Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | (show all)
tim53
Reged: 12/17/04
Loc: Highland Park, CA
Re: Delmarvascopics 8" f/9 OTA build new [Re: tim53]
      #5596714 - 12/30/12 06:45 PM Attachment (42 downloads)
First I turned the OD and sanded it smooth. Then I buttered it with some water-based polyurethane, and used a heat gun to dry it quickly (about 15 minutes instead of 2 hours). Then I sanded it smooth again. Finally, I parted it off the blank by gouging out the inside until the ring came loose. After that, I took the separated ring and sanded the inside on a spindle sander. I've checked the fit of these first 2 rings on the tube (actually, there's a third, but I used some old oil-based poly for it, and it's still tacky, so I don't know if I'll use that one).
Then, I grabbed a bag of chips and jar of dip and came up here to post the pics, since I can't figure out how to load them directly from my phone. I'm going to try to get the remaining rings cut out today so I can poly them all over and let them dry good and hard before working on them again tomorrow. If there's still daylight, I might start cutting the 1/2" aluminum bar stock into ring spreaders for the rotating ring cage.
-Tim.
tim53
Reged: 12/17/04
      #6390818 - 02/22/14 04:27 PM
Ah! Herrointment helped me find this thread, since I was on my iphone and my search didn't work.
I had started a new thread, but now that I know where this one is, I'll continue here.
-Tim.
tim53
Reged: 12/17/04
      #6390828 - 02/22/14 04:33 PM
I may do the rings over. I've been using that disk I mounted to the faceplate on my HF wood lathe as a faceplate. I could easily mark mounting holes around the thing that could double as spacer holes for the rings on the scope as well as help me make everything concentric and quick. I've got a bunch of fiberglass resin, cloth, and matting, plus some "bondoglass" for filling, so I think I can make some purdy rings fairly quickly if the ones I have thus far aren't sufficient.
I think I'll cannibalize the 3" f/6 Edmund I built a couple years back, where I used a Lumicon 1 1/4" helical focuser and a 3/4" secondary, and use them for this 8". Rather than make the mirror cell move fore and aft for focusing or troubling with a sled focuser.
-tim.
tim53
Reged: 12/17/04
      #6449184 - 04/05/14 03:18 PM
I think I musta lost a few posts in The Great Upgrade/Downgrade. No worries, though. Progress is slow, what with all the other things I'm doing these days.
-Tim.
tim53
Reged: 12/17/04
      #6449203 - 04/05/14 03:30 PM Attachment (17 downloads)
I was going to make just two of these "saddle plates" to bolt the rotating rings to for stiffening, and to mount the scope to a mount, with rod/spacers along the sides. But I decided that if I just made 4 of the saddles, I could mount accessories on the side of the scope as well as on top, so I made 4. When I bolted them all together for a dry fit, it occurred to me that I might as well make the inner part one solid piece with the outer races of the rotating rings attached, and then the inner races and plywood rings for attaching to the tube could be taken off for cleaning, lubing the bearings, and painting the components. So I think I'll fiberglass all the wood parts together. I may keep working on the other components of the OTA (need to make a mirror cell, spider, and sled focuser) so I can put it all together and try it out, maybe before finish sanding and painting.
-Tim.
Edited by tim53 (04/05/14 03:31 PM)
tim53
Reged: 12/17/04
      #6449210 - 04/05/14 03:34 PM Attachment (19 downloads)
Detail of one of the rotating rings. The assembly is just sitting near the end of the tube, but I have made sure I can slide it up the tube. I'll probably screw it to the tube when I've built everything and know where the balance point is.
woodscavenger
Reged: 08/20/13
Loc: Boise, ID
      #6450075 - 04/06/14 01:01 AM
Watching this makes me want to get a similar mirror and dust off the old woodworking tools.
tim53
Reged: 12/17/04
Re: Delmarvascopics 8" f/9 OTA build new [Re: woodscavenger]
      #6450153 - 04/06/14 02:18 AM Attachment (15 downloads)
Go for it!!
Now, this is going to look pretty awful, but it's progress! I'm using "Bondoglass" to fill voids in the wood structure and I'm making the outer races of the lazy suzan bearings integral to the "cage". I did make sure I left openings so I can access the plug to allow removal of the ball bearings and get the inner races off for when I go to paint everything.
I'll apply resin over the bare wood to fill and seal it before I paint. I'd use epoxy resin, but it takes too long to cure and I'm impatient!
-Tim.
tim53
Reged: 12/17/04
      #6451466 - 04/06/14 07:09 PM Attachment (16 downloads)
Getting slightly purdier. I took out the plugs and "drained" the bearings int
Plastic bags for cleaning and reassembly later. Here, I'm working on filling remaining voids after a sanding.
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #6452613 - 04/07/14 11:59 AM
Well, Carl Zambuto currently has advertised on his web site a 12.5" f/9.3 mirror available for immediate delivery.
The RTA numbers on it must be phenomenally low. I am very tempted …..
tim53
Reged: 12/17/04
Re: Delmarvascopics 8" f/9 OTA build new [Re: Jeff Morgan]
      #6475667 - 04/19/14 02:29 PM Attachment (9 downloads)
Back at it! Last weekend was a "house" weekend, but this is a "toys" weekend!
Here's the idea. I've put a first coat of black paint on the cage, and already decided that the osh black paint dries too slowly. It's dry after several hours, but it loads up sandpaper too easily still. I want to get this done soon so I'm switching to a primer for the next few coats to fill the grain, then I'll come back with the semi gloss black for the final.
Here, I've bondoed a couple spots and have the inner race/ring standing next to the cage. The ball bearings and plug are safely stored in plastic bags.
tim53
Reged: 12/17/04
      #6475668 - 04/19/14 02:29 PM Attachment (9 downloads)
Too
Pinbout
Reged: 02/22/10
Loc: nj
      #6475734 - 04/19/14 03:01 PM
I guess the eye piece height would be an inversion of the RTA.
figurate
Reged: 02/09/13
Loc: Metro North Texas
Re: Delmarvascopics 8" f/9 OTA build new [Re: Pinbout]
      #6475947 - 04/19/14 05:24 PM Attachment (5 downloads)
That looks nice, Tim. I am considering my options for a project of my own and was wondering what brand of lazy susan bearing you are using. It looks well-designed since there is a integral loading "port" to add or remove the balls. A couple of other comments: you can get a vinyl strip with a u-shaped cross section at auto-parts stores (intended to be put over door edges) that might help protect the fragile tube ends temporarily while you are working it all out.
Also I am wondering about the stresses on the particular saddle plate/bearing joint that will ultimately be supporting the telescope. I see that you refer to it as 'bolted' but I don't spot a fastener in the pics. You might consider a way to tie everything together around the circumference of your cradle assembly, which would avoid overloading one particular hexagonal face. (Not meaning to be critical, but I have been wrestling with similar issues) Like a strap, basically.
Here is a different approach to a wood & aluminum cradle for an 8" newtonian, my modified OC mount:
tim53
Reged: 12/17/04
      #6476103 - 04/19/14 07:02 PM
I forget. What's an RTA?
tim53
Reged: 12/17/04
      #6476109 - 04/19/14 07:07 PM
I bought the bearings from vxb.com but I think they all come from china.
tim53
Reged: 12/17/04
      #6476133 - 04/19/14 07:21 PM Attachment (6 downloads)
I keep finding goobers to fix. I'm going to have to call it good enough soon or go bonkers.
I remembered a "trick" I used to use to quickly fill grain on the bigger facets: mix a small batch of bondo "hot" with plenty of hardener. It hardens fast and hard, so I can keep working.
tim53
Reged: 12/17/04
      #6476137 - 04/19/14 07:22 PM Attachment (5 downloads)
Tooo
tim53
Reged: 12/17/04
      #6476231 - 04/19/14 08:22 PM Attachment (6 downloads)
Inner race/rings. Gonna have to touch these up a bit. I used krypton gold, which has a bit of a copper cast to it. Osh'a own gold looked more like clean brass to
Me, but they don't have it anymore.
tim53
Reged: 12/17/04
      #6476235 - 04/19/14 08:23 PM Attachment (7 downloads)
And the cage. Have to me tack so I can paint the other side.
10 registered and 30 anonymous users are browsing this forum.
