ki_cz
Reged: 02/05/08
5D MarkIII worth the additional money for astro? new
      #5111735 - 03/08/12 01:24 PM
I was already settled on the MK2 prior to the announcement, I'm still at a crossroads in terms of making up my mind.
My current setup is a Canon 40D with the following lenses:
Tamron 17-50 f/2.8
Carl Zeiss Jena 135mm f/3.5 (M42)
Takumar 200mm f/4 (M42)
Pentacon 300mm f/4 (M42)
Pentacon 500mm f/5.6 (M42)
MTO 1000mm f/11 (M42)
You can see some examples of what I shoot in my history on this site, although this is quite limited and in many cases outdated. My most recent work can be found on my www.15sunrises.com webpage.
The fact of the matter is that without question, I'm going to be upgrading to full frame, with the Canon 24-105 lens. I've chosen this one as it will finally bridge the gap (~80mm) that I've been missing for quite some time on my 40D. I may also get a wider angle prime (if I decide to experiment with untracked exposures), but would prefer to keep my weight down as my pack is already heavy enough as it is when going on shoots.
Now, in terms of the moon shots, I'm certain that the MKII and MK3 would perform equally as well, there is rarely a time that these shots require an ISO of above 800 on my 40D, therefore I think the difference between the two cameras would be negligible.
My question relates to star shots. Up to this point, I've been stacking tracked and untracked exposures in photoshop (tracking with the astrotrac), usually with exposures ranging from 3-5 minutes at ISO 640-800. This means that a single shot basically takes around 20 minutes to complete (5 minutes tracked + dark frame subtraction and then 5 minutes untracked + dark frame subtraction). Ideally, I would like to get this time down in order to be more productive, and would like to do this by increasing ISO. I also think that the 24-105 will be higher quality than my Tamron, so I may not have to stop down as much to keep everything sharp. I'm wondering what people think the quality difference will be in terms of ISO1600 and ISO3200 files in RAW between the two cameras. All I've heard so far is information regarding improvements in JPG noise, which seems to be due to new processing in the chip. I will always be using a tracking device, but just want to get the times for individual shots down. When printing at A2 sizes, trailing is already readily visible with 30second exposures at 17mm on a crop, and I'm further looking to start printing at A1 or even A0 sizes, where trailing will be evident at even shorter exposures.
Really don't know if my point got across at all here, but I've been wavering between these two since the announcement of the Mark3 and am looking for any advice. Thanks.
Hikari
Reged: 01/05/11
Loc: Maine, USA
Re: 5D MarkIII worth the additional money for astro? new [Re: ki_cz]
      #5111799 - 03/08/12 02:15 PM
Here are RAW samples from the 5DMkIII:
http://www.imaging-resource.com/PRODS/canon-5d-mkiii/canon-5d-mkiiiTHMB.HTM
nofxrx
Vendor (HyperCams & Mods)
Reged: 07/12/05
Loc: Palm Bay,Florida
Re: 5D MarkIII worth the additional money for astro? new [Re: Hikari]
      #5112267 - 03/08/12 06:53 PM
This is your first issue. You should never let the camera take an "Auto Dark". YOu are wasting precious star time letting the camera take the darks.
PLUS, those are NOT efficient at actually reducing your overall noise!!!!
You need to spend all of your time, AT NIGHT, capturing LIGHT frames. Take the darks yourself later when tearing down your equipment, or the next night out when it is cloudy(if the temps are similar,etc)..
There is a LOT of logic and reason behind these two statements..and I am not going to get into it more that this..but, I really suggest you read some of Jerry's(Lodriguss?) books/online books...
Now, RE: Mark II VS Mark III..
This will ALL be speculative til we actually get our hands on one...
But, being an owner of a modified Mark II, I can tell you, it is going to be quite an amazing feat if they actually improve on, what MANY call, the BEST DSLR for AP(currently available, and for the $$$!).
The Mark III has been shown already to produce about 1-2stops better than the Mark II **in JPEGs** out of the camera thanks to some new noise reduction in-camera processing.
Raw files on the other hand are only looking to be about 1/2stop better than the Mark II..which is not a giant leap forward...
Canon DID NOT DESIGN THIS CAMERA TO IMPROVE THE IMAGES of the 5D line. The only *REAL* improvements are the AF system, which is coming from the 1Dx's new AF system.and that is a $7k camera. So to put an AF system in like that, this is EXCEEDING people's expectations for the Mark III, because most simply wanted a blend of the 7D and 5D Mark II..keep the same brilliant ~21mp Full Frame Sensor, keep the AMAZING images and sensitivity. BUT install a USEABLE AF system.
The ONLY reason I AM going to buy a Mark III, is so that I do not have to use TWO cameras(5D Mark II and a 40D/7D) for all of my imaging needs. The Mark III is exactly what I had hoped it would be..brilliant AF system but with the same sensor and tech(no need for 38mp like some wanted...WHY??when you sacrifice sensitivity and pixel size, noise,etc just to get more MP...I can tell you what, I can easily crop my 5D2's images MUUUUUUUCH more than I can a 7D's..and the pixels in the 7D are ~2um SMALLER!!!)
the point is. the 5D Mark II is NOT GOING anywhere! It IS a remarkable camera, and will continue to be a remarkable camera.
But the Mark III is being marketed to those people that shoot sports/action/wildlife,etc that NEED that advanced AF system...all while keeping the same beautiful images that the Mark II produces...
AND IF, IF, they can actually get even a little(1/2 stop is plenty IMHO) better performance from the Mark III images, GREAT!!! if not? who cares!!?
SO. My question to you would be;
Do you NEED a VERY advanced AF system?
that should really be the only deciding factor when choosing between these two.
And if so, is it worth the ~$1500 MORE over the Mark II just to have a better AF system.
To me? YEP!!!
but, not everyone will agree/have the same criteria..
If you want/wanted a Mark II, NOW is the time to buy one as people are dumping them for REDICULOUSLY cheap prices just to pre-order the Mark III, which is the usual trend..but it will disappear quickly, too...(I am talking as low as $1500 for a VERY good condition used unit!!!).And at those prices, to me, it is a no brainer...ANYONE who has thought about upgrading to the full frame Mark II, NOW is your time to do so...
Take it however you want..but I sorta do this for a living , and am just trying to be honest..
Again, my 2's..
Good luck!
nofxrx
Reged: 07/12/05
Re: 5D MarkIII worth the additional money for astro? new [Re: nofxrx]
      #5112274 - 03/08/12 06:55 PM
Sorry. I forgot the actual initial question(title of the post.lol)
For AP, I seriously doubt there will be much, if any, difference in IQ(Image Quality)..
Hikari
Reged: 01/05/11
Loc: Maine, USA
      #5112484 - 03/08/12 09:13 PM
Well, you should be getting more than just AF. Even if it is just better operation. It looks like a better built camera as well. You should get a bit better IQ, but most most model changes are modest increases in IQ--folks generally blow that out of proportion.
Look at the specs and decide if the extra money is worth it to you. This is not a logical of rational decision beyond whether you can afford it. But the 5DMkII is getting a little long in the tooth. I would wait until the camera has had some good reviews.
I find buying the best camera you can afford saves money in the long run.
Kim Miau
Reged: 07/17/06
Loc: Malaysia
      #5354526 - 08/06/12 10:04 AM
Have there been any CNers using 5D MkIII for astrophotography these days?
p.s. Sorry to revive an old thread but I would like to see if things have changed.
SunBlack
Reged: 05/05/11
Loc: Rome (IT)
Re: 5D MarkIII worth the additional money for astro? new [Re: Kim Miau]
      #5355923 - 08/07/12 04:12 AM
Hi there, i read the interesting article in S&T about 60Da. Quoting: "A feature I was hoping for in the 60Da
is one off ered only in the 5D series — the
ability to buff er up to fi ve images in the
camera and then take a single dark frame
that’s applied to all of them. ". I own a 5D mkIII, how do in my camera that ? thanks
Fogboundturtle
Reged: 05/20/09
Loc: Burnaby, BC
      #5356211 - 08/07/12 10:07 AM
I have an 5D3 but I am not an 100% in operation yet. I will let you know in a couple of weeks
Kim Miau
Reged: 07/17/06
Loc: Malaysia
Re: 5D MarkIII worth the additional money for astro? new [Re: Fogboundturtle]
      #5356215 - 08/07/12 10:09 AM
Thanks. I am looking forward to hearing from you. By the way, do you have any 5D2 which you can compare side by side?
rainycityastro
Reged: 03/29/10
Loc: Seattle, WA
      #5356889 - 08/07/12 06:28 PM
I read a very in-depth review on the 5d3(Lloyd Chambers' paid site: highly recommended). The results aren't very encouraging. There is quite a bit of pattern noise. Also dynamic range is sub-par compared with Nikon. Lloyd's conclusion: at best a 12bit sensor.
I would not worry too much about the above issues if I was spending under $1000 but at over $3000, I don't believe it is a worthwhile investment for astro.
alpal
Reged: 06/15/09
Loc: Melbourne Australia.
Re: 5D MarkIII worth the additional money for astro? new [Re: rainycityastro]
      #5356925 - 08/07/12 06:53 PM
I am at the point of buying a QHY10. about $2400.
I don't think a 5D is worthwhile for astro because I
have found that my Canon EOS1000d is ok in winter
but hopeless in summer due to thermal noise.
Hikari
Reged: 01/05/11
Loc: Maine, USA
      #5357366 - 08/07/12 11:37 PM
It sounds like Lloyd is having a bit of a hissy fit. He is becoming more cantankerous as time goes on. If the 5DmkII is great for astro, then the 5DmkIII is going to be as well--DxO Mark shows them equal or the mkIII slightly better.
Kim Miau
Reged: 07/17/06
Loc: Malaysia
      #5357400 - 08/08/12 12:07 AM
One of the many things that concerns me is Canon applied a "black-box" noise reduction algorithm when the signal is readout from the signal and before it hits the .CR2 file.
Source:
Each photodiode is equipped with an underlying transistor that provides initial noise processing at the instant of signal transmission. This means that the EOS 5D MK III can achieve a nominal sensitivity of 25,600 ISO, extendable up to 102,400 ISO in H2 mode. According to Canon, an image shot at 25,600 ISO should be completely usable.
-- DxOMark
Hikari
Reged: 01/05/11
Loc: Maine, USA
      #5357744 - 08/08/12 09:52 AM
Why? The resulting image is really the point.
Kim Miau
Reged: 07/17/06
Loc: Malaysia
Re: 5D MarkIII worth the additional money for astro? [Re: Hikari]
      #5357751 - 08/08/12 09:56 AM
You're right in a way. If you've read Craig's article on Canon DSLR Linearity published recently, you will find out that what Canon has done, reasonably, to the raw file output. This, however, poses a hurdle to the calibration of the images.
From the DxOMarks evaluation of the 5DIII and 5DII, they both don't seem to have a significant difference in dynamic range and sensitivity. But I would like to see how such improvement could translate into real-world difference.
Hikari
Reged: 01/05/11
Loc: Maine, USA
      #5357942 - 08/08/12 12:17 PM
I think if you have a MKII and you are really happy with the results, then the only reason to go to a MKIII would be improvements in things like AF, which are not really going to impact your astro work.
If you don't have either camera, then I would go for the later model.
PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
      #5358038 - 08/08/12 01:23 PM
I've got a Hutech modded 5DII, and had an unmodded 5DII as well. I sold the stock MkII and bought a MkIII purely for the addition of better AF and some other features that don't really apply to astrophotography, as I do landscape photography as well. I haven't done any serious AP with it yet, as the MkII and my STF8300 keep me busy....My poor 60Da is bored too LOL
The fun thing with the MkIII is using a 50mm lens at f1.2, ISO 102K and over exposing the sky with 1 second exposures. Lots of noise, but great for finding stuff!
If I find some time I could do a bit of a shootout, what would you think is a representative test?
jerryyyyy
Reged: 10/06/11
Loc: Stanford, California
Re: 5D MarkIII worth the additional money for astro? new [Re: PGW Steve]
      #5358282 - 08/08/12 03:30 PM
I do a lot of fishing/conservation photography and despite 20 years with Canon decided to not get the 5D III but went over to the "dark side" and bought a Nikon D800. I looked very carefully given my investment in Canon lens and felt the Mark III was a minimal upgrade.... for $3.5k. The images on the D800 with the Nikon lens are all they are advertised to be... try effectively a medium format camera... so all in all I would save your money and forget the Mark III, maybe invest in a SBIG older model which would come in well under $3k.... if you want to do AP with a good device....
Fogboundturtle
Reged: 05/20/09
Loc: Burnaby, BC
Re: 5D MarkIII worth the additional money for astro? new [Re: jerryyyyy]
      #5358328 - 08/08/12 03:55 PM
MP does not equal a bigger sensor. Stop this non-sense. What makes a medium format great is the size of the sensor. I so tired of hearing the same BS over and over again. The D800 is not a medium format camera. Its a Full Frame 35mm camera. An Txi with 36mp would never be equal to an FF sensor of the same amount.
Hikari
Reged: 01/05/11
Loc: Maine, USA
      #5358418 - 08/08/12 04:50 PM
Wow, Fogboundturtle, that is a little harsh. You can disagree, but you can be polite too.
19 registered and 30 anonymous users are browsing this forum.
Moderator:  fishonkevin, tecmage
