shadowpdiggity
Reged: 07/23/12
Loc: new haven, indiana
rs232 hook up on meade lx80 new
      #5354739 - 08/06/12 12:21 PM
Can't get my cp to find the autostar. Does anyone know what i can be doing wrong.
Reged: 07/06/07
Re: rs232 hook up on meade lx80 new [Re: shadowpdiggity]
      #5354989 - 08/06/12 03:15 PM
Impossible to say without further details.
You'll need a Meade serial cable plugged into the Autostar.
Serial port provided by a USB serial cable.
Program to run the scope with the appropriate driver and given the com port number assigned by the USB serial converter.
Duncan Kitchin
Reged: 12/16/04
Loc: Beaverton, OR, USA
Re: rs232 hook up on meade lx80 new [Re: rmollise]
      #5355049 - 08/06/12 04:09 PM
also, remember to plug in the USB-serial converter into the same physical USB port each time, otherwise it will get a new COM port number and the software won't find it...
shadowpdiggity
Reged: 07/23/12
Re: rs232 hook up on meade lx80 new [Re: Duncan Kitchin]
      #5355112 - 08/06/12 05:05 PM
Went over all that with Dave Douglas. For some reason it just won't find the autostar. It fins that its plugged in but doesn't find the controller.
dmdouglass
Reged: 12/23/07
Loc: Tempe, AZ
      #5355158 - 08/06/12 05:27 PM
As i mentioned on the phone, i think you are down to one of two possible problems.
I guess it could be a bad telco wire connector too....
Either the USB to Serial adapter is not giving good throughput - or the 497 (AudioStar) controller has a bad serial port.
And yes folks.... he is using a new Meade USB to serial converter.
I think if i were you, i would see if you have a friend somewhere who has a known good USB-Serial adapter, and see if you can use it (don't forget to get the drivers).
Short of that, you would need to try a different 497, either a AudioStar version, or the ETX version. Either would plug into the LX80, and ASU would see them.
We did verify that is computer is seeing the USB-Serial device, and we can make it come/go by unplugging/and re-pluggging the USB side.
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
      #5355160 - 08/06/12 05:27 PM
Is it a prolific or ftdi chipset adapter? I have not had good luck with prolific drivers but never had a problem with the ftdi.
shadowpdiggity
Reged: 07/23/12
Re: rs232 hook up on meade lx80 new [Re: Stew57]
      #5355273 - 08/06/12 06:27 PM
I do have an old ETX60 that I can try out the controller from it. If it does see that controller will it be good to use then while I wait for meade to send me a new or repair my other controller.
shadowpdiggity
Reged: 07/23/12
      #5355290 - 08/06/12 06:33 PM
Guess that wont work. It doesnt have the extra serial port. OK. Step 2 then. It cant be that hard.
shadowpdiggity
Reged: 07/23/12
      #5355303 - 08/06/12 06:40 PM
I did just realize something though reading Daves comment. My controller is an Audiostar that has the 497EP program in it. Does that have anything to do with it. Im just guessing at this point.
shadowpdiggity
Reged: 07/23/12
      #5355312 - 08/06/12 06:44 PM
I was looking at Office Depot and it looked like they had the same adapter. Maybe I will just buy it and see. Since computers dont have these RS232 ports no more I dont think anyone I know will have one.
zerro1
Reged: 08/02/09
Loc: Smokey Point , 48.12°N 122.25...
      #5355608 - 08/06/12 10:22 PM
If you are intersted in finding a decent used guide computer that "HAS" and RS232/COM1/DB9 natively? look at Panasonic toughbook CF-74. They can be had very reasonable if you look. Here is one just like the one I use CF-74
shadowpdiggity
Reged: 07/23/12
Re: rs232 hook up on meade lx80 new [Re: zerro1]
      #5356724 - 08/07/12 04:07 PM
Ok. This may just be a shot in the dark, but I'm thinking about loading version 5.9.0 on the updater just to see if it recognizes my controller since it says on start up 497ep and that update specifically says for that program. Will let everyone know what happens when I'm done.
shadowpdiggity
Reged: 07/23/12
      #5357577 - 08/08/12 06:09 AM
No luck with that. Did find problem with cord though.
dmdouglass
Reged: 12/23/07
Loc: Tempe, AZ
      #5357877 - 08/08/12 11:35 AM
You say you did find a problem.
Does that mean it works ??
If not, i will ask a question.
Can you verify the small end of the cord is plugged into the 497 hand controller, and NOT into either of the two serial ports on the LX80 mount.
exparrot
Reged: 02/13/12
Loc: Dallas/Fort Worth, TX
Re: rs232 hook up on meade lx80 new [Re: dmdouglass]
      #5359835 - 08/09/12 12:36 PM Attachment (17 downloads)
I'm also having no luck connecting to the HBX, specifically from the ASCOM Diagnostics utility and SkyTools 3 Pro.
A few weeks ago, I updated the Audiostar firmware to A3S2 to resolve the LX80 RA tracking issue. That went well, no issues. Later, I downloaded the MeadeClassic 5.0.3 ASCOM driver to try out, but at this point, I have yet to get a connection using this driver. I'm running the ASCOM 6/SP1 platform. Not sure what's preventing this from connecting. Anyone have any ideas/suggestions?
I don't have any concerns about the laptop or the USB-to-serial cable - I've used them to connect successfully with a Nexstar and an iOptron mount via ASCOM as well. I'm typically using Skytools 3 to interface with them. But, this just doesn't work with the Meade driver. The 505 cable must be okay or I wouldn't have been able to update the HBX firmware.
I did notice the driver version does not match with the setup filename that I downloaded (see pic), but the download is clearly named 5.0.3 despite the version displayed in the driver setup UI.
Laptop - Dell Inspiron 64-bit Win7 Home
COM port - 3
ASCOM 6/SP1
Driver - Meade Classic (5.0.3)
Meade 505 cable
Sabrent USB-to-serial cable
dmdouglass
Reged: 12/23/07
Loc: Tempe, AZ
Re: rs232 hook up on meade lx80 new [Re: exparrot]
      #5359896 - 08/09/12 01:12 PM
Do you have PHD guiding software. It is a free download. Even if you do NOT guide, the PHD software, with ASCOM 6 and that Meade driver, will (should) connect. It is a simple test. It works for me.
the actual problem may be Skytools 3. This would be a "quick check".
exparrot
Reged: 02/13/12
      #5359993 - 08/09/12 02:11 PM Attachment (7 downloads)
Darn! I thought that might work, David
I grabbed PHD and also reinstalled the Meade ASCOM driver, but still no luck.
Jerry
shadowpdiggity
Reged: 07/23/12
      #5362573 - 08/10/12 10:27 PM
I can't even get the firmware update. Guess I will just keep trying. Called meade and they aren't much help. Keep telling me the same thing over again.
TALK2KEV
Reged: 03/08/06
Loc: Oklahoma
      #5364508 - 08/12/12 10:20 AM
Check COM port on software matches what the USB to serial is set at, a another thing is to plug into the same USB port on computer everytime.
Hope this helps
exparrot
Reged: 02/13/12
Re: rs232 hook up on meade lx80 [Re: TALK2KEV]
      #5365208 - 08/12/12 06:43 PM
I don't know about shadowpdiggity, but I've tried COM ports 1-5 with no luck. Guess I'll try a couple of other approaches - uninstall/reinstall ASCOM 6 and, if that doesn't work, try replacing my USB-to-Serial cable with one that sports an FTDI chipset. The one I have uses the Prolific chipset, which Mark (Stew57) mentioned earlier as being problematic.
Jerry
10 registered and 20 anonymous users are browsing this forum.
