OzAndrewJ
Reged: 11/30/10
Re: LX80 RA tracking
[Re: TALK2KEV]
#5315469 - 07/13/12 05:25 AM
Gday Kev
Ok I have a new HBX and will check firmware and do so more test under real sky
Ripper. Just for fun, you can do a dry run indoors if reqd. Just remove the OTA etc and start the scope Select LX80-Polar mode then reboot the scope, ( as some stuff only sets correctly during startup ) Once started, do a dummy polar one star align by just accepting the defaults as presented. Once it says its aligned, pressnhold mode for 3 or more seconds to bring up the RA/DEC display. Note the RA Wander off and do some gardening/ironing etc for an hour After one hour, go back and reread the RA. What does it say???
Andrew
TALK2KEV
Reged: 03/08/06
Loc: Oklahoma
[Re: OzAndrewJ]
#5315619 - 07/13/12 09:07 AM
I need to update firmware looking on Meade site I see Autostar updates but no Audiostar updates. Need to get with Meade or David to find the right file. I search Meade site for A3S1 but no luck
Starhawk
Reged: 09/16/08
Loc: Tucson, Arizona
[Re: dmdouglass]
#5315688 - 07/13/12 09:49 AM
I just have to ask, why do you keep referring to autostar as "audio star?"
-Rich
Greetings to: Philip Neidlinger (and all others...)
Well, the above post from ur7x pretty well sums things up right now. I am an Alt/AZ user, and I love it !!!
Andrew Johansen (Australia) and I are still doing tests, and he is studying the results. I just sent him some new data this morning. This, of course, is studying the Polar alignment issues...
I am sure this will all work out. The interesting part will be what is done when Andrew figures it out. So far, we have not had Meade in the loop (unless they are following this thread).
If you are looking for a polar mount, then i would suggest a little patience for a few more days, and lets see what Andrew comes up with. We have an active user here (Dennis and Kevin) that are polar users. And their new (replacement) Audiostar should be to them in a day or so, and we should then acquire some more data. Then we will all know more.
Starhawk
Reged: 09/16/08
[Re: Starhawk]
#5315700 - 07/13/12 09:54 AM
And for the love of Galileo, can't anyone just do a star trail PE test on one of these things?
All you have to to is plop it down in equatorial mode with a lousy polar alignment, point at a star overhead, hook up a camera and let it go for 30 minutes with the shutter open. That's it. When you look at the image, the stars will have been drifting north as a result if the poor polar alignment. Periodic error gets recorded as wiggle in the star trails. See, it's easy.
-Rich
jrcrilly
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
[Re: Starhawk]
#5315726 - 07/13/12 10:02 AM
Audiostar is an enhanced Autostar controller provided with several newer mounts, including the LX80. It's very similar to Autostar but it is not identical.
jmiele
Patron Saint?
Reged: 12/04/10
[Re: jrcrilly]
#5315748 - 07/13/12 10:09 AM
Does it talk to you now. I don't get it.. but I am getting old. BTW, Thanks for asking Rich, I thought I was the only boob out there that didn't know.
Best, Joe
Starhawk
Reged: 09/16/08
[Re: jmiele]
#5315765 - 07/13/12 10:15 AM
So does it have Johnny Depp describing the wonders of the night sky?
-Rich
jrcrilly
Reged: 04/30/03
Loc: NE Ohio
[Re: jmiele]
#5315813 - 07/13/12 10:41 AM
Yes.
idealistic
Reged: 12/31/10
Loc: massachusetts
[Re: jrcrilly]
#5315850 - 07/13/12 11:07 AM
Please tell me its Morgan Freeman.
jmiele
Patron Saint?
Reged: 12/04/10
[Re: idealistic]
#5315908 - 07/13/12 11:52 AM
LOL
TALK2KEV
Reged: 03/08/06
Loc: Oklahoma
[Re: TALK2KEV]
#5315978 - 07/13/12 12:46 PM
HBX in up to date going to do a couple test
Tmohr36
Reged: 09/27/10
Loc: Nevada
[Re: Starhawk]
#5316001 - 07/13/12 01:00 PM
-Rich
Rich,
I did a 315 second exposure (5:15) with my t2i and a 120 second Drift checking exposure with Arcturus (and surrounding stars). Results are here:
http://www.flickr.com/photos/56510505@N04/7166696732/in/set-72157629942853026
bumps in the star trail = PEC the fact that the trails are not on top of each other indicate distance from proper polar alignment (I believe anyway)
BTW, I only use this mount in Polar mode, I have an LS-8 for Alt-Az and CGEM for AP.
Tom Mohr
Tmohr36
Reged: 09/27/10
Loc: Nevada
[Re: Tmohr36]
#5316042 - 07/13/12 01:21 PM
Andrew,
You'll forgive me for posting this here (I hope), but I did the 1 hour test after doing a 1 star fake alignment this morning. Here are my results.
Local time: 0910 Star: Sirius RA: 06:45.0 DEC: -16 degrees 41'
Local time: 1010 RA: 06:44.4 DEC: -16 degrees 41'
I guess that shows the small amount of drift you discussed earlier in the thread.
I'll add a note here, during the Venus transit and the solar eclipse this past May and June, I had the mount set up, pointed north, accepted the two stars during alignment. After alignment successful, slewed and centered the Sun and let the mount go. Over the 4+ hours of Venus transit, I only made minor corrections every 30 minutes or so to recenter the Sun at 50x magnification through the 8" SCT.
Tom Mohr
Starhawk
Reged: 09/16/08
[Re: Tmohr36]
#5316100 - 07/13/12 01:47 PM
This is progress! What was the focal length? What we want is image angular size per pixel. So that means figuring out how wide the field of view is in your telescope, then rotate the image to line up with a vertical or horizontal marker, then find the coordinates of high and low peaks and multiply by the angular size of the image width divided by the pixe size of the width.
Longer trails are needed, though. It's best if you can get three revolutions of the worm, and that makes it possible to see what the periodic element is.
-Rich
TALK2KEV
Reged: 03/08/06
Loc: Oklahoma
[Re: TALK2KEV]
#5316129 - 07/13/12 02:14 PM
Test before firmware update
A2S6 firmware using LX55/75 ra rate +2.75075 Dec rate +2.75075
4.07.30am ra 18:38.1 Dec +38.47'
4.19.11am ra 18:43.4 Dec +38.47'
4.32.35am ra 18:49.4 Dec +38.47'
4.41.55am ra 18:58.2 dec +38.47'
4:52.19am ra 19:05.4 Dec +38.47'
5:01.08am ra 19:09.4 Dec +38.47'
5:05.36am ra 19:11.2 Dec +38.47' alt +44.28.15 Az 292.13.36
After letting the mount track for hour selected the star again Goto
5:0812am ra18.37.4 dec +38.47' alt +37.42.15 az 294.55.53
TALK2KEV
Reged: 03/08/06
Loc: Oklahoma
[Re: TALK2KEV]
#5316139 - 07/13/12 02:25 PM
Both test was done using (fake) One star test data after firmware up date
A3S1 firmware unsing LX80 at default rates ra +2.75075 dec +2.75075
4.06.05am ra 18.37.2 dec +38.47' alt +49.18.03 az 290.32.34
4.16.33am ra 18.41.8 dec +38.47' alt +48.18.22 az 290.52.55
4.23.30am ra 18.45.6 dec +38.47 alt +47.18.50 az 291.12.40
4.36.20am ra 18.52.6 dec +38.47' alt +46.39.09 az 291.26.04
4.46.50am ra 19.03.01 dec +38.47' alt +46.34.20 az 291.28.27
5.01.45am ra 19.10.08 dec+38.47' alt +45.12.10 az 291.57.20
asking the mount to center in Goto
5.05.59am ra 18.37.5 dec+38.47' alt +38.12.20 az 294.42.05
exparrot
Reged: 02/13/12
Loc: DFW, TX
[Re: TALK2KEV]
#5316218 - 07/13/12 03:24 PM
Here's my fake 1-star test data.
Firmware: A3S1 RA/DEC ratios: +02.75075
START - 13:07 CDT RA 06:45.1 / DEC -16*41'
FINISH - 14:07 CDT RA 07:14.9 / DEC -16*41'
Jerry
OzAndrewJ
Reged: 11/30/10
[Re: Tmohr36]
#5316391 - 07/13/12 05:54 PM
Gday Tom/All
Andrew,
Absolutely. The more in the one thread, the merrier.
Also Thks to Kev and Jerry for cross checks.
Now it gets interesting.
David was reporting about a 20 to 30 RAmin "increase" in RA
over a one hour test when polar. Ie running horribly slow.
My bench tests using LX90 motors, (but LX80 selected in the Hbx)
gave a 0.6 RAmin "decrease" in RA over one hour.
Ie i "sped up"
This 0.6 RAMin perHr lines up with the 1.01155 factor i saw in the code.
Getting Toms results this morning cheered me up a bit
as his numbers agreed with mine.
However
both Kev and Jerrys results agree with David
ie they show an RA "increase" of about 30 RAmins per hour
ie running at 50% speed.
The fact the "gotos" appear to work would indicate the
encoders are working correctly, so all i can think of now
is there are different motorcards out there,
and one lot has a problem with its internal motor speed loop.
That sorta gets destroyed by the fact that Davids scope ( at least )
tracks perfectly in AltAz.
I guess the next step is for Kev and Jerry to do real sky
altaz then polar tests, to confirm the results,
ie AltAz works but Polar keeps track of position, but tracks slow.
Edit.
To test the encoder theory under a real sky, do a proper polar setup/ align then do a goto and centre the target.
If it is clearly drifting after that, just let it go for say 10 minutes or more.
Now, without doing anything else, just hit goto again.
The scope will still have its prev targets coords loaded, so if it detects a delta between current and target, it will slew back to target.
If the scope slews back and recentres the target correctly, that proves that the scope still knows "where it is" ie the encoders etc are working, just its not tracking.
It is certainly looking weird.
Andrew
Edited by OzAndrewJ (07/13/12 08:01 PM)
Wigleydh
Reged: 10/26/07
[Re: OzAndrewJ]
#5316496 - 07/13/12 07:32 PM
Tom thank you for providing more data.
I notice that Tom mentions using his during the the Venus transit, which was almost a month prior to Kevin getting his LX80 on (06/28 I think as the 1st test was the night of 06/29). I don't see any solid info about when the rest were received. Can we list data on that?
We might want to compare when Tom, David, Jerry, and Kevin got their mounts. Could the ones having the issue of slow RA in polar, all be mounts from the 2nd batch shipped?
exparrot
Reged: 02/13/12
Loc: DFW, TX
[Re: Wigleydh]
#5316566 - 07/13/12 08:31 PM
I got mine on 7/3. I've only been able to log about 3 real-sky hours in AltAz. No problems with gotos or tracking in that mode.
Jerry
