Pages: << 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | (show all)
ccs_hello
Reged: 07/03/04
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD new [Re: Moromete]
      #5675397 - 02/12/13 08:33 AM
Please use the other guiding thread or start a new thread on this severely off topic discussion.
P.S. not any CCTV videocam, but only on long exposure capable videocam. Also, the autoguide software has to be configured differently to capture in the right time interval. Rather involved and not optimal at all.
svrider1000
Reged: 06/28/12
Loc: Sylmar, California
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD *DELETED* new [Re: mattflastro]
      #5680079 - 02/14/13 07:20 PM Attachment (56 downloads)
Here is a quick video I took last night. I sort of took a small part and looped it a few times. I also added an image. These are not stacked at all.
Test Video of Orion Nebula with XLT 150 and LN-300 CCD camera
Edited by svrider1000 (02/14/13 07:22 PM)
astrojunkie52
journeyman
Reged: 03/08/08
Loc: Pennsylvania USA
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: Hemmi]
      #5690058 - 02/20/13 12:48 AM
Hemmi,
I bought the wireless remote. What gets connected to the TX on the camera, the + or - from the dome controller?
Can you be more detailed on what keys controls the OSD?
astrojunkie52
journeyman
Reged: 03/08/08
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: astrojunkie52]
      #5690407 - 02/20/13 09:03 AM
Played with camera and have wireless remote working. + on dome controller goes to RX on camera, - goes to TX. Go to settings in camera and confirm camera ID is 1 and baud rate should be 9600.
Power up wireless remote and it should display either A001 or P001. Hold down red Setup button for at least 3 seconds and display will change to d 24 which is the current baud rate. Use the right arrow button to scroll through settings until 96 is displayed then press Enter. A001 will now be displayed and 9600 baud rate will be set.
The Iris Open button behaves as Enter key and the arrow buttons behave as Up, Down, Right, and Left.
svrider1000
Reged: 06/28/12
      #5691989 - 02/20/13 11:33 PM
Astro,
What camera is this remote working for. Is this for the larger Sony camera?
mattflastro
Vendor - Astrovideo Systems
Reged: 07/31/09
Loc: Brevard County , FL
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: svrider1000]
      #5692156 - 02/21/13 03:09 AM
Astro,
Any camera that uses PElco-D over RS485 . Lntech for example (the large one).
The same codes that are used by the remote could be sent from a computer (if you use a frame grabber ) .
There is software available which allows pc remote control of PElco-D cameras , see this post http://www.cloudynights.com/ubbthreads/showflat.php?Cat=&Board=VAA&Nu... .
telfish
Reged: 11/17/10
Loc: Adirondack Mountains NY
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: mattflastro]
      #5692368 - 02/21/13 08:59 AM
Will this work for the smaller camera?
mattflastro
Reged: 07/31/09
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: telfish]
      #5693046 - 02/21/13 04:17 PM
The smaller Lntech camera uses the same imaging board as the large one but a different interface board.
It does not have the RS485 connections to the outside world, although its DSP has the necessary firmware.
out of the box the small cam can't be remote controlled over rs485.
astrojunkie52
journeyman
Reged: 03/08/08
      #5695995 - 02/23/13 02:36 AM
LN-320-11673
astrojunkie52
journeyman
Reged: 03/08/08
      #5696002 - 02/23/13 02:50 AM
Matt,
Checked the link. Would you use HyperTerminal to send the hex codes?
The PTZ Controller software also looks like it will do the job. Wish it was less than $69.
mattflastro
Reged: 07/31/09
      #5696347 - 02/23/13 10:53 AM
Matt,
I suppose you could use hyperterminal although I haven't tried.
I used this:
http://www.commfront.com/232default.htm
John59
Reged: 11/06/11
Loc: Round Rock,TX
      #5698152 - 02/24/13 12:04 PM Attachment (89 downloads)
Here is a snapshot of the spindle galaxy with my unmodded mini NTech. (commercial IR filter is removed)
This was through a C11 with 6.3 reducer at 1024 integration.
Matt I would be interested in how this looks with your modded camera.
Edited by John59 (02/24/13 12:05 PM)
mattflastro
Reged: 07/31/09
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: John59]
      #5698832 - 02/24/13 07:47 PM Attachment (62 downloads)
For now it would look like the attached picture.
I'm waiting for a good moment .
Just a note about the IR cut filter on the LNtech cameras. There are 2 types of IR cut filters that can be shipped with the cameras, a 670nm and an 850nm .
I believe the 850nm is for low light IR illuminator applications . This one seems ok to not remove . The 670nm should be removed .
In order to figure out which one you have, the simplest thing is to shine a TV or other appliance IR remote at the camera and see either a blinding light (indicating you have the 850nm filter) or nothing (you have the 670nm ).
Some of the cameras came with a version of the OSD menu that allows you to select which IR cut filter you have (the DSP will calculate the white balance slightly differently depending on the selected filter) .
John59
Reged: 11/06/11
Loc: Round Rock,TX
      #5698850 - 02/24/13 07:59 PM
I hear you Matt. Last winter we had 25 clear nights between Dec and Jan. This this year...1. So far Feb has been better, clear and steady 5 nights so far.
Moromete
Reged: 02/15/12
Loc: Romania
      #5700143 - 02/25/13 04:10 PM
Matt, are you modding the Lntech cameras with Super HAD II or Exview II sensor?
Secondly, are you using the bigger or the smaller Lntech model to put Peltier cooling on it?
PS: Put some dame photos with the modded camera to cool us down a little.
Live_Steam_Mad
Reged: 07/24/07
Loc: Moss Bank, St.Helens, England
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: Moromete]
      #6121288 - 10/06/13 08:54 PM
Hi, I fancy getting this 40 GBP smaller version camera shortly.
There was mention of the camera defaulting to black and white ? If I set Sens up to OFF and the AGC to OFF and Lens to electric between x32 and x1024, does the camera stay in color all the time? Do I have manual control over the white balance whilst it does this?
I would like to know please what is the source of the noise that the pix have, even when switching the camera on and using it straight away from ambient temp? Is it the on chip amp? The readout amp? Another amp. chip after that? The 1/3" chip itself?
Any news on those 1/2" cameras with the new Super HAD CCD 2 and Ex View HAD 2 yet?
Alistair G.
Edited by Live_Steam_Mad (10/06/13 08:57 PM)
ccs_hello
Reged: 07/03/04
Re: 17 sec (x1024) Camera Sony 960h Exview HAD CCD2 new [Re: Live_Steam_Mad]
      #6121841 - 10/07/13 08:11 AM
Alistair,
For detailed discussion on image sensor noise analysis including noise sources, please read Prof. Craig Stark's article series "Fishing for Photons" shown in Cloudy Night's home page:
http://www.cloudynights.com/index.php
Videocams, just like any other types of imaging devices, are depend on image sensors thus are subject to the same evaluation criteria and constraints.
Clear Skies!
ccs_hello
barbarosa
Reged: 04/11/10
Loc: "lamorinda", CA
      #6122490 - 10/07/13 01:35 PM
Yes
Yes
6 registered and 8 anonymous users are browsing this forum.
Moderator:  csa/montana, JayinUT
