loo27
Reged: 09/30/04
Loc: GA
CG-5 GT computer issue new
      #5364104 - 08/11/12 11:50 PM
I have a 4 yr old cg-5 gt that has worked great for many years. Tonight, i plug in the hand controller, it says intializing, then goes blank, but still lit. Has the hand controller gone bad? the whole mount? Any easy fixes?
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Re: CG-5 GT computer issue new [Re: loo27]
      #5364572 - 08/12/12 11:19 AM
The first question usually asked when it comes to Celestron mounts is what kind of power supply are you using? Celeston mounts are sensitive to voltage drain. If you're using a powerpack, make sure that it's fully charged. Voltage drop off will cause your mount to act like Mr. Hyde.
David
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CG-5 GT computer issue new [Re: David Pavlich]
      #5364588 - 08/12/12 11:31 AM
Cliff,
First take a deep breath, it is very very unlikely there is anything permanently wrong with your mount. If the power is good (source, connections, etc.) you might need to re flash the firmware in the hand controller. Have a read of the website www.nexstarsite.com for info on the connection and how to do the upgrade. There is also a condition where the hand controller is stuck in "initializing" mode where a dummy version of the firmware can be substituted to "unstick" the hand controller.
Mike's website contains a ton of good information to guide you through the steps required to bring back your hand controller.
loo27
Reged: 09/30/04
Loc: GA
Re: CG-5 GT computer issue new [Re: mclewis1]
      #5364988 - 08/12/12 04:32 PM
thanks for the advice! deep breath taken. RE: power source - i'm at home and plug directly in the wall, but did notice it seems the plug into the mount seemed a little loose. I'll follow up on all this advice.
Cliff,
SkipW
Reged: 02/03/11
Loc: Oklahoma, USA
Re: CG-5 GT computer issue [Re: loo27]
      #5365457 - 08/12/12 09:05 PM
The power switch on mine went bad a couple weeks ago. At first I thought it was the power cord, then the battery, but found that if I pushed in on the power switch while turning it on, it was better (for a little while). Eventually it wouldn't stay on at all (handset lights were on, but display went blank). I bypassed the switch with a soldered-on jumper and all's well again.
Before re-flashing the firmware, try the usual power cord tricks (carefully spread the center pin, etc.). If those don't work, try turning the switch on "with authority" and see if it works better. If it does, that may be a sign the switch is failing.
16 registered and 32 anonymous users are browsing this forum.
