MHamburg
Reged: 06/21/06
Loc: Brooklyn, NY/Berkshires, MA
CGEM HC INFO new
      #5363419 - 08/11/12 02:21 PM
I love my two year old CGEM! But it has a persistent quirk. I always put it into Hibernation at the end of a run. But upon awakening, it never shows the correct time and date. All other info is correct. Is this a failing battery or something else? All suggestions are much appreciated.
Michael
RTLR 12
Reged: 12/04/08
Re: CGEM HC INFO new [Re: MHamburg]
      #5363445 - 08/11/12 02:46 PM
Is your RTC turned on? If so, you need to change the battery and see if that is the problem.
Stan
MHamburg
Reged: 06/21/06
Re: CGEM HC INFO new [Re: RTLR 12]
      #5363467 - 08/11/12 03:00 PM
Hi Stan,
RTC is turned on.
Michael
RTLR 12
Reged: 12/04/08
      #5363516 - 08/11/12 03:36 PM
Michael,
Try changing the battery and see if that works. Do you know how?
Stan
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
      #5364087 - 08/11/12 11:43 PM
How do you change the battery stan?
RTLR 12
Reged: 12/04/08
Re: CGEM HC INFO new [Re: wolfman_4_ever]
      #5364126 - 08/12/12 12:06 AM Attachment (4 downloads)
Dave,
The RTC battery is located on the back side of the MC board. You remove the 4 screws holding the control panel and you will see the CR2032 battery.
Stan
MHamburg
Reged: 06/21/06
Re: CGEM HC INFO [Re: RTLR 12]
      #5364539 - 08/12/12 10:48 AM
Thanks a ton. Will post results.
Michael
29 registered and 35 anonymous users are browsing this forum.
