Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | (show all)
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: totolesbaloches]
      #5253563 - 06/03/12 03:36 PM
Version 1.00.19 update : http://www.felopaul.com/software.htm
i add :
- fix bug Pinpoint
- add new taget for Bias/Flat/Dark (with vbs script on start/stop session)
Edited by totolesbaloches (06/04/12 05:50 PM)
totolesbaloches
Reged: 08/22/08
Loc: France
      #5255070 - 06/04/12 05:54 PM
Version 1.00.20 update : http://www.felopaul.com/software.htm
i add :
- fix bug autostart
- fix bug focus with MaximDl
- add new Focus target, before a focus, goto this special target, after focus, come back and make a Pinpoint
Edited by totolesbaloches (06/06/12 03:41 PM)
totolesbaloches
Reged: 08/22/08
Loc: France
      #5258573 - 06/06/12 03:44 PM
Version 1.00.21 update : http://www.felopaul.com/software.htm
I add :
- park with goto to a selected target (for mount without park mode)
- Focus avable with camera 1 or 2 (with offset if use camera 2)
WARNING: You must start Focusmax with the camera desired check, otherwise Focusmax will return an error when the focus.
Update manual
totolesbaloches
Reged: 08/22/08
Loc: France
      #5268675 - 06/12/12 08:11 PM
I find some probleme if you forget to vrite all parameter
so i put for each parameters i put limite, maxi, mini, scale ...
I developp new soft MaxCCD it's include in this update but you can not use on this time.
Version 2.00.01 Update : http://www.felopaul.com/software.htm
totolesbaloches
Reged: 08/22/08
Loc: France
      #5271745 - 06/14/12 06:46 PM
New Update
Version 2.00.04 Update : http://www.felopaul.com/software.htm
- fix bug T° Up and down
- fix bug Remap
- add for cloudwatcher mode suspend (park all, wait cloud exit, restart all=
totolesbaloches
Reged: 08/22/08
Loc: France
      #5278549 - 06/19/12 10:27 AM
New Update
Version 2.00.07 Update : http://www.felopaul.com/software.htm
I add:
- Add new button for automatic Update
- optimise for AO7 use
- fix bug script VBS and offset sart session
totolesbaloches
Reged: 08/22/08
Loc: France
      #5282864 - 06/21/12 08:31 PM
Version 2.00.08
Update for SBIG camera with chip inside :
Change Filter before start Guiding/Calibrate
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5288415 - 06/25/12 01:22 PM
Laurent, your product is amazing. Thanks again!
lawrie
Reged: 01/31/06
Loc: Okanagan Valley
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: Raginar]
      #5288862 - 06/25/12 06:08 PM
Does it work with pinpoint le in Maxim?
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: lawrie]
      #5288918 - 06/25/12 06:35 PM
No, pinpoint LE can not be ordered by extrenal soft
you need pay version
shurik
Reged: 10/07/07
      #5288928 - 06/25/12 06:42 PM
Looks like an excellent software. I have some specific questions:
1. Is it possible to integrate with Cartes du Ciel not just the Sky for mount control
2. Can I schedule to park the mount at certain time unattended, and turn off cooler on the camera
Thanks! Alex
korborh
Reged: 01/29/11
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: shurik]
      #5289306 - 06/25/12 10:53 PM
Laurent, thanks for your efforts and making this software available to the astro community
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... new [Re: korborh]
      #5289514 - 06/26/12 03:14 AM
Thank you !
Alex, i maked a mail to "Cartes du Ciel", and ask who manage this soft. if possible i will do use it.
Yes Maxpilote park the mount et turn off cemera on end of session. see the pdf manual.
totolesbaloches
Reged: 08/22/08
Loc: France
      #5290677 - 06/26/12 08:48 PM
New update V2.00.10 Update : http://www.felopaul.com/software.htm
- Pinpoint before focus if you use a focus target
- new check for park scope on start (before open dome)
- optimise for AO7
- fix bug pinpoint exposure
shurik
Reged: 10/07/07
      #5290720 - 06/26/12 09:26 PM
Excellent, thank you Laurent. I found the parking option too.
I am guiding with SBIG AO-8 and I am still a bit confused about the sequence of operation with MaxPilote:
I usually setup everything in Maxim Dl (guider-mount calibration and mirror of AO-8 calibration), when do I connect to MaxPilote before or after I start guiding the star?
Also when I finish the session and select "close all soft" option does it turn off the cooler of my cam? if not can this option be selected?
thank you, Alex
totolesbaloches
Reged: 08/22/08
Loc: France
      #5291110 - 06/27/12 04:57 AM
For AO, the miror calibration can not be manage my external software, so you just have to do this one time, after if you don't change optic , you don't have do it.
MaxPilote automatique ask mout calibration and start autoguide session. Between each exposure, put the start in center with ST4 port and home the AO miror.
For you ccd, yes you have option, to start the cooler on begin, and stop on end :
Marke
Reged: 11/28/09
      #5294124 - 06/28/12 11:06 PM
Dont know if I missed something but I cant connect to SkyX pro ? Keeps telling me skymap connect fail.
Mark
totolesbaloches
Reged: 08/22/08
Loc: France
Re: MaxPilote: Software to manage Maxim DL/FocusMax... [Re: Marke]
      #5294353 - 06/29/12 04:36 AM
i thing, it's because TheskyX can not connect the scope.
If it's to test, usa simunlator telescope in theskyX
Good remarque, i put message in my soft
thank you
Marke
Reged: 11/28/09
Re: MaxPilote: Software to manage Maxim DL/FocusMax... [Re: totolesbaloches]
      #5294359 - 06/29/12 04:58 AM
Well I have been running the scope with the skyx and maxim together no problem ?
Marke
Reged: 11/28/09
      #5294363 - 06/29/12 05:01 AM
Ok tested again will work if I run skyX first and connect to scope but if its not already running Maxpilote wont connect.
20 registered and 15 anonymous users are browsing this forum.
Moderator:  Oldfield, bilgebay
