Stellarfire
Reged: 07/10/11
Loc: Switzerland
Re: Poll: TAK TOA 170, 175 or 180mm?
[Re: Astrojensen]
#5236087 - 05/23/12 05:06 PM
Thomas,
Are those big Aries APO refractor tubes made from aluminium? I am asking this, because aluminium, being a poor isolator, tracks with the outdoor ambient temperature much quicker than tubes made from phenolic resin / Kruppax 50. Therefore, thermal equilibrium of a closed OTA is reached faster with an aluminium tube. I think this is particularly important on big and voluminous refractor OTA's.
TAK uses aluminium for its massive refractor tubes.
Stephan
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
[Re: Stellarfire]
#5236109 - 05/23/12 05:20 PM
Hmm. I think it was aluminum, yes, but I can't remember for sure. Ask Markus Ludes, he's the retailer of these scopes.
And you're right on the money about the cooling issues.
Clear skies! Thomas, Denmark
Stellarfire
Reged: 07/10/11
Loc: Switzerland
[Re: Astrojensen]
#5236152 - 05/23/12 05:55 PM
I guess we will see his post on here soon.
Stephan
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
[Re: Stellarfire]
#5236229 - 05/23/12 06:45 PM
The other part of the equation is that whichever part of the tube is sky facing will, on a clear night, be colder than the part of the tube which is ground facing. If the tube material is a good conductor this will cause tube currents. The best thing to do, without any doubt at all, is to have an insulating tube, with adequate vents for cooling, which can be closed when in use.
Wooden tubes are excellent in many respects. Carbon fibre is a reasonable insulator & works well. If you're unfortunate enough to have a conductive metal tube, paint it white or have it polished metal finish and line it with cork or sytrofoam.
gnowellsct
Reged: 06/24/09
Re: Future TAK TOA: What would you like to see?
[Re: tmbuser6]
#5236511 - 05/23/12 10:56 PM
They make 'em now, Greg--- it's called a NEWTONIAN!
Except for the increase in quality.
I don't know. Newts are pretty cumbersome and long. I don't know how the weight would pan out between a ten inch Newt and a ten inch apo. Of course, much would depend on the design choices. But I do have a very nice 10" Newt.
Greg N
PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
[Re: gnowellsct]
#5237433 - 05/24/12 02:26 PM
FSQ175EDX that works with the current .76 reducer. Make the tube from a thermally stable material and ventilate it to control the wild focus change of the 106.
Stellarfire
Reged: 07/10/11
Loc: Switzerland
[Re: Ennis]
#5243630 - 05/28/12 11:06 AM
The TOA line is getting a bit old, too. Maybe the TSA line will supersede it.
Yes, maybe. According the homepage of Takahashi Japan, the TOA-130 was introduced in January 2003, and the TOA-150 in July 2005.
But, frankly, I think there is no such thing as "getting old" for a fantastic product line as the TOA. It is a timeless monument of industrial art.
Stephan
Ennis
Reged: 09/11/06
Loc: The Outer Limits
[Re: Stellarfire]
#5243683 - 05/28/12 11:32 AM
"I think there is no such thing as "getting old" for a fantastic product line as the TOA."
I agree.
E.
Edited by Ennis (05/28/12 11:28 PM)
daveCollins
Reged: 05/06/11
Loc: Washington DC
[Re: Ennis]
#5244509 - 05/28/12 07:12 PM
I haven't found its weight to be too much of a problem. I removed the tube weight, rings, and and diagonal and the scope weighed in at 31 pounds.
aa6ww
Reged: 10/23/11
Loc: Sacramento, Calif.
[Re: daveCollins]
#5244619 - 05/28/12 08:23 PM
My TOA-130 weights 35 pounds with the clamshell, D-type dove tail and accessory ring and its a featherweight to put on my G11. Funny how many read spec sheets only instead of talking to users on how much their scopes really weight. The 150 is awesome!!
...Ralph
daveCollins
Reged: 05/06/11
Loc: Washington DC
[Re: aa6ww]
#5244640 - 05/28/12 08:41 PM
I just got in from viewing the moon. I have the TOA 150B mounted on a Universal Astronomics Unistar Delux Alt-Az manual mount and I was using 297 power to identify the Apollo 15 landing site. This mount is rated for 30 pounds and it worked just fine. In broad daylight (7pm to 8:30pm) I could easily see Rimea Fresnel and Mons Hadley and use them to then jump over to Apollo 15 site. I don't think this scope is the monster that it is made out to be.
Ennis
Reged: 09/11/06
[Re: aa6ww]
#5244889 - 05/28/12 11:20 PM
The folks at Texas Nautical Repair, the Takahashi distributor in Houston, have warned me that the TOA-150 was too heavy for a G-11 mount even just for visual work, and I won't bother with a mount bigger than a G-11. The TOA-130, on the other hand, is not too heavy for a G-11.
If I could look through a TOA-150, I might be convinced to buy one -- but I have never seen any TOA refractor at any star party that I have attended.
E.
Edited by Ennis (05/29/12 09:28 AM)
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
[Re: Ennis]
#5245048 - 05/29/12 02:05 AM
As one who has had equipment damaged by rough usage at public events, if I had something as good as a TOA frac, I wouldn't take it either. I'm happy to take cheap & easily replacable scopes to public events, if they do get damaged it's no biggie to repair or replace them.
MAURITS
Reged: 09/22/09
Loc: Diksmuide (Belgium)
[Re: brianb11213]
#5245079 - 05/29/12 03:12 AM
The TOA-150B is "extraordinarily"
YES, it's made for a "lifetime"!
NO, it's not a "monsterscope"!
Stellarfire
Reged: 07/10/11
Loc: Switzerland
[Re: saemark30]
#5249018 - 05/31/12 02:48 PM
I wonder if fluorite is still made larger than 175mm?
Apparently yes. The Observatory FET-200 200mm f/10 Triplet Fluorite/ED Telescope is still available from TAK. There is also offered a FET-250 and FET-300 model, with Fluorite element, too.
The Observatory FET-200 being the next step up from the TOA-150, results in a big gap between both refractor models.
Stephan
chboss
Reged: 03/24/08
Loc: Tokyo Japan
[Re: Stellarfire]
#5249700 - 05/31/12 10:53 PM
Stephan
If I understand correctly those scopes you mention are made to order so certainly not available from stock? And the price point of these models is extreme...
The question is really at what price a 170mm or 175mm lens could be "mass" produced.
regards Chris
Stellarfire
Reged: 07/10/11
Loc: Switzerland
[Re: chboss]
#5249934 - 06/01/12 02:34 AM
Stephan
Chris,
That is correct. But it is impressive that TAK offers them with Fluorite lenses that large.
regards
Chris
The Dealer Minimum Advertised Pricing (MAP) lists the TOA-150B at USD $ 10,895.00 (Texas Nautical / TAK America), respectively EUR 11,952.00 (Optique Unterlinden / TAK Europe.
In the high-end APO refractor market, prices definitely go through the roof for anything larger than a 6 incher. This is still a small market segment. In view of high labour cost and small production numbers, I would expect a price tag of at least USD $ 20'000.00 for a 175-180mm TOA.
Stephan
Stellarfire
Reged: 07/10/11
Loc: Switzerland
[Re: daveCollins]
#5255606 - 06/05/12 01:59 AM
In particular the intelligently placed and solid carry-handle helps a LOT to control the expensive TOA-150B OTA during set-up and break-down.
Stephan
Alvin Huey
Reged: 10/18/05
Loc: NorCal
[Re: Ennis]
#5284795 - 06/23/12 03:33 AM
E.
Really? I've mounted my TOA-150 on my friend's G-11 and it was fine for visual use...but for imaging - forget about it. That thing weighs 45 pounds!
Ennis
Reged: 09/11/06
[Re: Alvin Huey]
#5285207 - 06/23/12 12:23 PM
Thank you! That is good to know!
E.
