Orion58
Reged: 10/28/11
Loc: Southern Wisconsin
The Eagle Nebula
      #5292211 - 06/27/12 08:49 PM
Hello CNers;
This image (of M16) was taken over two nights - total exposure time almost 4 hours. Dark, flat and bias frames were also incorporated.
The images taken the second night, June 22, were the first taken from my new observatory.
A larger version can be accessed here http://www.flickr.com/photos/orions_belt58/7457537334/in/photostream
and thank you for looking.
Clear skies
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: The Eagle Nebula new [Re: Orion58]
      #5292292 - 06/27/12 09:40 PM
Congrats Bruce, were you guiding for your subs? The stars look good, maybe a little oversharpened inside the nebula in just a couple of areas but overall a nice image.
NorthBoundTrain
Reged: 11/23/11
Re: The Eagle Nebula new [Re: rigel123]
      #5292617 - 06/28/12 01:35 AM
I was thinking the same in respect to the stars. If they were more like the ones around the outer parts of the nebula, I think you would hit perfection. Still though it's a great shot. I really hope I can find a position in my yard to image it this season.
EricJD
Reged: 07/24/07
Loc: Chesapeake VA
Re: The Eagle Nebula new [Re: NorthBoundTrain]
      #5292796 - 06/28/12 07:40 AM
Great shot.
zjc26138
Loved By All
Reged: 02/24/05
Loc: Mingo Junction, Ohio
Re: The Eagle Nebula new [Re: EricJD]
      #5292812 - 06/28/12 08:04 AM
Greeat Image!
Orion58
Reged: 10/28/11
      #5292839 - 06/28/12 08:42 AM
Yes, I was autoguiding and taking 200 sec subexposures. I believe the artifacts you mention may have resulted from my use of the minimum filter in photoshop. I tried to reduce the stars slighly so they weren't so overpowering. Perhaps I can come up with a different method to improve these stars a little.
Edited by Orion58 (06/28/12 08:45 AM)
Orion58
Reged: 10/28/11
      #5292847 - 06/28/12 08:49 AM
In addition to the comments I made to Warren I'm wondering if these stars were a little overexposed to begin with??? Perhaps I need to try imaging this target as I would for M42 - take shorter exposures of the middle/brighter part and longer exposures for the rest of the image and combine them???? Just thinking out loud here... But thanks for your remarks Chris - I appreciate them.
Orion58
Reged: 10/28/11
      #5292855 - 06/28/12 08:51 AM
@ EricJD & zjc26138; Thanks for the comments!
CounterWeight
Reged: 10/05/08
Loc: Cloudyopolis, OR.
      #5293480 - 06/28/12 03:41 PM
Congrats on the nice M16 image and getting you obs running !! The way it looks I am curious about if the flats worked. The center seems a bit washed compared to outer area?
Vladimir Elvov
Reged: 08/21/11
Loc: Munich, Germany
Re: The Eagle Nebula new [Re: CounterWeight]
      #5293578 - 06/28/12 04:54 PM
Nice shot, Bruce.
Perhaps a bit overexposed or over-sharpened. With mod Canon it should show more red emission. Minimum filter should not make the star edges sharp or may be you need to feather it a bit
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: The Eagle Nebula new [Re: Vladimir Elvov]
      #5293598 - 06/28/12 05:07 PM
Looks really good.
Orion58
Reged: 10/28/11
      #5293669 - 06/28/12 06:05 PM
I think this may be due to a contrast curve I applied in the center to bring out the pillars a little better. Perhaps I brightened this area a bit too much...
One other comment I'll throw in - the telescope I use is well know for making bright stars "square". This is due to the thick spider vanes holding the secondary. Very high on my "things to do" list is to grind these as many VC200L owners end up doing...
rigel123
Reged: 06/29/09
Loc: SW Ohio
      #5293827 - 06/28/12 07:32 PM
Something you might try is once you have your image where you want it, and you feel the stars are just a little too much, do a Select/Color Range and Highlights. You'll have to deselect some parts of the nebula that this will pick up. When you see that only stars are selected, do a Select/Modify/Expand and try 3 pixels, then feather about 2 pixels, and then do a very mild (.5 - .7) gaussian blur on them. You might have to play with them a couple of times to see what looks best, but I have found that just blurring them a little bit brings the nebula out a bit more. I also use the Carboni Tool for reducing stars which I think works better than the minimum filter alone for reducing stars.
Orion58
Reged: 10/28/11
      #5293920 - 06/28/12 08:58 PM
Hi Warren; I think that those suggestions are well worth trying on version 2. I have used these methods on other images but I did not use them on this one. Out of habit I scroll for the minimum filter - I need to use more of Carboni tools - obviously in conjuction with PS tools.
Thanks for the input.
rigel123
Reged: 06/29/09
Loc: SW Ohio
      #5294076 - 06/28/12 10:35 PM
Dozens of ways to skin that cat in this hobby!
alpal
Reged: 06/15/09
Loc: Melbourne Australia.
      #5294161 - 06/28/12 11:42 PM
Always take some shorter exposures than 200 seconds -
say 30 s, & 60 s.
You can then put that frame as a hide all layer in Photoshop
& paint the inherent smaller stars - with their better colour
through using the paint brush tool.
This works great for the big bright stars.
Orion58
Reged: 10/28/11
Re: The Eagle Nebula new [Re: alpal]
      #5294431 - 06/29/12 07:53 AM
say 30 s, & 60 s.
Thanks for the tip! Looks like it will be a few days before the weather clears up, but I'll grab some shorter exposures and give it a try.
Clear skies
alpal
Reged: 06/15/09
      #5295819 - 06/30/12 02:49 AM
Good on you Bruce.
There are many tips in processing but
you are doing well.
This was the best introduction place for processing
but it's been down for months:
http://www.atalas.net/
There were top videos there of how to process using photoshop.
I hope they return for the benefit of those who
haven't downloaded all the videos.
4 registered and 16 anonymous users are browsing this forum.
