Pages: 1 | 2 | 3 | (show all)
nomosnow
Reged: 03/21/11
Loc: Fort Saskatchewan,Ab ,Canada
Do you measure double stars??
      #5155600 - 04/04/12 01:29 AM
Hi
I am having a lot of fun measuring double stars with my astrometric EP. And I am quite happy with my first time accuracy. I am using procedures that Bob Argyle suggests in his excellent book.
I am hoping that maybe I could "help out" in measuring some neglected doubles . Does anybody actually do this and if so where would you submit your results.
In anycase it is fun doing some "classic" astronomy.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Do you measure double stars?? new [Re: nomosnow]
      #5156693 - 04/04/12 08:05 PM
Yes there are people who do this - one individual comes to mind with a 90mm Questar. Heres an informative link to get you started;
http://www.skyandtelescope.com/observing/objects/doublestars/3304341.html
Pete
buddyjesus
Reged: 07/07/10
Loc: Davison, Michigan
Re: Do you measure double stars?? new [Re: azure1961p]
      #5170872 - 04/13/12 05:52 PM
I am eager to get to measuring some of the doubles also. This journal has good articles that describe the methodology.
http://www.jdso.org/
rookie
Good Night Nurse
Reged: 01/14/06
Loc: St. Petersburg, FL
Re: Do you measure double stars?? new [Re: buddyjesus]
      #5171051 - 04/13/12 07:51 PM
I have made a game of "Guestimate".
I make an observation, go check my results on Skytools, and then look again to see how I could have done better. I'm learning and improving but some nights are better than others. A reticle ep is a nice investment.
Hats off to those that take the time to make fine measurements.
desertstars
Reged: 11/05/03
Loc: Tucson, AZ
      #5171227 - 04/13/12 10:24 PM
A good source of double star information all around.
ken hubal
Reged: 05/01/07
Re: Do you measure double stars?? new [Re: desertstars]
      #5172285 - 04/14/12 04:11 PM
I you can obtain a Filar Micrometer, do so. It is a good tool for making measurements. Otherwise, a good astrometric eyepiece will work.
drollere
Reged: 02/02/10
Loc: sebastopol, california
Re: Do you measure double stars?? new [Re: ken hubal]
      #5173768 - 04/15/12 01:54 PM
the u.s. naval observatory (USNO) curates the largest double star database (WDS). if you go to their home page you will find links to a list of "neglected doubles":
http://ad.usno.navy.mil/wds/wdstext.html#files
perusing the list, you'll find many stars that haven't been measured since they were discovered, and many of those that haven't been measured in decades or even since the 19th century. most are brighter than v.mag 10. jump in.
you will need to document all your observations as well as your summary statistics for each pair. you'll need to make multiple measurements with the micrometer eyepiece on at least two different nights. it can get tedious if you're not motivated.
the JDSO ( http://www.jdso.org/ ) periodicals describe a variety of measurement methods and results. you should review those to get a sense of what's possible.
i believe the JDSO is the place to send your observations, so contact them for details. stuff they approve gets passed on to the guys at USNO for their review and eventual inclusion in the WDS.
i also have made a real effort to judge position angle and separation by eye. at present i can usually guesstimate values to around 20% of separation and plus/minus 20º PA. nothing formal; i do it so that i can recognize when the catalog source i'm using is probably incorrect, and can check the system in WDS. i've even found a few systems in obvious need of new measurement ... a project for later this year.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #5180431 - 04/19/12 02:33 PM
As others have said, JDSO is the place to go. Look for articles by Russ Genet and his group, they make extensive use of astrometric EPs and there are articles you need to read about techniques that are scattered through several years. I use a webcam, which I find more efficient. But, use what you have.
Ed
rookie
Good Night Nurse
Reged: 01/14/06
Re: Do you measure double stars?? new [Re: Ed Wiley]
      #5253822 - 06/03/12 07:13 PM
I've looked for 360 degree protractors in the past, couldn't find one and then forgot about buying one. Then today, spotted them on clearance at Staples for $.50. It's a nice sturdy 6" Staedtler. Apparently the rush from the double star measuring astronomers has passed and Staples has been caught with a plethora on their shelves.
WRAK
Reged: 02/18/12
Re: Do you measure double stars?? new [Re: rookie]
      #5254346 - 06/04/12 08:28 AM
I own a 12.5mm micrometer eyepiece but use it only if I have good reason for it - means clear differences between my guesses based on visual observation and catalogue entries (I usually avoid having all informations about the doubles in my sessions plans especially the position of the companion to be better able to counter check with catalogues if my observations are correct). The need to use different or several barlows and to have to do some calculations afterwards to translate eyepiece divisions into degrees and arcseconds takes somewhat the fun out of it. A Filar Micrometer would at least make the measurement of separations a bit more flexible but I found so far no source
payner
Reged: 03/22/07
Loc: Bluegrass Region, Kentucky
Re: Do you measure double stars?? new [Re: WRAK]
      #5255000 - 06/04/12 05:02 PM
Check Van Slyke Instruments for a production bi-filar micrometer. Better be seriously into this endeavor because they are not cheap.
WRAK
Reged: 02/18/12
Re: Do you measure double stars?? new [Re: payner]
      #5255637 - 06/05/12 03:10 AM
Thanks payner, great tip with Van Slyke, will consider even if the price is somewhat stiff.
Only one drawback - my APO is for reasons of ease to use with 980mm rather short, so the included 25mm Plössl does not make much sense for me despite the included 2x barlow. But I think you should be able to use any 1.25" eyepiece with it, I will check this.
Wilfried
Simoes Pedro
Reged: 02/03/09
      #5259850 - 06/07/12 11:00 AM
If I purchased my own reticle from Edmund opticsto mate it to an eyepiece I already own, I has to be placed at eyepiece's field stop, right?
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
      #5260224 - 06/07/12 01:55 PM
I am surprised no one has mentioned making a diffraction micrometer. They are very very cheap and give results equal to or better than some reticle eyepieces:
Observing and Measuring Visual Double Stars: the diffraction micrometer
It won't work for some fainter pairs, but for moderately bright ones, it is a simple and easy way to get into double star measurements. Clear skies to you.
WRAK
Reged: 02/18/12
Re: Do you measure double stars?? new [Re: David Knisely]
      #5263434 - 06/09/12 02:01 PM
Quite interesting. There is another article on this topic "http://www.nyskies.org/articles/pazmino/diffmic.htm" - but the handling seems a bit time consuming, especially field rotation (I use an alt-az mount without tracking) is an obstacle.
I found an interesting article of Thomas G. Frey "Visual Double Star Measurements with an Alt-Azimuth Telescope" in JDSO Spring 2008 using an micrometer eyepiece and especially the measurement of the position angle does not seem so difficult to me anymore as after aligment of the double on the linear scale and positioning the primary on its central mark you have simply to wait until the primary reaches the angle scale giving you the value for the position.
Wilfried
chascar
Reged: 02/14/05
Loc: Franklin Massachusetts
      #5269270 - 06/13/12 09:56 AM
There is a good article on Belt of Venus web site about putting together a protractor assembly for astrometric EP also second edition of Argyles book is due out Aug. 2012
chascar
Reged: 02/14/05
      #5269271 - 06/13/12 09:56 AM
WRAK
Reged: 02/18/12
Re: Do you measure double stars?? new [Re: chascar]
      #5269557 - 06/13/12 01:21 PM
Charles, quite interesting article - but I find the method described by Thomas G. Frey in his article "Visual Double Star Measurements with an Alt-Azimuth Telescope" in JDSO Spring 2008 (Thomas G. Frey "Visual Double Star Measurements with an Alt-Azimuth Telescope" in JDSO Spring 2008) quite easier and more comfortable as you need not even make a protractor assembly but use instead only the angle scale already available on the micrometer eyepiece.
Wilfried
Rutilus
Reged: 12/17/10
      #5341783 - 07/29/12 02:48 PM Attachment (44 downloads)
With all the cloud here over the last couple, I've been spending more time making astro stuff. Yesterday I made
a protractor assembly, took about an hour. Amazingly the sky was clear last night, so could not resist trying it out.
Spent about an hour calibrating, using Beta Cygni as a calibration star. Moved onto Gamma Del, to try my first
measure of the P.A. with this instrument. Took 30 readings, then moved back to Cygni to observe various objects,
before going back to Gamma Del and finally making another 10 readings.
Ended up with a P.A. average of 266-267 degrees. Quite pleased with the result, and I built it to add more interest
and enjoyment to my double star observing.
I used the instrument on my 120mm f/8.3 Achromat, also used was a 2x Barlow giving a power of 166x.
Some pictures below showing it on the scope in the observatory.
Rutilus
Reged: 12/17/10
Re: Do you measure double stars?? new [Re: Rutilus]
      #5341785 - 07/29/12 02:50 PM Attachment (41 downloads)
Another shot.
0 registered and 3 anonymous users are browsing this forum.
Moderator:  PJ Anway, Rich (RLTYS), rflinn68
