Privacy Policy |
Please read our Terms
of Service | Signup and
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
Re: C14. Refractor Equal
[Re: Eddgie]
#5295053 - 06/29/12 03:23 PM
For example, if I were to use 300x (many people suggest 50x inch of aperture, but I think that is way to high) in my 6" APO, the exit pupil would be about .5mm. My view is very dim. Plasing, but dim.
Using the C14 at 300x, the exit pupil is over twice as large, and the image is more than 3 times as bright.
It is this added "illumination" of the target that makes it possible to detect detail that has become to faint in the 6" APO to be easily resolved.
This is an extremely important part of the discussion.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
[Re: GeneT]
#5295076 - 06/29/12 03:40 PM
I compare the image brightness to the dimmer on my computer screen. The larger aperture C14 is like full brightness, the 6" APO is about five clicks back, noticeably dimmed. However the 6" has a very nice high resolution 1040p monitor where the C14's is only 760p. But the C14 is set for millions of colors while the 6" APO is set for thousands.
Something like that anyway .
BillP
Reged: 11/26/06
Loc: Vienna, VA
[Re: GeneT]
#5295185 - 06/29/12 05:02 PM
Agreed! The interplay of illumination and image scale are critical in perception.
Edited by BillP (06/29/12 05:03 PM)
vahe
Reged: 08/27/05
Loc: Houston, Texas
[Re: Mark Harry]
#5295296 - 06/29/12 06:37 PM
I was under the impression the obstruction on a C14 was about 1/3rd the aperture, resulting in a degradation to about .80 Strehl; 1/4 wave. Where does the 1/8th @ .95 come from?(obstruction size = ?) Don't they have baffle also, which has to be taken into account? M.
You are preaching to the wrong crowd my fried, here on Cloudynight SCT’s enjoy tremendous support from owners, admirers and supporters, it is not uncommon to encounter claims of Strehl of .95 and 1/10 Wave.
As for central obstruction and its side effects, to quote a member “the large central obstruction myth is largely overblown”, and another quote “The central obstruction is nothing more than a very minor ingredient; even at 35% a rather unimportant one”.
As for laws of physics, who cares!
Vahe
Reged: 06/16/04
[Re: Eddgie]
#5295419 - 06/29/12 08:01 PM
First, the eye and the camera lens are each very unique. The fact that the camera can do a very long exposure gives it an advantage because it an build an image due to accumulation of light, where the eye really doesn't function this way.
The question here is how valid it is to compare planetary performance to deep sky performance. Clearly with bright objects like Jupiter, the improved contrast that a larger scope provides is very useful when looking at the fine scale, low contrast details on Jupiter's surface.
But Jupiter is very bright, the Ring Nebula is very dim. To resolve those faint, barely visible details of the ring, the eye requires that the scale of the detail be very large, highly magnified. The eye is not resolving those fine details on M57 because the entire image is barely visible, it is the added light gathering of the larger scope that allows the higher magnification and brighter image at the same time that allow for more details to be seen. But the telescope resolves more than the eye can see, the camera shows this.
I like your example of the M57. How does the ring nebula compare to Jupiter in terms of details resolved and brightness...
According to the Sky, Jupiter is currently 35 arc-seconds in diameter with a brightness of -2.2 magnitudes. M-57 is 2.5 arc-minutes in diameter and magnitude 9.0. Jupiter is 28,000x brighter and covers an area 1/18th of that of M57. Do the math, the surface brightness of Jupiter is 500,000x brighter than M57.
With an image this bright, there is enough light that the eye can see those fine details. 500,000x, most solar filters have an attenuation of 1/100,000. If my calculation is correct, that says that the ring nebula is dimmer than were I to view Jupiter through a solar filter.
Do the thought experiment, viewing Jupiter through a solar filter... no detail is lost, no contrast is lost, only brightness.... what would Jupiter look like through a solar filter?
I suggest that Jupiter would be barely visible and that the wealth of detail that is there to be seen at full brightness could not be seen, the added contrast of the fine details that the increased aperture provides would not be visible to the eye. Were it merely brighter or the eye far more sensitive, it could be seen.
The camera is instructive because it is an example of the contrast and detail visible in deepsky objects. Long integration imaging does not improve the spacial detail, it just makes the image brighter... The example of the fine detailed images of the deep sky that the camera provides which are not visible to the eye is merely useful to demonstrate that there is significantly more at the focal plane to see than the eye can see...
So my point is that factors that are important in providing the high quality planetary views are not in operation when viewing the faintest objects because the details are simply too small for the eye to resolve because there is just not enough light reaching the retina. Less light means the image at the retina must be larger.
This is why image intensifying eyepieces are so effective, they provide the brightness needed so the eye can resolve what is there to be seen.
So, I ask this question:
I make the calculation that from a brightness point of view, a C-14 has the through-put of a perfect 12 inch telescope. So, that means the C-14 is 4 times brighter than the 6 inch refractor.
Add neutral density filter with 25% transmission to the C-14 and look at the M57. How different would the images be, the detail seen, than if you were looking through the 6 inch? Were you looking at Jupiter, the larger scope would show significantly more.
Looking at M57, I just don't think the fine details that are enhanced by the improved contrast of the larger scope are visible to the eye.
David Pavlich
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
[Re: HCR32]
#5295624 - 06/29/12 10:39 PM
I'd like to see a C14 like scope that has been hand figured like the apochromats we are always comparing the C14 to. I don't know the cost of an 8" TEC, but I remember seeing an 8" AP on the 'Mart for about $49K.
An SC that has, say, $20K's worth of polish would probably put up some pretty nice views.
David
Peter Natscher
Reged: 03/28/06
Loc: Central California
[Re: Jon Isaacs]
#5295653 - 06/29/12 11:02 PM
Actually, I've found that given decent quality seeing, the most important issue for a telescope is its thermal characteristics. Tube currents, boundary layers all destroy planetary observing more times than questionable seeing. With average or fickle seeing, you can still be patient to glimpse great detail. With telescope thermal issues, there's no hope of seeing anything worthwhile, sometimes the entire night long. I see little enjoyment in observing planets with a telescope that requires half the night to settle thermally. Big Dobs used during the summertime are prone to never reaching thermal equilibration all night long. I've seen C14's never settling down in order to achieve their "on-paper" performance levels vs. a neighboring 6-7" APO settling in an hour's time. In this case, the APO wins hands down. This scenario happens much of the year. On-paper performance numbers don't live up to real world performance for many observers.
I'm not sure what you mean by "equal"
It seems that discussions like this always end up focusing on one thing: Planetary performance comparing the two scopes with the seeing is excellent, the SCT or Newtonian thermally stablized and with excellent optics. Such comparisons do not represent what the vast majority of us experience on a nightly basis.
The planets are just one small corner of the sky and there are many other aspects and interests to consider.
Agreed Jon, however planetary comparisons seems to be a common ground for resolution and contrast comparison. Right or wrong that just where things gravitate.
Joe
They are common ground for comparing planetary views because that is about the only thing that is arguable when comparing two scopes. The rest is pretty much a no brainer, field of view, off-axis correction, light gathering...
The fact is that the important factor governing the quality of the planetary viewing is not the telescope but the seeing. The fanciest scope is of little worth if the seeing is poor and any decent scope will do a wonderful job when the seeing is excellent...
David Pavlich
Transmographied
Reged: 05/18/05
[Re: Peter Natscher]
#5296082 - 06/30/12 09:39 AM
....and then we turn the scopes to look at NGC4565.
David
Reged: 06/16/04
#5296709 - 06/30/12 05:45 PM
I definitely agree with that... thermal stability, good seeing, good optics, a stable mount, that's the key.
That said:
If anyone is still reading this thread, here is an interesting little experiment:
I made the calculation that the surface brightness of Jupiter is about 500,000x greater than that of the ring nebula. Jupiter is not visible but the moon is currently well positioned. My calculation says the surface brightness of the moon was about 600,000x that of the ring nebula. Using a solar filter with it's 100,000:1 should cut that down so that the moon is only about 6X brighter than the ring nebula.
With the solar filter in place, one has an effective model DSO, relatively bright by DSO standards and known to be highly detailed. I estimate that with the filter in place, the moon represents a magnitude 1.6 DSO about a half a degree in diameter.
Last night, after it was as dark as it was going to get, I spent some time observing the moon through a solar filter. I was using my 4 inch apo and tried a variety of magnifications.
I was skeptical that I could actually see the moon though the solar filter but I was able to and as my calculations suggested, it was actually quite bright, by DSO standards that is.
But how much detail could my eye see? In comparison to what it sees without the solar filter, not much. Certainly less than is visible through the poorest telescope I have ever looked through.
Anyone interested in just doing some interesting investigations into the importance of brightness in seeing details... give it try.
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
[Re: vahe]
#5296725 - 06/30/12 06:02 PM
Vahe
Isn't Strehl ratio the ratio of the amount of light that an optical system puts into the central spurious disc of the Airy diffraction pattern (about 83% iirc) to the same measurement in a perfect Unobstructed Optic?
The obstructed optical system directs some light away from the central spurious disc to the rings thus the obstructed system cannot have a Strehl ratio close to 100% or even 90% When compared to an unobstructed system. Even a perfect Newtonian system cannot have a Strehl of 95% if we accept the definition above.
We could invent a new ratio which compares the spurious disc light in obstructed systems to a theoretical perfect obstructed system but it won't be a Strehl.
Dave
vahe
Reged: 08/27/05
Loc: Houston, Texas
[Re: Cotts]
#5296805 - 06/30/12 07:04 PM
You are correct, Strehl is supposed to give the ratio of light that forms the image vs the ratio of light that floats around the image messing the contrast. In a perfect optical system with no obstruction roughly 83% of light comes to focus, central obstruction directs additional light away from focus into the surrounding rings lowering the image quality and the contrast, the larger the co. the more damage is done.
For whatever reason the effects of co. are not factored in the Strehl calculations making it fairly misleading, or producing very high numbers that simply do not reflect the reality, and by eliminating the effects of co. manufacturers can claim some real outrageous numbers.
And if this is not bad enough in optics with refracting elements Strehl’s are always given for monochromatic light removing the CA and its effects from the system, that way an achromat will produce a Strehl of .99, tested with monochromatic light an achromat will test better than a super apo producing zero CA, it can not get any better than that.
A better standard is to give “encircled energy” for the system, encircled energy considers everything in the light path but you will never see one quoted for any optic.
At the end of the day all the numbers given are suspect, be that PW, RMS or Strehl, there are ways to glorify a given optic by claiming high numbers that do not mean much, that is why if you are really looking for quality optics ignore all the technical mumbo jumbo and go with the reputation of the manufacturer.
Vahe
gnowellsct
Reged: 06/24/09
#5296867 - 06/30/12 07:53 PM
Tube currents, boundary layers all destroy planetary observing more times than questionable seeing. With average or fickle seeing, you can still be patient to glimpse great detail. With telescope thermal issues, there's no hope of seeing anything worthwhile, sometimes the entire night long. "
Try observing on grass. And I mean "lawns." GN
[Re: Rustynuts]
#5297216 - 07/01/12 12:59 AM
What instrument are you using to measure the "40%" increase in brightness? How are you measuring contrast; what tools/methods are you using?
I ask because perceptions of brightness and contrast can be affected by a multitude of factors, and unless you really are using methods that keep "all else equal", such conclusions are suspect. For example, are you using the same exit pupil with both scopes when estimating brightness? How about magnification; same or different? Disparity in either will have an affect on visually perceived brightness.
[Re: Cotts]
#5297223 - 07/01/12 01:15 AM
Yeah, the folks referencing 0.95 Strehl SCTs don't understand the data they cite. The data refers to the primary mirror's Strehl, not the SCT's whole-system Strehl, and as such is rather meaningless. A simple spherical mirror of just 0.95 Strehl is actually kind of "meh" to be honest. As a system, it's rare for an SCT to meet the commonly accepted definition of "diffraction limited".
Be that as it may, a good one (0.75 system Strehl?) can be an excellent visual scope, offering loads of aperture in a small, easily mounted package. I have a very good, brand new C8, a really decent C6, a fairly average C11 and a bit worse than average C5, and the fact that not a one of them is "diffraction limited" doesn't bug me. I accept them with their faults, and enjoy them for the things they do well. Of course having a high Strehl where it matters - as a system - ain't one of those virtues.
- Jim
scopelover
Reged: 02/02/08
Loc: Catskill Mtn.s, NY
[Re: Eddgie]
#5297270 - 07/01/12 02:16 AM
For what its worth~ At last yrs WSP in the Keys, my 1974 C14 gave the BEST planetary views of the whole week.... NOW, maybe I missed someones kick *** scope on the berm, BUT ... side by side w/ a 7" Astrophysics .. the C14 blew it away! The image in ANY good refractor- however- is soooo SO pleasing and juicy .. I cannot deny! .. But the proud owner of that 7" AP spent a LOT of time with my old fork-mounted C14 beast! The views of Mars in the C14 were in another league altogether - TRULY. I was running at 650x --- the refractor could really only handle @ 300x .... This over 3-4 nights consecutively~ Some say aperture wins ... Perhaps.
Now I'll go back to dreaming and drooling over the f antasy of a 12" refractor!
EddWen
Reged: 04/26/08
Loc: Here or There
[Re: scopelover]
#5297671 - 07/01/12 10:52 AM
Here you go !!!!
http://www.astromart.com/forums/viewpost.asp?forum_post_id=787606&poll_id=&news_id=&page=
EddWen
Reged: 04/26/08
Loc: Here or There
[Re: EddWen]
#5297687 - 07/01/12 11:03 AM
"....The data refers to the primary mirror's Strehl, not the SCT's whole-system Strehl, and as such is rather meaningless...."
I'm not sure that is correct either. A properly derived Strehl is calculated from interferometer data of the whole surface. A spherical f/2 mirror would exhibit too much coma off axis to result in a .95 Strehl.
Reged: 06/16/04
[Re: EddWen]
#5297723 - 07/01/12 11:27 AM
It is my understanding that the Strehl ratio is based on a perfectly executed optic of the same same design. The measured Strehl for an SCT is compared what is theoretically possible for an SCT with the same sized central obstruction etc. It's a measure of the optical quality of the scope, not the capability of the scope.
I think sometimes people refer to the "system Strehl" which would compare it to a perfect scope of the same aperture. In this case, the Strehl of the SCT is much lower because of the spreading of the energy by the central obstruction.
ValeryD
Vendor (Aries)
Reged: 11/26/05
Loc: Kherson, Ukraine.
[Re: scopelover]
#5297806 - 07/01/12 12:22 PM
The friend of mine and me have performed the test of three telescopes 14" SCT (with active cooling system), 10" F/14.6 Mak (22% central obstruction and active cooling system) and 7" F/7.8 Fluorite doublet refractor. Three evenings straight. Targets were Saturn and moon. This was not a side by side comparo, because I have only one mount. We were need to load and unload each telescope. This was not too difficult to make it in four hands. My large balcony is about 160 feet from the ground - so, with either west, south-west, south, south-east and east breath often are steady. But not always. These evenings were different. We were able to use magnifications up to 450x. Most frequently we used 250x to 350x.
Rating.
Poor to average seeing (4-5 of 10).
1. 7" apo.
2. 10" Mak
3. 14" SCT
Average to good seeing (5-6 of 10)
1. 7" apo
2. 10" Mak
3. 14" SCT
Good seeing. (6-7 of 10)
1. 10" Mak
2. 7" apo
3. 14" SCT
Good to Very good seeing (7-7,5 of 10)
1. 10" Mak
2. 7" APO
3. 14" SCT
Excellent seeing, best moments we have seen these evenings (8 - of 10)
1. 10" Mak
2. Tie 7" APO and 14" SCT.
The most delicate details were seen in 10" Mak and were not seen in other scopes. All details wich were seen in 7" APO during 4-7 seeing, were seen in 14" SCT too, but not as clear and sharp. And only during excellent seeing 14" works as good as 7" APO.
During good to very good seeing 14" SCT gaves best pictures in color rendition. To work at it's best 14" SCT needs almost perfect seeng and really smooth optics, smoother than in my good sample of 14" SCT.
So, accoring to our practical test, the answer to the question of this topic will be: an excellent 7" APO and only during very good to excellent seeing.
Rustynuts
Reged: 07/25/11
Loc: East Tennessee
[Re: jrbarnett]
#5300066 - 07/03/12 12:38 AM
the brightness conclusion was only determined after evaluating all types of targets. on the planets and moon, it was not as apparent. but when we went to deep sky targets was the difference overwhelmingly apparent, especially galaxies.
my 228mm APO has a fl of 2050mm vs the 9.25 at 2350mm. the fl is close but I did match power as much as possible. a cass has two mirrors and a corrector which all rob contrast. for example start out at 100% for a newly coated mirror subtract 2% for the corrector 13% for the central obstruction corrector another 5% for the secondary and yet another 5% for the primary mirror losses At the end only about 50% to 70% of the light reaches the eyepiece. vs 96% of a smooth figured APO with top shelf coatings. a large portion the light from the cass is scattered and a large percentage is lost.
After I finish my observatory I will be comparing different scopes side by side because I too want to know what will be the equel to the big Apo, FYI I have a 20"f3.7 mirror set which I own and will build a scope from and be using in tandem with the refractor in the dome.
This is my bet for a better deep sky scope.
I understand any comparison is suspect, but this one time the apo was superior in pulling in the faint stuff. Jon
Edited by Rustynuts (07/03/12 12:41 AM)
25 registered and 31 anonymous users are browsing this forum.
Moderator: Scott in NC, Bowmoreman, KWB
