Privacy Policy | Please read our Terms of Service | Signup and Troubleshooting FAQ | Problems? PM a Red or a Green GuÖ uh, User
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | (show all)
Gord
Reged: 01/06/04
Loc: Toronto, ON, Canada
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: APM M.Ludes]
      #5599170 - 01/01/13 07:54 AM
Ugh. Happy New Year to you as well Markus!
Clear skies,
Ambiorix
Reged: 05/01/11
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: Richard Low]
      #5600962 - 01/02/13 10:30 AM
Richard, has allready been done by James ling,see refractor forum!
Doublet has no CA, but had softer image on jupiter's globe and not so good definition on the moons neither.....
Richard Low
Reged: 11/27/05
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: Ambiorix]
      #5601132 - 01/02/13 12:00 PM
Yes it is done...and I had also just posted my first impression in the refractor forum.
APM M.Ludes
Vendor (APM Telescopes)
Reged: 05/01/03
Loc: Germany
      #5601565 - 01/02/13 04:41 PM
Hi Richard,
363 x power in a 6" is simply to much power for any 6" , no matter how perfect it is, that is a exit pupille of 0.41 mm
Thatís aso called a empty power, thatís 60.5 power per inch
Worldclass manufacturers guarantee maximum 50 power per inch
If you take a FS 102 and a TSA 102 on Jupiter, and you gop up to about 150 power you will see that the FS 102 hold up perfectly to the much better colorcorrected TSA, but if you go to 200 or 250 power, you will notice that the FS 102 will brake down against the TSA due its lack of perfect CA, that is normal
So if you do such tests, please stay in the normal max power range and the normal max power range is 1.5 x of the aperture, but not more then 2 x aperture.
Overpower will make bad image
Would like to see the same review on Jupiter again with same stardiagonal and normal power for a low contrast object like Jupiter which is around 180 to 220 x...thats what I use max in worldclass 6" Apos
many thanks
Richard Low
Reged: 11/27/05
      #5601747 - 01/02/13 06:56 PM
Markus, thank you for your feedback.
After >36 years of observing here and elsewhere, I know what you meant, but that doesnt typically apply here. We usually have good seeing here that allows our 6" apo to give sharp planetary images above 350x. My 15" dob with Zambuto mirror regularly gets sharp planetary images at 450-600x. Thete was one occasion I had a wonderful view of Saturn sharp at 600x in a 6" apo on a night of exceptional seeing. I had viewed good Lunar image through my APM/LZOS 6" triplet at >1200x before.
So 363x for 6" apo is actually alright here.
t.r.
Reged: 02/14/08
Loc: Upstate NY
      #5602619 - 01/03/13 09:48 AM
I can testify to those seeing conditions...in Seoul S. Korea during summer I was able to run my 4" Genesis routinely to 260x on Jupiter and it wanted more! Ganymede looked like a marble transiting across the face! I'll never forget it.
APM M.Ludes
Reged: 05/01/03
Loc: Germany
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: t.r.]
      #5602689 - 01/03/13 10:29 AM
I also understand what you both mean, but such powers are called empty powers and per physics, all this powers doing is making the object bigger and reducing the visible details.
450 to 600 power in a 15" confirms the rule.
we have low contrast and high contrast objects. Satrun is a high contrast object, as well as Moon, but Jupiter with its great surface details is a low contrast object and low contrast objects should be observed also below the theoretical max power
so please do us the favour and when you have your next observation try Jupiter with the real good power between 180 and max 250 times and let us know what you see then
APM M.Ludes
Reged: 05/01/03
Loc: Germany
      #5602714 - 01/03/13 10:46 AM
The designer of our Chinese 152 ED can read on CN Refractor forum but not post there due his poor english , so he asked me to post here his comment regards the CA discussion in englisch.
Hallo Markus,
As I read on CN's it all about the color correction blue against red
Valery compares a doublet with a correction E-D-F (FH lines d and F have a common focus) with a doublet with the correction E-C-F and means the E-D-F correction is worse.
Both fixes are not ideal for visual observation after photopic (tags marriages) viewing.
Sensitivity tags marriages photopic in our eyes
F ... 18%
C ... 8%
Hence our optimized doublet has neither a correction E-D-F nor E-C-F correction but is seen for the photopic, exactly like it did when Massimo LZOS Doublet, which should also yield the best result on Jupiter.
May you write something for me or I write there but then you would have to translate the previously because as mentioned before my Englich too rough.
Greetings Gerd
Ambiorix
Reged: 05/01/11
      #5602785 - 01/03/13 11:31 AM
Yes Richard, unfortunately I have to agree (for once ) with Markus about the empty magnifications you where using!
Lichtenknecker optics always told me that the optimum magn. was around the diameter of the lens, which would be around 150X for your 6" ED. Off course opticss have changed for the best, so I would say that about 200X max. for Jupiter and perhaps about 225X for Saturn and moon, should be what you should use in a 6" refractor! I am not saying that, so it seems, under your extraterestrial seeing conditions, higher mags can't be used, but as Markus is saying they are completely useless, and will only show a bigger ball in the sky, but not more details. If you like big balls in the sky, use big glass down here:)
No, really, an exit pupil of 0,8mm on Jupiter is more than enough, and one of 0,7mm on Saturn, Mars and the moon is good to, but no more. And certainly not when testing two scopes against each other!
So, I would like to hear the verdict when you do the test over again, this time with normal magnifications of around 1mm to 0,7mm exit pupils....I think the difference will be less noticable.
I cannot believe that I am defending Ludes here, usually we fight together all the time, but when he's right he's right
Alvan Clark
Reged: 03/13/10
      #5603274 - 01/03/13 03:56 PM
I disagree. Like enlarging an image on a computer, You don't gain any detail if you keep enlarging it. Just makes what is there easier to see. You don't lose any though if you keep making it bigger. The same amount of information is still there.
In the case of a telescope you may lose detail at some point because it's "seeing" limited. The quality of the seeing would determine that point.
APM M.Ludes
Reged: 05/01/03
Loc: Germany
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: Alvan Clark]
      #5604005 - 01/04/13 02:07 AM
Hi Alvan
if I make a picture on the computer much bigger, it start showing less due the pixels, nothing else happens on the telescope if you make the picture to big you loose details.
The word Loose is maybe wrong you are right, because you do not really loose something , it is still there and if you make it smaller again it is there, so what you do is you wash out the picture or spell it any other way, in any case you see less if you oversize it
Ambiorix
Reged: 05/01/11
      #5604989 - 01/04/13 03:03 PM
Yep, I can't believe what is happening, but once again I must agree 100% with Markus here
If this continues we might even become good mates
And Alvan, let's be honest here, do you really like the darkness of an exit pupil of little more than 0,4mm?
I don't, that's for shure. Even 0,5mm is much too dark for my likings!
Live_Steam_Mad
Reged: 07/24/07
Loc: Moss Bank, St.Helens, England
      #5605090 - 01/04/13 04:02 PM
Interesting to hear someone mention that the very small exit pupil is darker, a thing that I had not noticed before myself.
BUT I have noticed that 0.5mm exit pupil on any 'scope that I try really is not great for me because it shows up the floaters and cells in the back of my eye quite noticeably and it interferes with the view I get of Jupiter.
So I would want a 1mm exit pupil at the smallest, preferably (personally).
As a side note, an exit pupil of 4mm shows the astigmatism that I have in my own eyes really badly (small-ish but very noticeable crosses on the brighter stars on M45 for example), even when I have my spectacles on (probably because my prescription is 3 years old and I am starting to need new glasses since my astig. has probably got worse, I already had 3.0 diopteres (severe) of astig. in my right / observing eye, which my glasses don't appear to fully compensate for). At this point I could really use an eye test and a Dioptrx lens for my 32mm TeleVue Plossl...
And I can't use my left eye, since that's even worse at 3.5 diopteres of astig...
Alistair G.
Edited by Live_Steam_Mad (01/04/13 04:05 PM)
faackanders2
Reged: 03/28/11
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: Vondragonnoggin]
      #5607318 - 01/05/13 09:23 PM
Markus, you are the best for getting this going! Can't wait to see the offerings!
(on a side note - any newer news on that apo BT with 90 degree oculars?)
No pressure. Still patiently waiting.
Would these be similar to the big binos, or an all new binocular telescope?
APM M.Ludes
Reged: 05/01/03
Loc: Germany
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: faackanders2]
      #5607907 - 01/06/13 08:47 AM
the Apo Binos will be real binoculars , they still working on them, going slowly, but they will come for shure, no vapour, maybe a few more monthes
Live_Steam_Mad
Reged: 07/24/07
      #5608446 - 01/06/13 01:56 PM
Any chance of creating binoculars which are Dioptrx compatible? and / or where you can change eyepieces? With 50mm aperture? I wish TeleVue would do some. But I can't contact them, they have no e-mail.
Alistair G.
Edited by Live_Steam_Mad (01/06/13 02:08 PM)
APM M.Ludes
Reged: 05/01/03
Loc: Germany
Re: New 6" F/8 ED Doublets from APM Telescopes new [Re: Live_Steam_Mad]
      #5608499 - 01/06/13 02:14 PM
50 mm ? , what sense does it make ?
Live_Steam_Mad
Reged: 07/24/07
      #5608973 - 01/06/13 06:11 PM
OK, first I started off by using my late father's 10x50 Pentax bino's and the views were awesome - before my Brother used bog roll (toilet paper) to clean the lenses (doah!) and scratched the coatings to hell
Then it didn't help that as a teenager I dropped the bino's onto solid concrete several times by accident... and it ruined the view
...however later on in life I bought a pair of Nikon 8-24x25 Travelite V binos for use with Astronomy (don't be too quick to judge) (because they were lightweight, the Pentax bino's were 1,200 grams!), and although the performance at 8x was not incredible, it was still very high contrast and sharp on axis, and at the high end of the magnification range the correction at the edges improved dramatically and the field expanded hugely and it hugely REDUCED that horrible orange glow as I zoomed in (as it darkened the background sky) so that on one night whilst looking at the Double Cluster being just about overhead and filling the view, and seeing diamonds against dark velvet, and being mesmerised, I realised I was getting hooked on zoom binoculars
And then I started to want more aperture... but they get heavy really quickly, and 40mm Nikon bino's are heavy (as heavy as the Pentax 10x50).
So I was looking for a pair with say 8-20 (zoom) x 50mm aperture, carbon fibre body like the Nikon's I have for lightweight, and then I WANT TO BE ABLE TO TAKE OFF MY GLASSES when using the bino's as I have severe astigmatism and using my glasses all the time with 'scopes / bino's sucks
So I thought, what if you could have Dioptrx compatible bino's (surely I can't be the only person that has thought of this - how many people are there with significant astigmatism...) and get a sharp view and be able to zoom in and darken the sky (the Ethos versus Plossl argument, the "majesty factor" as Uncle Al puts it), and with a pair of bino's that are say 1Kg max. Hell I'd buy them.
Alistair G.
Edited by Live_Steam_Mad (01/06/13 06:14 PM)
APM M.Ludes
Reged: 05/01/03
Loc: Germany
      #5609676 - 01/07/13 06:40 AM
for such a special binocular you need to order minimum 500 pc or 1000 pc and prepay , otherwise nobody would it and who will buy so many ? Therefore I am not going such way, sorry
Live_Steam_Mad
Reged: 07/24/07
      #5610137 - 01/07/13 12:29 PM
Couldn't some company just make a binocular to be Dioptrx compatible (i.e. with that ring around the eyepiece tops like the Televue eyepieces have), I mean, how hard can it be?!
Alistair G.
2 registered and 8 anonymous users are browsing this forum.
