s2jesse
Reged: 01/17/05
Loc: Sonoma County, CA
Flexure new
      #5346325 - 08/01/12 01:48 AM
So ive been working from square one on really setting up my imaging system.
I think i have an extremely rigid setup but TPoint is showing a lot of flex in my setup.
Ive noticed a good amount here in my focuser. With the ccd etc hanging off...
http://www.youtube.com/watch?v=LSMx7XlkIbI
Is there a way to eliminate some of this give?
its an fsq106edxiii
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
Re: Flexure new [Re: s2jesse]
      #5346357 - 08/01/12 02:50 AM
Hmm, wish I had some experience with the TAK, but I do not. Sure seems like something could be adjusted to lessen that, it is a lot of flexure.
Blueman
mikeschuster
Reged: 08/25/11
Loc: SF Bay area
      #5346363 - 08/01/12 02:58 AM
Jesse,
Check out the instructions here to tighten up the focuser and CAA. If this is not sufficient you can remove the focuser entirely and replace it with a fixed adaptor from PreciseParts and an Atlas.
SteveProcter
Reged: 03/21/09
Loc: UK
      #5346496 - 08/01/12 06:48 AM
That is way, way too much movement in the focuser. Did you buy the scope from a dealer? If so, I'd return it and ask them to resolve the issue.
The focuser on my FSQ 106ED shows some sag (but not as severe as on yours) when used with a fairly heavy imaging load (6Kg) and I was advised to have the focuser upgraded to the latest version used on the EDXIII. Apparently it involves changing a pair of focuser tube tube supports inside the focuser to a more robust deign. I will be doing that in the near future. But I guess yours should already have the latest version.
Steve
s2jesse
Reged: 01/17/05
Re: Flexure new [Re: SteveProcter]
      #5347334 - 08/01/12 05:06 PM
Yep its very new
alpal
Reged: 06/15/09
Loc: Melbourne Australia.
      #5347413 - 08/01/12 05:57 PM
I watched the video - I couldn't believe the wobble in that focuser.
I thought Takahashi were top of the range products?
( the price would have you believe that )
You have put me off buying a Baby Q.
alpal
Reged: 06/15/09
      #5347414 - 08/01/12 05:57 PM
deleted due to double post
Edited by alpal (08/01/12 05:58 PM)
s2jesse
Reged: 01/17/05
Re: Flexure new [Re: alpal]
      #5347809 - 08/01/12 10:18 PM
Im gonna look into it tommorow and call tak...one of the reasons I chose the fsq was because I thought the focuser was gonna be awesome. Im currious if somethign is really wrong or if all are actually like this. This is WITHOUT the lock on... Because im using a robofocus.
Edited by s2jesse (08/01/12 10:19 PM)
alpal
Reged: 06/15/09
      #5347997 - 08/02/12 12:29 AM
Please keep us updated.
I thought people used heavy 4Kg SBIG & other cameras with no problem on Taks.
I don't see how if they use Robofocus.
There is something wrong which we don't understand yet.
SteveProcter
Reged: 03/21/09
Loc: UK
      #5348245 - 08/02/12 07:09 AM
Jesse
There is something wrong with your focuser. No focuser should flex the way that yours does but I'm sure Tak will resolve it for you.
The FSQ 106ED is a great scope but is imo let down by its focuser. There is something flawed with its design. From my experience, it works OK with lighter imaging equipment but struggles with heavier gear. I've now removed the focuser on my scope and replaced it with a fixed length adapter and an Atlas focuser. I know of others who have made a similar switch
Steve
s2jesse
Reged: 01/17/05
      #5348980 - 08/02/12 04:19 PM
Yep I talked to Fred over there at Texas nautical he gave me instructions on how to adjust.. Gonna try that first if not ill shoot it over to him and they'll take care if it.
Jesse
mmalik
Reged: 01/13/12
Loc: USA
Re: Flexure [Re: s2jesse]
      #5352668 - 08/05/12 06:11 AM
Jesse, here is the link to my problem which seems the same. Please keep me posted as you get this sorted out.
Daniel Mounsey
Vendor - Celestron
Reged: 06/12/02
      #5602277 - 01/03/13 01:33 AM
I think i have an extremely rigid setup but TPoint is showing a lot of flex in my setup. Jesse, maybe I missed it, but what do you have attached to the focuser weighing it down?
its an fsq106edxiii
There's something up with that particular unit. There's no way there's that much flexure. The focusers are rock solid on them. Jesse, what is it you have attached to the focuser?
15 registered and 20 anonymous users are browsing this forum.
Moderator:  Oldfield, bilgebay
