Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | (show all)
justforfun
newbie
Reged: 08/28/08
Loc: Lees Summit, MO USA
Re: 17" CDK and Equatorial Mounting new [Re: zytrahus]
      #6203196 - 11/19/13 08:41 AM
I have been following this great project for some time.
Might it be possible for you to post some photos of the parts being machined?
I have as much interest in how something is done as what is being done.
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
Re: 17" CDK and Equatorial Mounting new [Re: justforfun]
      #6204889 - 11/19/13 11:20 PM
I'll try to take some pictures of the last parts I'll make as I just finished working on the bearing blocks and housing parts for the Declination sub-assembly. They're currently being anodized, and I will probably put them together this week-end.
I finished the floors of the observatory. I ended up using 2x6 12" on center that's all I had. Joists are covered by 23/32" plywood. The whole thing seems pretty strong.
to the walls now..
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6206451 - 11/20/13 08:55 PM
here's the first wall - I need a second pair of hand to get it in place though ^_^
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6212341 - 11/23/13 11:15 PM
I've got the 4 walls up - I'll cover them with OSB tomorrow, then probably do the concrete for the two footings that will hold the structure for the roll-off rails.
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6214028 - 11/24/13 08:48 PM
Today I got the OSB done on the 4 walls and the siding on 3 of the 4 walls.
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6242520 - 12/09/13 12:11 PM
I haven't been super lucky with the weather lately - ~6in of snow on Saturday kept me from doing the last footing and lay the structure for the roll-off rails. It's looking better for next week-end.
Meanwhile, I started working on the new CF tubes since the original length was slightly too long for the final specs of the optics. I ended up using thicker wall and larger OD for the CF tubes (redoing the tube ends and support).
I've got the DEC shaft done as well as the two bearing blocks for DEC (you can see those on the pic below).
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6256520 - 12/16/13 03:42 PM
My optics are finally here!
I have next week off so I should be able to get a bit of work done.
R Botero
Reged: 01/02/09
Loc: Kent, England
      #6256668 - 12/16/13 05:20 PM
Great news Stephen! Looking forward to seeing the mirrors mounted.
dmcnally
Reged: 03/17/12
Loc: Lompoc, CA
Re: 17" CDK and Equatorial Mounting new [Re: R Botero]
      #6261741 - 12/19/13 11:28 AM
Thanks for sharing the build process. I just found this thread and I think your design and craftsmanship is awesome.
Next is the second Delrin washer and the installation of four M3x8 dowel pins. These will force the whole clutch to spin with the shaft and preventing to loosen/tighten. Since I use a “captain wheel” that screws onto the shaft to compress the clutch spring,
The quote above is from your "EQ-Z – RA Housing and Shaft Assembly (Part 1)" web page.
Do you have any pictures you could post of the clutch spring assembly that show how it mates to the dowel pins?
thanks,
Dave
seryddwr
Innocent Bystander
Reged: 02/19/10
Loc: La-la land.
Re: 17" CDK and Equatorial Mounting new [Re: dmcnally]
      #6261802 - 12/19/13 12:13 PM
Stephen, a lot of the early pics in this thread are showing the broken image icon. Is the website where you were hosting them dead?
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
Re: 17" CDK and Equatorial Mounting new [Re: seryddwr]
      #6261830 - 12/19/13 12:34 PM
Dave:
Here's a quick section view that shows the pins (you can only see 2 of the 4 in this view).
Greg:
yes, I decided to move my WP.com to a WP.org blog. While I was able to have all the images working on the new blog, most of the forums links are broken, and most CN posts are old enough that I can no longer edit them.
all pictures are available on the blog though (zytratech.com)
dmcnally
Reged: 03/17/12
Loc: Lompoc, CA
      #6261868 - 12/19/13 12:55 PM
Hi Stephen,
Thanks for posting the drawing. Again, fantastic craftsmanship on the mount and the CDK.
thanks,
Dave
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6263903 - 12/20/13 02:53 PM
I haven't opened up the optics yet, however I finished putting together the DEC gear housing. Just like for RA, the rolled aluminum part is one of the few parts I didn't do and I am not super satisfied with the respect of tolerances, not a big deal since I kind of expected and took that into account.
With a bit of luck I should be able to do the roof next week, in which case I could finally start finalizing the assembly of the mount.
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
      #6269611 - 12/23/13 10:32 PM
The roll-off structure is finally done.
Uploaded with ImageShack.us
Hoping to have a roof before the end of the week
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
      #6270695 - 12/24/13 01:37 PM
Stephen,Looks like things are coming along nicely.
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
Re: 17" CDK and Equatorial Mounting new [Re: tim57064]
      #6278324 - 12/29/13 12:24 AM
Just gotta put on the shingles and the roof will be done
MKV
Reged: 01/20/11
      #6278906 - 12/29/13 10:56 AM
Stephen, you do realize everyone is holding their breath and waiting for the jaw-dropping finish and some deep sky photos. That's truly an amazing project.
regards,
Mladen
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
Re: 17" CDK and Equatorial Mounting new [Re: MKV]
      #6279273 - 12/29/13 02:20 PM
Thanks Mladen, I'm holding my breath too haha
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #6279306 - 12/29/13 02:44 PM
You could always remake the DEC gear cover out of a solid piece.
The other day I ordered a 4"x13"x17" piece of 6061 to mill a DEC housing from for my Series II.
zytrahus
Reged: 06/16/09
Loc: Long Beach, CA
Re: 17" CDK and Equatorial Mounting new [Re: TxStars]
      #6279480 - 12/29/13 04:19 PM
Yep but it won't be worth it, there isn't that much of a gap and it doesn't affect anything.
19 registered and 22 anonymous users are browsing this forum.
