John59
Reged: 11/06/11
Loc: Round Rock,TX
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2
[Re: James Cunningham]
#5406462 - 09/06/12 12:27 PM
Anyone use the "Auto" under Lens? Can you see a star with the auto setting? I know that it is the the right setting during the daytime. Also, anyone use a barlow to increase the size of the image? I am using a 120mm refractor and most of my images are really small. Thanks. Jim
I have not used the "Auto" mode, however I do use a 3x barlow when viewing planetary nebulas.
James Cunningham
Reged: 08/07/10
Loc: Maryland
[Re: John59]
#5406678 - 09/06/12 02:34 PM
What is the lowest Lens setting that you can use and still see a star in a 5 inch refractor? Thanks.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
#5407014 - 09/06/12 06:20 PM
Jimmy, My guess? If a star like Sirius or Vega, faster than 1/60 second.
James Cunningham
Reged: 08/07/10
Loc: Maryland
[Re: GlennLeDrew]
#5409689 - 09/08/12 08:19 AM
I am giving up on my use of this Lyntech camera. Its just too hard to get good images. I only purchased mine to take with me to dark sites for use on a 120mm refractor. You can get decent images but it takes a LOT of fiddling. I will just take my Mallincam off of the big scope and take that with me. Anyone want to buy a camera? $50.00 including shipping. Jim
core
Reged: 02/23/08
Loc: Mostly in Norman, OK
#5409862 - 09/08/12 10:58 AM
I am giving up on my use of this Lyntech camera. ... Anyone want to buy a camera? $50.00 including shipping. Jim
PM'ed you ... think I'll give it a try
James Cunningham
Reged: 08/07/10
Loc: Maryland
#5409902 - 09/08/12 11:24 AM
I have a buyer for my camera. Thanks. Jim
James Cunningham
Reged: 08/07/10
Loc: Maryland
#5426822 - 09/18/12 07:20 AM Attachment (73 downloads)
Jock sent me photos of a remote control OSD cable that he sells for $10.00 including shipping. Here they are.
James Cunningham
Reged: 08/07/10
Loc: Maryland
#5426823 - 09/18/12 07:21 AM Attachment (67 downloads)
Here is the 2nd one
No Idea
newbie
Reged: 10/02/12
#5452921 - 10/03/12 12:10 AM
Hi guys,
I’ve been avidly reading this forum and am totally sold on this camera. But please forgive me as im not planning to use it at this stage on a telescope but rather for a night vision project I’m working on.
I was just hoping for some of your expert advice as to some questions I have about this camera. I have had look at the 2 camera specs but I think I might be missing something.
I thought this initially was a black and white camera due to the lux rating. But some have been talking about the colour of their photos. Is there a black and white version that you have seen? As from what I understand it would be more sensitive. Is it truly 0.0003 lux @ faceplate or is it actually 0.003 lux being colour?
To me it looks as if it is only manual focus and zoom . Am I correct? Are these cameras capable of zooming and focusing using a motorised lens?
Should I go PAL or NTSC. I’m from Australia but does it make any difference? Is one more sensitive?
On the back of the larger camera there are a few terminal strips (RX, TX, Alarm) what do the others do? Is it only for the remote?
What functions does the remote on the larger camera actually control?
I like the smaller one but don’t want to sacrifice any important functions. I realise this is pretty basic stuff for you guys but im just trying to get my head around it all at this point. So please help.
Thanks in advance guys.
Joel
ccs_hello
Reged: 07/03/04
[Re: No Idea]
#5453990 - 10/03/12 06:43 PM
Joel,
This cam is a color cam. About the lux rating, you migh just as well ignore the number because there is no single, repeatable measurement method across different manufacturers. Sometimes, even within the same manufacturer, in different models, the measurement methods are different !
Note some of these unbelievable lux numbers are even measured (1) with IR llluminator light (not included) turned on, or (2) turn long exposure on, which is useless for security cam applications.
The cam does not come with any lens, you have to order your own per your requirement. Also the only interface this camera has to interface with the lens is the "DC Lens" connector which can only tell the compatible lens to adjust the iris opening. Anything else on lens control, the control signals has to talk directly to the control console, not through this camera.
Australia is PAL so order PAL type is more suitable in most cases.
RE: the camera terminal strip
Rx and Tx form a pair to use a twisted cable (2-wires) to interface with the RS485 controller to achieve the same effect of button pushes on these 5 buttons.
Alarm interface is a contact closure output to interface with an alarm system. In cam's menu setting, there is an "Alarm sensing page".
BTW, there are many security CCTV camera forums. You might be able to find some better answers there.
Clear Skies!
ccs_hello
No Idea
newbie
Reged: 10/02/12
[Re: ccs_hello]
#5454605 - 10/04/12 06:23 AM
Thanks mate that helps heaps
Ok so the camera is color, but at night it can switch to B/W, when it does though, does the lux abilty increase as well or is an dedicated B/W camera better? To me thats what it appears the spec's are saying. So in other words, is this color exview sensor capable of doing B/W like a dedicated B/W exview sensor?
Cause I would like to go color but only if I dont loose the low lux abilties of B/W.
And one more...
Are Lower resolutions in the exview better in regards to light pick up eg. 430, 600, 650, 700, TVL ?
Joel
ccs_hello
Reged: 07/03/04
[Re: No Idea]
#5454631 - 10/04/12 07:24 AM
Joel,
It's color. B&W is just by processing.
Day-Night mode setting is by menu selection (Day only <-- color, Night-only <-- B&W, and AUTO.)
In B&W mode, chroma signal is suppressed such that a slightly higher gain is applied to luma signal to make it looks "brighter".
READ: brighter =/= more "sensitive" (But with some measurement methods, the resulted Lux value will be better )
Monochrome CCD (in this generation, ExView HAD II) would be better than (same generation color ExView HAD II). However, I am not aware SONY produces the monochrome version of the same sensor used in this cam.
RE: pixel size discussion
Please read early part of this thread on my posts.
Clear Skies!
ccs_hello
No Idea
newbie
Reged: 10/02/12
[Re: ccs_hello]
#5458821 - 10/07/12 05:42 AM
Thanks Mate
Do you know were i can get the whole range of exviex data sheets to choose the best one.
Joel
ccs_hello
Reged: 07/03/04
[Re: No Idea]
#5459200 - 10/07/12 12:00 PM
Joel,
SuperHAD II and ExView HAD II are recently release products. There are not too many parts released.
Please start from here:
http://www.sony.net/Products/SC-HP/
Note: it's written for engineers.
Good luck.
Clear Skies!
ccs_hello
nytecam
Reged: 08/20/05
Loc: London UK
[Re: ccs_hello]
#5460049 - 10/08/12 03:04 AM
Please start from here: http://www.sony.net/Products/SC-HP/Note: it's written for engineers.Good luck.Clear Skies!ccs_hello
Thanks CCS for the link - I love the techno read - especially the Sony RGBW Bayer mosaic with W [white] pixels in lieu of green to boost sensor sensitivity even if currently only for phone cams
No Idea
newbie
Reged: 10/02/12
[Re: nytecam]
#5462665 - 10/09/12 06:47 PM
Thanks ccs_hello,
I took your advice and had a look at the CCTV forums. The camera Im looking for sounds like it is the watec LCL 902K.
I realise you guys need sens up functions etc. but as i will be using it on the move it seems the watec will be better for me in this case (no sens up). Could you please give me your opinion as to wether in my case a watec LCL 902K would pick up light better? Any other ideaS? If Im off topic sorry mate
Joel
James Cunningham
Reged: 08/07/10
Loc: Maryland
[Re: No Idea]
#5462779 - 10/09/12 07:58 PM
Only problem with the Watec is that it is black and white only. Jim
ccs_hello
Reged: 07/03/04
[Re: No Idea]
#5463047 - 10/09/12 11:11 PM
Joel,
It's off topic really.
Anyway, monochrome ExView is nicer but I can say it out right using these regular CCD (i.e., not photo-electron multiplying techniques), seeing in the extreme low light without time-domain accumulation is a pipe dream.
Sorry I must state the above so you get the expectation right.
Clear Skies!
ccs_hello
slipfit
journeyman
Reged: 04/02/12
#5463055 - 10/09/12 11:14 PM
Has anyone got this camera working with the RS485. I have a RS485 to RS232 converter, but can't get the osd to work. Missing something. The RS485 has 6 terminals, TX-,TX+, RX+, RX-, GND, 5-12V. Thanks
ccs_hello
Reged: 07/03/04
[Re: slipfit]
#5463092 - 10/09/12 11:32 PM
Slipfit,
Welcome to Cloudy Nights!
The larger model of the LNtech cam is using the one-pair (half-duplex) RS-485 for control. Your device is a two-pair design for full-duplex.
Please try:
Tie Rx- to Tx- and Rx+ to Tx+ to change two-pair into one-pair.
Connect the one pair cable to LNtech
Set your RS485 control software to half-duplex
Supply power to +5 and Ground
Test it again.
Clear Skies!
ccs_hello
