AstroGabe
Reged: 01/10/10
Loc: SE Wisconsin
Star testing with a diagonal
#5356907 - 08/07/12 06:43 PM
I know that it's suggested to star test a refractor w/o a diagonal. I also know that to get an acceptable star image w/o much atmospheric disturbance, you should find a fairly bright star near zenith. This combination makes for a lot of uncomfortable viewing, especially when you're trying to wait for the seeing to stabilize if for a second.
My question is whether taking the diagonal out is necessary. Is it simply a worry of not having the diagonal not seated squarely in the focuser? Or will a diagonal give some unexpected results aside from a slight miscollimation? On that note, what diagonals would you suggest using in a star test if it's squarely in the focuser?
Gabe
mgwhittle
Reged: 08/24/11
Loc: Chattanooga, TN
Re: Star testing with a diagonal
[Re: AstroGabe]
#5356982 - 08/07/12 07:25 PM
It is possible for a star diagonal to create abberations during the star test. I had a name brand diagonal that had a slightly astigmatic mirror.
Having said that, I would use whatever diagonal you have to do the test. If you see a problem, then you can remove the diagonal for further testing to determine if the problem is with the diagonal or the scope.
thesubwaypusher
Reged: 07/08/04
Loc: New York City
[Re: AstroGabe]
#5357929 - 08/08/12 12:10 PM
The system should remain in the state that you are observing with. If you observe with the diagonal, then it should stay in during collimation.
Good luck, Chris
dan_h
Reged: 12/10/07
[Re: AstroGabe]
#5358420 - 08/08/12 04:50 PM
Unlike a Newtonian reflector, a refractor uses only a very small portion of the diagonal to form any one star image. At f10 a refractor only uses about 0.2" inches of a 2" format diagonal for any one star. You need to have a nasty diagonal to see a significant error on a spot that small. Even at f5, the surface area of the diagonal that contributes to a single star image is less than a 1/2" diameter. Unless the mirror is very poor indeed, it won't affect your testing.
dan
AstroGabe
Reged: 01/10/10
Loc: SE Wisconsin
[Re: dan_h]
#5358545 - 08/08/12 06:10 PM
Thanks guys for the suggestions and information. I'll just keep the diagonal in place when testing.
Gabe
Reged: 06/16/04
[Re: dan_h]
#5358555 - 08/08/12 06:14 PM
dan
Dan:
True, but the diagonal still could be miscollimated, some are surprisingly bad. This is particularly true of inexpensive mirror diagonals but I had a 1.25 inch TeleVue/Vixeen that was quite bad.
I would test it with the diagonal and if something looks fishy, try it without.
AstroGabe
Reged: 01/10/10
Loc: SE Wisconsin
[Re: Jon Isaacs]
#5358565 - 08/08/12 06:19 PM
I tested my refractor the other day w/ a hubble star unit and found severe astigmatism. It turned out that I needed quite a few extenders to move the eyepiece back since the artificial star was so close (about 40 ft). The extenders either weren't seated squarely or were sagging and gave really bad results. That's when I decided to just go and try it on a real star... No astigmatism on the real thing:)
Gabe
dan_h
Reged: 12/10/07
[Re: Jon Isaacs]
#5359568 - 08/09/12 10:32 AM
dan
Dan:
Jon,
I agree that a diagonal can be poorly assembled or miscollimated but it is surprising how little this actually affects the image. You need a really gross diagonal error to significantly affect the star test.
Assuming 2" from the mirror surface to the focal plane, a one degree tilt in the mirror will displace the image at the eyepiece 0.0349". That's not very much and it can be difficult to maintain the star image on axis within that tolerance without a tracking mount. Even a very poor diagonal with a 2 degree tilt displaces the image only 0.070" or 1.778mm. Of course, this can be easily seen as off axis in an eyepiece that covers a 10mm diameter field.
If one attempted a star test with the image displaced by a tilted diagonal one would simply re-aim the scope to centre the target in the eyepiece. With a 600mm focal length scope the 0.0349" displacement of a one degree diagonal error, corresponds to 0.085 degrees off-axis for the image from the objective. That is a very small misalignment and I seriously doubt it would appreciably affect the image in a star test. The angular displacement is proportionally less in a longer focal length scope and it would be even more difficult/impossible to see any affect on the star test.
Perhaps there are others who are considerably more experienced than I am but I remain skeptical when I see reports of how much a refractor can be improved by minor adjustments to collimation errors in diagonals and focusers.
dan
AhBok
Reged: 12/02/10
[Re: dan_h]
#5359643 - 08/09/12 11:04 AM
Dan,
I have always collimated refractors that have a non-collimatable cell by adjusting the focuser. One example is my Orion ST-80 guidescope. It was way out of collimation and I simple capped the tube, inserted my cheshire and repositioned the focuser until the collimation was perfect. A mis-collimated diagonal will definitely throw your overall collimation out on a doublet refractor. Try it--it is easy to test and see.
dan_h
Reged: 12/10/07
[Re: AhBok]
#5359773 - 08/09/12 12:12 PM
Dan,
I agree that a miscollimated diagonal will affect overall collimation in a measureable way. With a cheshire site tube you can detect very slight alignment errors. I don't agree that you will easily see it in a star test and I believe that was the original question.
Also note that a diagonal tilted one degree does not impart the same error to the image as the objective tilted one degree would. A tilted diagonal shifts the image about 0.035" for one degree. A tilted objective shifts the image about 0.0175 X the focal length for the same tilt, or about 0.41" for a 600mm focal length. Hence, the tilted diagonal has minimal impact on what you see in the eyepiece whereas the tilted objective puts the target right out of view and the centre of the eyepiece view is the image one degree off axis.
However, when you put the cheshire sight tube into the tilted dialgonal, you will see the error projected onto the objective and it will appear to the same 0.41" or so off centre in the objective. This is easy to see and can be corrected but the end affect on the image in the eyepiece is insignificant.
I remain a skeptic.
Focuser alignment is a different story.
dan
Reged: 06/16/04
[Re: dan_h]
#5360268 - 08/09/12 04:46 PM
Dan
All reasonable points. Still. I have seen st-80 diagonals that were misaligned enough that a laser hit the tube wall or that an eyepiece vignetted.
dan_h
Reged: 12/10/07
[Re: Jon Isaacs]
#5360374 - 08/09/12 05:46 PM
Dan
Ouch! One doesn't need a laser to see a diagonal that is bent that much. And yes, that would affect cause some grief.
dan
