azure1961p
Reged: 01/17/09
Loc: USA
Porrimas Albireo effect
#5276368 - 06/17/12 11:46 PM
I had a really terrific view of Porrima for the first time. Other times the seeing was 3-4/10 Pickering. Finally I get 7/10 withy my 70mm and I swung it onto this double.
I know what the books say - identical F spectrum stars. What seemed persistent - even beautiful however was the fact that one seemed yellow the other a cold white or very light blue. I investigated this online and found it was a case of atmospheric dispersion. Its hard to believe though. The colors seemed to natural.
Anyone else see this discrepency ever?
Pete
PS: Im 51 -I finally get a night thats good and clear for this double. The majority of my doubles observed however are from Vulpecula to Polaris as luck would have it I often always ended up with poor southern exposure no matter where I lived. Its got and upside as there are so many doubles now that Im only starting to see.
Edited by azure1961p (06/17/12 11:47 PM)
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
Re: Porrimas Albireo effect
[Re: azure1961p]
#5276522 - 06/18/12 02:40 AM
Pete
In my 4 inch f/6 refractor a few weeks ago, the double was well resolved and both stars looked almost identical (an off-white color). They also look like that in my 9.25 inch SCT, although in that scope, they are more of a pure white color. Clear skies to you.
RLTYS
Reged: 12/18/04
Loc: New York (Long Island)
[Re: azure1961p]
#5276623 - 06/18/12 06:15 AM
Observations with my 10" refl have shown the colors of Porrimas to be the same, bluish wht. I've had a similar experience with Gamma Del where the spectrum of both components are the same, so they should appear the same color but instead they appear pale yellow and greenish blue. You might want to check this star out.
Rich (RLTYS)
blb
Reged: 11/25/05
Loc: Piedmont NC
[Re: RLTYS]
#5276847 - 06/18/12 10:19 AM
Pete, I looked at Porrima, y Vir, STF 1670 last month with my 5-inch ETX 125, using a 7mm eyepiece at 271x. The stars were two equal magnitude off white stars seperated by a thin black line (Sep. = 1.6 seconds). I did not see any color differences in the stars but was very happy to split them, my closest pair split yet.
Rutilus
Reged: 12/17/10
[Re: blb]
#5277278 - 06/18/12 03:07 PM Attachment (44 downloads)
This is the view I had with my 6 inch Achromat fitted with a 100mm aperture mask. In my notes I wrote that both stars appeared off white/cream in colour. One of the stars appeared slightly darker than the other.
WRAK
Reged: 02/18/12
[Re: Rutilus]
#5277524 - 06/18/12 06:18 PM
This season I have missed most of the double stars in Virgo due to bad weather but in my notes from last year I found the remark "120mm refractor: Two white suns of similar size, clear split". Wilfried
Astrodj
Reged: 08/24/11
Loc: Missouri
[Re: WRAK]
#5277627 - 06/18/12 07:32 PM
Pete,
Last month I observed Porrima and did not note any yellow tints, but I did see an apparent color variation of sorts.
Here are my notes from May 10th of this year:
Gamma Virginis (Porrima) Date: 5/20/12 Time: 0238 UTC Seeing: 6 of 10 (Pickering) Transparency: 5 Instrument: XT10 Magnification: 150x Notes: Just split with a dark line between the components. Primary is pure white in color; the companion appears white with a blue tint.
azure1961p
Reged: 01/17/09
Loc: USA
[Re: Astrodj]
#5277878 - 06/18/12 10:10 PM
Here is an EXACT color ccd image of Porrima - its an atmospheric dispersion effect. Amazing.
http://www.astropix.com/HTML/SHOW_DIG/Porrima_Gamma_Virginis.HTM
Rich, nice rendering.
Thanks guys for the reply.
Pete
azure1961p
Reged: 01/17/09
Loc: USA
[Re: blb]
#5277883 - 06/18/12 10:13 PM
Ill bet it was a nice sight in the mak. Just when I tried to take it on with my 6"SCT my neighbor turnsw on the drier and it killed my seeing. Porrima was practicaly wedged it was so awful. Such is condo life.
Pete
blb
Reged: 11/25/05
Loc: Piedmont NC
[Re: azure1961p]
#5277910 - 06/18/12 10:28 PM
...This is an effect seen in images and visually when an object is viewed or photographed at a low altitude and the light has to go through a lot of the Earth's atmosphere. The air mass acts as a prism, splitting the wavelengths of white light and diffracting the red light to the bottom of the object, and the blue light to the top. At the time this image was taken, Porrima was only about 33 degrees above the horizon.
No doubt that this effect is a very interesting one. Perhaps I did not see it because Porrima was crossing my meridian and at it's highest for me when I observed it. Kind of makes me wont to reobserve this double star at a lower altitude and see what it looks like. Thanks for shareing the web site. Now all I need is a clear sky.
azure1961p
Reged: 01/17/09
Loc: USA
[Re: blb]
#5277997 - 06/18/12 11:20 PM
Very interesting, as thats how high the elevation was when I observed it!
Pete
blb
Reged: 11/25/05
Loc: Piedmont NC
[Re: azure1961p]
#5278619 - 06/19/12 11:06 AM
Prismatic atmospheric dispersion. I will bet that this is the reasion for spurious colors being reported by people who observe doubles. Unless the double is high in the sky, above 45 degrees altitude (one and a half atmospheres), how can you really say what colors the double stars are?
ken hubal
Reged: 05/01/07
[Re: blb]
#5279043 - 06/19/12 03:04 PM
Agreed! The effect you are referring to is actually called Differential Atmospheric Refraction. I've found that this has a profound effect on spurious color while observing multiple star systems. I've also seen it play a significant role in planetary observation as well when atmospheric conditions are right(dust, particulates, etc.). There was an article in S&T about a dozen or so years back about this phenomena.
JimP
Reged: 04/22/03
Loc: South Carolina
[Re: ken hubal]
#5279373 - 06/19/12 06:35 PM
Pretty neat! Thanks for the image.
