Rudra
Reged: 07/02/10
G11 vs G11 Gemini new
      #5304593 - 07/05/12 11:28 PM
Hello Friends,
I have a question. My question is what is the difference between a Losmandy G11 mount and a Losmandy G11 Gemini mount? If you could provide a picture to show the difference between the two, it would be very helpful. Does Losmandy G11 have encoders?
Thank you.
Wouter D'hoye
Reged: 06/27/03
Loc: Belgium
Re: G11 vs G11 Gemini new [Re: Rudra]
      #5304755 - 07/06/12 01:46 AM
A standard G11 just has a motor drive (digital drive system) but not goto. The G11 gemini (or gemini II) has a goto system called Gemini. The visual difference is different motors and larger electronics box for the gemini. Also the gemini II has a graphic control box where the standard G11 just ha sa 4 button control box.
Kind regards,
Rudra
Reged: 07/02/10
Re: G11 vs G11 Gemini new [Re: Wouter D'hoye]
      #5304796 - 07/06/12 02:43 AM
Hello Friend,
Thank you for the answer. The mount that I have just says "G11", no mention of GEMINI or GEMINI-II anywhere. I will try to post pictures of my mount later but thank you so much again for all your help.
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
Re: G11 vs G11 Gemini [Re: Rudra]
      #5305339 - 07/06/12 12:45 PM
The box that you hang on it and plug your controller into, will say Gemini or Digital Drive and this will tell which you have.
Blueman
Anand Rajiva
Member
Reged: 05/11/04
Loc: Bavaria, Germany
Re: G11 vs G11 Gemini new [Re: blueman]
      #5305454 - 07/06/12 01:56 PM
there is no difference in the mount it self, just the electronic differ.
Startraffic
Reged: 02/12/06
      #5309297 - 07/09/12 05:24 AM
Rudra,
The G11 does NOT have encoders built in. They are an add-on. I think JMI & a couple of others still make them, Losmandy does not. Gemini had encoders built into the motors that have fairly good resolution. IIRC Gemini-2 doesn't read external high-res encoders yet but it is on the list of future features. HTH
Clear Dark Skies
Startraffic
39.138274 -77.168898
18 registered and 24 anonymous users are browsing this forum.
