Privacy Policy |
Please read our Terms
of Service | Signup and
langejcarl
Reged: 01/05/05
Loc: Michigan USA
Microscope EP's
#5247113 - 05/30/12 11:05 AM
Will a .965 to 1.25 inch compression ring adapter work ok with microscope eyepieces with 23.2mm barrels? Will there be too much "play"?
tomcody
Reged: 07/06/08
Loc: Titusville, Florida
Re: Microscope EP's
[Re: langejcarl]
#5247176 - 05/30/12 11:59 AM
You might check out this article: http://www.cloudynights.com/item.php?item_id=365 Rex
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
Re: Microscope EP's
[Re: langejcarl]
#5247327 - 05/30/12 01:45 PM
There will be too much play. 0.965" is 24.5mm. You can build up the barrel of the eyepiece with a bit of ordinary household tape. This can work well, if done carefully.
Clear skies! Thomas, Denmark
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
Re: Microscope EP's
[Re: Astrojensen]
#5261170 - 06/08/12 12:06 AM
Use metallic duct tape. Cut the tape into strips to fit the length of the eyepiece barrel. I've built up the barrel of microscope eyepieces with good results in this way. It is very durable and looks good.
Mike B
Starstruck
Reged: 04/06/05
Loc: shake, rattle, & roll, CA
Re: Microscope EP's
[Re: Sarkikos]
#5269854 - 06/13/12 04:07 PM Attachment (52 downloads)
Have done this, to great effect! But be forewarned- it definitely has a "home-brew" effect, which will make selling the EPs in the future (should you ever decide to try ) a challenge.
Another trick i've used is to find a couple of those old-style 35mm plastic film canisters, and cut their barrel bottom-ends as required to suit. In the photo below, the micro-barrels fit into the "sleeves" perfectly to the hilt, and they snug into my BVer's collets like they were made for it! A li'l double-stick tape inside ensures the EPs *stay* in the sleeves. 'Tis a very "clean" solution!
Doug Culbertson
Reged: 01/06/05
Re: Microscope EP's
[Re: Mike B]
#5269858 - 06/13/12 04:12 PM
Elegant and low cost; nice!
Mike B
Starstruck
Reged: 04/06/05
Re: Microscope EP's
[Re: Doug Culbertson]
#5269890 - 06/13/12 04:39 PM
The frugality doesn't end there, either. The eyeguards are Starman inspired... bike innertube segments, doubled over & fitted onto the barrels- adjust to height desired. A humble fix, fersure, but works really well.
Loren Toole
Reged: 03/23/04
Loc: New Mexico USA
Re: Microscope EP's
[Re: Mike B]
#5272064 - 06/14/12 10:43 PM
I've discovered by accident that ordinary kid's posterboard cut into strips will fill the gap in 0.965-1.25" adapters, if carefully wrapped around the eyepiece with no overlap. I use a pair of 20x (12.5 mm) microscope eyepieces in my Baader Maxbright, wrapped in posterboard, alignment is perfect.
Sarkikos
Reged: 12/18/07
Re: Microscope EP's
[Re: Mike B]
#5277260 - 06/18/12 02:53 PM
Mike B,
Having never sold an eyepiece, the thought of resale value never crosses my mind! My prime motivation is a fix that works well. Some of the best improvements to my scopes and accessories have involved black foam core, Velcro, foam sheeting, wire screen and Gorilla Glue.
The metallic duct tape works very well. I doubt very much if anything works better, short of hiring a machinist for beaucoup d'argent. To me, the metallic tape looks good, too.
I suppose if I were to sell an eyepice that was taped, it wouldn't be difficult to remove and clean up with Goo Gone.
5 registered and 7 anonymous users are browsing this forum.
Moderator: Geo557, panhard
