tim53
Reged: 12/17/04
Loc: Highland Park, CA
Re: Building a wood Tube new [Re: Pinbout]
      #5276365 - 06/17/12 11:43 PM
The scrap stuff I tested in the 5" cardboard tube handled it okay, though it's relaxed to more like 12" diameter now that it's dry. It must be glued with waterproof glue, because I got no delamination at all.
I have no clue about the 4x8 sheet though.
-Tim.
astrobeast1
Reged: 09/28/10
Loc: leicester england
Re: Building a wood Tube [Re: tim53]
      #5276608 - 06/18/12 05:26 AM Attachment (20 downloads)
Hi all,
I found this thread fascinating with all the different methods used, thanks everyone.
Some of you may have seen my attempt at making a 635mm hexadecagon (16 sided ) plywood binoscope.My album will show more pics of the build, a lot of the ideas were gleaned from this forum, so many thanks for them.I,m at the mirror making stage at mo. regards Dan
Edited by astrobeast1 (06/18/12 05:32 AM)
tim53
Reged: 12/17/04
Re: Building a wood Tube new [Re: astrobeast1]
      #5276906 - 06/18/12 10:52 AM
Looks impressive, Dan!
One of the reasons I'm considering a round tube this time is that I mount my scopes (so far) on GEMs, and so I need them to rotate. My 10" tube rotates okay, but getting the rings mounted to the 9-sided tube tightly has been frustrating, since the tube isn't a perfect nonagon and varies in trueness.
So, I was thinking it would be easier to make a round tube by making a form that doubles as bulkheads/baffles after the tube is finished, and building the tube around that (or inside inner rotating rings and end rings, perhaps).
I suppose the same strategy could be used in making a polygonal tube as well, like plyscope does or I did for my 6" f/15 Jaegers:
or the 8" Springfield I built 30 years ago:
Neither of those tubes need to rotate, though. And when I was finishing them, I trimmed the last couple of sides to take up some propagating errors that came along as the layup progressed. For a rotating polygonal tube, then, I could make the inner rotating ring halves double as forms for fitting the plywood sides inside them, and make adjustments in the side widths as I go.
I suppose either tube type will give the same problems with that last seam (with the polygon) or the butt joint (for the rolled tube). But at least, from the get-go I'd have the basis for a rotating tube built into the tube. (I'd have to approximate the final balance point, and/or provide for a tube weight system - which is desirable in a rotating tube anyway).
I left out coopering inside the rotating rings and end rings. That might be even easier to do than rolling plywood or polygonal tubes.
A year or so ago, I'd bought this absolutely beautiful 2x7" by 66" Cherry plank, with stunning figure. But it's not long enough for the 8" f/9! So if I do a coopered tube, I'll need to find another stick! Probably about 7 feet long... ...or make the tube in sections, like Royce describes.
-Tim.
hickeydp
Reged: 06/14/09
Loc: Ireland
Re: Building a wood Tube new [Re: tim53]
      #5276953 - 06/18/12 11:18 AM
Hi Tim,
I'm planning something very similar to what you've suggested above. I have a carpenter friend that I have been talking to about this and he has suggested cutting out circular baffles from marine ply, bracing them and then wrapping it in a 3mm flex-ply. I'm looking to house a 16" f5 newt in this and he's confident that the tube will be stable enough.
Hoping to start the initial work this week.
rboe
Reged: 03/16/02
Loc: Phx, AZ
      #5276963 - 06/18/12 11:26 AM
Velcro strapps make good strapping clamps (as well as surgical hose) as long as glue is not involved.
1 registered and 17 anonymous users are browsing this forum.
