
      #5147253 - 03/29/12 02:03 PM
Much thanks,
Dave
I usually don't go much above 200x with any of my refractors (mainly due to atmospheric limitations), but have not noticed any of the issues you mentioned. Getting the scope perfectly balanced is key, however, in minimizing the likelihood of these problems.
Rich V.
Reged: 01/02/05
Loc: Lake Tahoe area, Nevada, USA
Re: Question for UniStar Mount Owners new [Re: Jeff Bennett]
      #5147264 - 03/29/12 02:09 PM
I've run into some tension difficulties on the alt axis with my Unistar Super 8/ TMB 130. It seems to me that too much torque is being transferred to the interface between the tension knob/nylock nut and the axle bushing in the upright. This works some slop into the system eventually as the nylock wears making a "dead spot" in the friction. Sometimes there is sufficient torque to even loosen the tension knob when moving the scope while set at higher friction levels.
I found the simple answer was to put a needle thrust bearing between the tension knob and the upright arm of the mount. This took all the torque off the knob/nut and put it onto the teflon bearing surface where it belongs. Alt motions are smooth and predictable with the bearing in place.
This is the thrust bearing I used:
http://www.vxb.com/page/bearings/PROD/Thrust/Kit8670
I'm very happy with the results. Smooth even at 300x.
Rich
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #5147456 - 03/29/12 03:53 PM
Thanks for the tip!. It can't hurt to get a bearing for both axis. David
Edited by dscarpa (03/29/12 03:56 PM)
Rich V.
Reged: 01/02/05
Re: Question for UniStar Mount Owners new [Re: dscarpa]
      #5147471 - 03/29/12 04:04 PM
The bearings are inexpensive but there's an approx. $5 shipping fee. I bought several bearings since the shipping was a fixed price anyhow. Got an extra for a friend's Unistar also. I just smeared some quality synthetic/teflon bicycle bearing grease on the bearing when when I put the stack together.
Don't know why Larry doesn't use a thrust bearing in the first place; it does a great job of putting the frictional load where it belongs.
Rich
zawijava
Reged: 10/06/07
Loc: Wells, Maine 04090
Re: Question for UniStar Mount Owners new [Re: Rich V.]
      #5147727 - 03/29/12 07:38 PM
Rich
Any chance you've got a pic of that bearing installed? thanks, Tim
Rich V.
Reged: 01/02/05
Re: Question for UniStar Mount Owners new [Re: zawijava]
      #5147758 - 03/29/12 08:12 PM Attachment (52 downloads)
The bearing just stacks behind the tension knob; it's thin like three washers so you hardly know it's there.
Photos of bearing on alt axle and complete knob/bearing assy as used.
Rich
Rich V.
Reged: 01/02/05
      #5147759 - 03/29/12 08:15 PM Attachment (42 downloads)
Bearing in normal use; hidden under the tension knob:
Edited by Rich V. (03/29/12 08:17 PM)
Reged: 03/05/05
Loc: NC
      #5147768 - 03/29/12 08:24 PM
Great tip, Rich, and thanks for the illustrations! I'm going to file this post away for future use, in case my Teflon bearings ever wear out.
zawijava
Reged: 10/06/07
      #5149036 - 03/30/12 04:01 PM
thanks Rich, great tip...think I'll give it a try.
Tim
Goodchild
Reged: 12/31/08
      #5149403 - 03/30/12 09:12 PM
Rich, quite honestly, it seems to me that that would eliminate all tension and your scope would be free-floating in the alt axis. No?
It looks like you removed the teflon bearing on this bolt. Yes?
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: Question for UniStar Mount Owners new [Re: Goodchild]
      #5149419 - 03/30/12 09:30 PM
I was about to ask the same question myself.
zawijava
Reged: 10/06/07
      #5149550 - 03/30/12 11:23 PM
Turning the knob essentially tightens a nut [inside the knob] on the threaded shaft that runs through to the plate where you attach your scope. [actually the knob itself may in fact be a solid piece with a threaded center hole]. The essential friction/tension is on the larger teflon spacer on the scope side of the mount. The roller bearing reduces the non-essential friction on the knob side which often causes the knob/nut to back off the threaded shaft when the scope is moved up and down on the Altitude axis.
I understand that my explanation leaves room for further clarification so I hope someone else gives their version. -Tim
Edited by zawijava (03/30/12 11:54 PM)
20 registered and 47 anonymous users are browsing this forum.
