General Astronomy >> General Observing and Astronomy
Pages: 1 | 2 | 3 | (show all)
mark8888
Reged: 09/24/10
Re: does anyone view with a full moon? new [Re: plav1959]
      #5304924 - 07/06/12 07:20 AM Attachment (20 downloads)
Yep, besides planets while the full moon is up, I love viewing the full moon itself. Anyway, as someone commented earlier, it often isn't quite full even when it appears that it is. Here's a recent example, to the naked eye it looked full, but you can see that it isn't. It looked amazing at the eyepiece.
Full version here: MOON
desertstars
Reged: 11/05/03
Loc: Tucson, AZ
Re: does anyone view with a full moon? new [Re: mark8888]
      #5305041 - 07/06/12 09:21 AM
Full version here:
Beautiful image, and one that illustrates my point perfectly. I spent an entire lunation this past spring going out and observing the Moon every day of the cycle. I expected the day either side of Full to be among my shorter sessions, but instead they were among the longest. There's a lot to be seen, as this image shows. It can be a challenge to identify features peeking up at you over the limb. It's enormously gratifying when you succeed.
mark8888
Reged: 09/24/10
Re: does anyone view with a full moon? new [Re: desertstars]
      #5305081 - 07/06/12 09:48 AM
Thanks, and yeah absolutely, there's really a LOT to be seen at every phase of the moon, including full. It's funny. When I first got a scope, it was like, oh cool, look at the moon! Then, it becomes a bit of, oh, look at that source of light pollution. But finally, with a more experienced eye, well, it's just incredible. How can you not be into looking at mountains on a body in space? As clear and distinct as mountains you see on earth as you fly in an airplane, but in space?! Or looking deeply into craters? It's just unbelievable.
(Oo by the way, I neglected to put in the link to the full version of the pic above, I just added it)
SmoothJazz
journeyman
Reged: 07/05/12
Re: does anyone view with a full moon? [Re: plav1959]
      #5305268 - 07/06/12 11:53 AM
I do not view with a full moon, and I do not suggest you do either. While yes, as people have ponted out, you can still see the planets and bright deep sky objects, you are missing out on the good targets, that require a new moon to see.
Reged: 06/16/04
Re: does anyone view with a full moon? new [Re: SmoothJazz]
      #5305396 - 07/06/12 01:18 PM
One of my favorite quotes:
"Do not let what you cannot do interfere with what you can do." John Wooden.
Yes, there are targets I cannot see when the moon is full or nearly full (as it will be tonight) but there is still plenty to see and enjoy. If limited my observing to those nights when everything was just right to see the faintest possible objects, I would miss out on a lot.
Tonight for example, the moon is nearly full, about 90% illuminated and rises only 25 minutes after astronomical twilight, certainly not an ideal night for hunting down the faintest fuzzy's.
But it will be clear, the skies transparent and the seeing quite good later in the evening. Check out the Clear Sky Clock, if all goes as planned, I am certainly going to have some fun tonight.
BigC
Reged: 09/29/10
Loc: SE Indiana
      #5305475 - 07/06/12 02:07 PM
So the Moon is not a good target?
Hmmmm.
I amused myself in the late night heat playing around with a couple small scopes and spent an hour or so finding just which of my eyepieces worked best with a 80mm tabletop Galileo Dob.Said Dob actually has very smooth movement and is fine on a patio table.It also is very lightweight and looks impressive sitting in the living room which is its usual place while i use more advanced scopes.
160x was the limit,beyond that the Moon's image became too faint and grainy.Amazingly that is the oft quoted "2 times the objective in mm" rule.I've gone higher power with a bigger scope.
I saw dramatic contrasts at the limbs,numerous areas of darker patches,and picked out more detail on crater floors that appeared smooth in a 25mm but showed many neat little? craters using 2.5mm.Probably the best high power combo was Celestron 17mm plossl and Meade 5x telenegative.A 12mm EP and 5x was too faint to view.12.5mm and 5x was acceptable but a little washed out..
desertstars
Reged: 11/05/03
Loc: Tucson, AZ
Re: does anyone view with a full moon? new [Re: Jon Isaacs]
      #5305901 - 07/06/12 06:58 PM
When you add the Moon to planets, double stars, and DSOs faint and otherwise, there will always be something to observe on a clear night, whether you are under dark skies or dealing with an urban glow.
mantrain
Reged: 07/22/11
Loc: San Diego
      #5306656 - 07/07/12 12:08 PM
re astronomical twilight, about how long after sunset is that? I am thinking as another as implied about 90 minutes?
then there is atronomical dusk. is that substantially more dark than twilight?
and what should I do to avoid "twilight zone" while observing alone?
ColoHank
Reged: 06/07/07
Loc: western Colorado
Re: does anyone view with a full moon? new [Re: mantrain]
      #5306710 - 07/07/12 12:51 PM
Most of the guys in my club prefer observing DSOs, and most of our public outreach events are scheduled to coincide with the new Moon. This month, however, we're devoting one event to the waxing gibbous Moon because the skies don't get dark enough for DSOs until very late. Our guests enjoy seeing faint fuzzies, but being able to see the detail on the Moon is a real crowd-pleaser.
SmoothJazz
journeyman
Reged: 07/05/12
Re: does anyone view with a full moon? new [Re: BigC]
      #5306931 - 07/07/12 03:16 PM
Hmmmm.
I'm not sayit the moon is not a good target. My answer was more geared toward the topic starter, as a 16 inch dob is not really designed for mooon observing, and the moon would appear much too bright without a moon filter.
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
      #5307248 - 07/07/12 08:05 PM
The length of twilight depends on your latitude and the time of year. At latitude 40N, 90 minutes from sunset to the end of astronomical twilight is a good rule of thumb. But right now, near the solstice, it's closer to 2 hours.
By tradition, twilight is divided into three zones: civil, nautical, and astronomical. See my blog on civil and nautical twilight and my blog on astronomical twilight.
mantrain
Reged: 07/22/11
Loc: San Diego
Re: does anyone view with a full moon? new [Re: Tony Flanders]
      #5307426 - 07/07/12 10:02 PM
seriously Tony you enjoy naked eye observing more than w telescope?
anyways I looked at your chart and from that I guess astronomical twilight occurs about 1 hour 10 min after sunset for where I am (San Diego).
craytab
Reged: 06/10/11
Loc: Bethlehem, PA
      #5307963 - 07/08/12 09:51 AM
I was skeptical about Tony's naked eye and bino claims as well until I got to a good dark sky. I spent a bunch of time looking at stuff first naked eye, then with bino, and last with telescope. What Fun!
No need to guess or calculate the various twighlights. You can get the info from any number of many webpages. I have a calendar linked to my phone that shows it anytime I want. Here is such a webpage: http://www.wunderground.com/sky/ShowSky.asp?CurDir=Up&TheLat=32.72109985&TheLon=-117.16430664&TimeZoneName=America/Los_Angeles
tejasdragon
Reged: 09/08/11
Loc: Garland, Texas
Re: does anyone view with a full moon? new [Re: craytab]
      #5308006 - 07/08/12 10:29 AM
If you use Cartes du Ciel the clock app has the twilight
times.
Henry
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: does anyone view with a full moon? new [Re: tejasdragon]
      #5308021 - 07/08/12 10:42 AM
Odd that people would complain about the moon being too bright, wouldn't complain if they could see small craters and individual mountains on Mars, Venus, Jupiter, or individual ice crystals in Saturn's rings. I do not consider the moon an irritant; I consider it an opportunity.
panhard
It's All Good
Reged: 01/20/08
Loc: Markham Ontario Canada
Re: does anyone view with a full moon? new [Re: csrlice12]
      #5309873 - 07/09/12 01:56 PM
I will go out during a full moon and times near it. I view double stars and clusters then. Also I put in my variable polarizing filter to view the moon itself it is amazing through my 10" dob.
CounterWeight
Reged: 10/05/08
Loc: Cloudyopolis, OR.
Re: does anyone view with a full moon? new [Re: panhard]
      #5313825 - 07/12/12 07:38 AM
What a luxury some of you have, that of being able to choose. Many times of the year I am so clear sky starved that opening in the grey dome is graciously enjoyed no matter what is or isn't up. Often it will only clear on or near the full moon. Jus sayin'.... if i waited for more ideal it could be half a year...
seattlepete
Reged: 01/29/12
Loc: Uh...seattle.
      #5315406 - 07/13/12 02:22 AM
With only two good months of viewing here North of Seattle each year, I am out EVERY night it is clear, moon or no moon!
Escher
Reged: 08/30/07
Loc: Fenton, MI
Re: does anyone view with a full moon? new [Re: seattlepete]
      #5316030 - 07/13/12 01:12 PM
During fall / spring I will observe any chance I get. Winter I'm more selective, but then again - M42 doesnt care about the moon..
In summer, I'm picky - lately, planning vacations around new moons. I've been out 3 - 4 hours each of the last two nights.
craytab
Reged: 06/10/11
Loc: Bethlehem, PA
Re: does anyone view with a full moon? new [Re: Escher]
      #5316073 - 07/13/12 01:33 PM
Really? I can get a lot more of the faint wisps out of M42 without the moon.
9 registered and 10 anonymous users are browsing this forum.
Moderator:  cildarith, droid, tecmage
