Telescope Specific Forums >> NexStar GPS / CPC Telescopes
Gastrol
Reged: 11/04/11
Loc: los angeles
Beer as counterweight?
      #5225920 - 05/16/12 09:17 PM Attachment (72 downloads)
Just curious, has anyone ever used beer as counterweight? I found that the stock 50mm finderscope bracket holds the bottle securely. Only problem is is that it's just not heavy enough so I plan on replacing the Dos Equis bottle with a short iron pipe of the same diameter and fill it ballast.
Monadnock
Reged: 04/24/12
Loc: SW NH
Re: Beer as counterweight? new [Re: Gastrol]
      #5225942 - 05/16/12 10:14 PM
I don't always use beer as a counterweight, but when I do, I prefer Dos Equis.
Stay balanced, my friends.
Pegdragger
Reged: 05/01/10
Loc: Johnson City, TN
Re: Beer as counterweight? new [Re: Monadnock]
      #5225956 - 05/16/12 10:24 PM
KDizzle
Reged: 09/12/08
Loc: Woodinville, WA
Re: Beer as counterweight? new [Re: Pegdragger]
      #5225961 - 05/16/12 10:27 PM
I'm KDizzle and I approve this message.
Darren Bly
Reged: 07/24/06
Loc: Bakersfield, Ca
Re: Beer as counterweight? new [Re: KDizzle]
      #5225974 - 05/16/12 10:35 PM
For me it would a "variable" counterweight.
Brian A
Reged: 03/16/06
Re: Beer as counterweight? new [Re: Darren Bly]
      #5226287 - 05/17/12 06:19 AM
I tried it with Miller Lite but it wasn't heavy enough.
Yeah I know, bad...
JoeR
Reged: 03/07/10
Loc: Columbus, OH
Re: Beer as counterweight? new [Re: Brian A]
      #5226322 - 05/17/12 07:21 AM
No, considering beer usually causes me to lose my equilibrium it's probably not good for the scope too.
Larry F
Reged: 05/24/04
Loc: Westchester, NY
Re: Beer as counterweight? new [Re: JoeR]
      #5226477 - 05/17/12 09:52 AM
The Large Binocular Telescope on Mt. Graham, the largest single instrument in the world, has a system of conduits that flow ethylene glycol to various parts of the scope to dynamically balance it. That allows the 570-metric-ton scope to be moved with four 3-hp motors and always remain in exquisite balance, with fantastic pointing and tracking accuracy.
This suggests a similar dynamical balancing scheme with the CPC. The on-scope beer reservoir is connected on one end to a keg which feeds the reservoir via a motorized impeller and valve that are actuated by signals from a balance sensor on the scope. On the back end of the reservoir there's a flexible tube. When you switch eyepieces or other equipment and need to lighten the front end, the balance sensor sets off an alarm that tells you to suck some beer out of the tube and swallow it. Perhaps the alarm can be in the form of a digital .wav file that says "Chug! Chug! Chug!" until you reach the desired balance. When you put back the heavier eyepiece, the sensor/motor combination senses the imbalance and refills the reservoir with just the right amount of liquid.
This tends to be self-correcting. The more times you switch equipment, the more chugging you will do, the more blotto you will get and therefore the less capable you will be to change anything, so the number of refill cycles will decrease. You will maintain both scope balance and a substantial but hopefully pleasant beer-infused state.
James Cunningham
Reged: 08/07/10
Loc: Maryland
      #5226481 - 05/17/12 09:56 AM
Why not drink the beer and then put lead shotgun shell pellets in the empty bottle to get the right weight?
astrovienna
Reged: 12/04/06
Loc: The NoVa White Zone
Re: Beer as counterweight? new [Re: James Cunningham]
      #5226527 - 05/17/12 10:25 AM
No, but I hear that Uncle Rod occasionally uses Rebel Yell to keep himself balanced.
(Come on, Rod, you're going to pass up this thread? )
Kevin
      #5226554 - 05/17/12 10:42 AM
Stay thirsty, my friend!
- Jim
rboe
Reged: 03/16/02
Loc: Phx, AZ
Re: Beer as counterweight? new [Re: jrbarnett]
      #5226560 - 05/17/12 10:45 AM
I've seen this used quite a bit in the field but only to the viewer/astronomer. Many lament the fact that they now have this counter weight and can't remove it.
Applying it to the scope would seem to be a better idea; until it got cold.
HeyJP
Reged: 12/11/10
Loc: Boulder, CO
Re: Beer as counterweight? new [Re: rboe]
      #5227027 - 05/17/12 03:33 PM
That would work perfect as a progression through the night. As you drink your counterweight you move from Panoptics thru Naglers to the Plossl eyepieces. Keeps the balance in play.
Digital Don
Reged: 01/20/04
Loc: Manteno, IL
      #5227356 - 05/17/12 08:06 PM
If you believe their commercials, with Dos Equis, the stars will be watching YOU!
Don
Gastrol
Reged: 11/04/11
Loc: los angeles
Re: Beer as counterweight? new [Re: Digital Don]
      #5264662 - 06/10/12 12:23 PM Attachment (40 downloads)
I needed something heavier than beer so replaced it with a 2" drain pipe filled with sand.
yonkrz
Reged: 11/16/06
Loc: SW Minnesota
      #5265128 - 06/10/12 06:12 PM
Clever idea,although i do like the beer idea.
Rich56
Reged: 06/02/12
Re: Beer as counterweight? new [Re: yonkrz]
      #5266062 - 06/11/12 10:38 AM
This post inspired me to add a few thoughts of my own here...
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5266057/page/0/view/collapsed/sb/5/o/all/fpart/1
I do hope the moderators don't mind a bit of humor on these Forums.
Rich
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5266852 - 06/11/12 06:11 PM
I balance with Jameson.
Greg K.Administrator
Reged: 12/11/03
Loc: Clifton Park, NY
      #5266855 - 06/11/12 06:12 PM
Gastrol
Reged: 11/04/11
Loc: los angeles
Re: Beer as counterweight? UPDATE new [Re: Greg K.]
      #5297772 - 07/01/12 11:56 AM Attachment (15 downloads)
No more finderscope bracket, beer, and sand filled drain pipe. I needed a bit more adjustability.
I've seen a couple people use T-tracks so I decided to do the same. I used a pair of Losmandy radius blocks to center mount the T-track. And that's a 3 lb dumbbell plate.
Balance at zenith is a little off.....I can use a lighter plate and move it further up the track to achieve better balance at zenith.
Gastrol
Reged: 11/04/11
Loc: los angeles
Re: Beer as counterweight? UPDATE new [Re: Gastrol]
      #5297774 - 07/01/12 11:57 AM Attachment (47 downloads)
another view
Astroegg
journeyman
Reged: 01/21/11
      #5379819 - 08/21/12 05:58 PM
Honestly, when I first saw your beer bottle counter weight I just assumed you had created a very expensive beer pouring device - I wouldn't be able to resist lying under the scope whilst using the hand controller to pour beer down my throat!
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
Re: Beer as counterweight? UPDATE new [Re: Astroegg]
      #5379878 - 08/21/12 06:54 PM
Ahhh.....the good old days!
tomnjulie
Reged: 12/04/12
Loc: Texas
      #5620162 - 01/13/13 03:26 AM
I'm gonna do the lead shot and seal the bottle with candle wax.
barbarosa
Reged: 04/11/10
Loc: "lamorinda", CA
      #5628925 - 01/17/13 09:32 PM
Cloudy weather or clear,
pale ale or bock beer,
A CPC pours us good cheer.
Indoors or out,
Porter or stout,
Its a fine mount,
you can't do without.
2 registered and 3 anonymous users are browsing this forum.
Moderator:  BRisley
