Jerry-rigged
Reged: 01/30/12
Loc: Coastal Texas.
ETX60/70 as a finder scope?
#5368014 - 08/14/12 10:10 AM
Howdy gang-
Let me start by saying I like to "think outside the box", but I know sometimes I just end up making things more complicated. So if this sounds too far out in left field, let me know.
I am looking for a finder scope for my 10" dob. I have a Telrad, but I would like something to go with it that give a little bit of light gathering and magnification to help cut thru the sky glow for star hopping. The basic, no base, straight thru 7x50 GSO finder is about $45, and the GSO RACI 8x50 with base is about $80.
But then I start thinking about "other options", small scopes that I could use as a finder scope, but also have the option to use as a stand alone scope, a "grab and go" for quick trips outside... The first two or three options I though of would have set me back $300-$500 (options like the Astro Tech 72mm F6 refractor, almost $400 for the OTA) Then I noticed that ETX60/70's on ebay are often going for $75-$100, sometimes with a few eyepieces or a tripod. If my math is right, one of these scopes with a basic 25mm eyepiece (that I already have) would give me about 14x, and almost 4deg TFOV. A cheap wide field 25mm would give between 4.25 - 4.8 TFOV. (the 7x50 GSO gives about 5 deg, TFOV, I think. Also, the AT72 could get to 5.6 TFOV with a 2" 35mm, 68 def FOV eyepiece, but would cost over $500 for the scope + diagonal + eyepiece)
So with the ETX60/70 - how do they unmount from the forks? My ETX90 has 4 screws, two on each fork. I can de-fork or re-install the OTA in about 5 minutes. Are the smaller ETX's the same? Also, my EXT90 has a "foot" on the bottom of the OTA that mounts directly to a photo tripod - do the smaller ETX's have this?
Last - how is the ETX60/70 as a stand-alone scope? Some places I read it has a built-in barlow? How well does that work? If you push it up to 100x-150x, how well does the image hold up? How would the ETX70 compare to the above mentioned AT72?
Any other thought on these scopes, or using the OTA from one as a finder?
*skyguy*
Reged: 12/31/08
Loc: Western New York
Re: ETX60/70 as a finder scope?
[Re: Jerry-rigged]
#5368665 - 08/14/12 04:13 PM
Why not just "bolt" the entire telescope assembly ... scope, fork arms and drive base ... directly onto a flat area on the dob. The Coulter dobs are so heavy and the ETX 60/70 so light ... a little extra weight shouldn't make a difference! It would certainly save you the additional cost of buying finder brackets.
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
[Re: *skyguy*]
#5368727 - 08/14/12 05:00 PM
Deforking the ETX 60,70,80 is not a 5 min job but not difficult. I wouldn't want to have to put it back together for a quick vies as the time defeats the grab and go purpose. I think the ETX 80 is the one with the builin barlow. You would need rings to mount the smaller ETXs.
Jerry-rigged
Reged: 01/30/12
Loc: Coastal Texas.
[Re: Stew57]
#5368817 - 08/14/12 06:13 PM
Mounting, I am not worried. If it has the foot for a camera tripod, Like my ETX90, then it will be easy. If no foot, it will be toughter, but still do-able.
How do you De-fork the smaller ETX's?
Jerry-rigged
Reged: 01/30/12
Loc: Coastal Texas.
[Re: Jerry-rigged]
#5368822 - 08/14/12 06:18 PM
Google is my friend today...
http://www.cloudynights.com/ubbarchive/showflat.php/Cat/0/Number/2013928/Main/2010728
Yeah, that is not good for what I want to do with it...
Oh well... I guess I could still use it for a finder, but it would be a one way trip. Maybe I can find a cheap one on ebay with a dead mount.
Edited by Jerry-rigged (08/14/12 06:36 PM)
nytecam
Reged: 08/20/05
Loc: London UK
[Re: Jerry-rigged]
#5379677 - 08/21/12 04:27 PM
I've used a spare ETX-70 deforked and mounted on 'rings' on my 12" SCT for some years - currently an excellent e-finder and autoguider via a tiny SX Lodestar cam
burb scope
Reged: 04/18/08
Loc: Canton, MI
[Re: nytecam]
#5381129 - 08/22/12 01:54 PM Attachment (60 downloads)
I bought a used ETX-70 OTA from someone who de-forked it from a trashed mount. I bought used 100mm tube rings, mounted them onto a piece of wood, then mounted it all to the top of my NexStar 6SE. Cost me $100 total. I now having an ETX-70 with working goto. (ha ha!) I keep a wide-field eyepiece in one port, and a 12mm illuminated reticle eyepiece in the other. Anything that lands in the square of the illuminated reticle is in the middle of a high power eyepiece of the main instrument. The versatility of a flip-mirror on the ETX outweighs other conventional finders in my opinion. As an added bonus, the Sun (and Moon) almost fill the entire field of view of the ETX-70 with a Meade LPI camera. This is great for full-disk solar & lunar images, and did a nice job on the recent Venus transit. By the way, the above poster nytecam takes better astrophotos through his ETX-70 than I ever will with any larger scope!
Jerry-rigged
Reged: 01/30/12
Loc: Coastal Texas.
[Re: burb scope]
#5384564 - 08/24/12 01:03 PM
Thanks, glad to hear I am not crazy...
NYTECAM: nice site! I see you have torn your etx down to nuts and bolts... I was wondering - I have seen a few 60/70's on Ebay with loose mirrors or broke focusers sell for less than shipping. How hard would it be to fix these? Is the mirror a glue down affair? Is the focuser screw a standard thread size?
nytecam
Reged: 08/20/05
Loc: London UK
[Re: Jerry-rigged]
#5413811 - 09/10/12 05:44 PM
Bit hit 'n' miss I suspect but if its low cost what's there to loose
Jerry-rigged
Reged: 01/30/12
Loc: Coastal Texas.
[Re: nytecam]
#5567429 - 12/12/12 12:01 PM
Follow up- Well, I done and did it. Payday lined up with a EXT80 "for parts or repair" on ebay, and I won it, $62 shipped. Supposedly the OTA is fine, but the ALT motion is broke, not sure if mechanical, drivetrain, or something else. My plans are to de-fork the OTA and scrap the base, so if anyone here wants some parts, let me know. I will check out all out and see if the issue is repairable before I trash anything... Once the scope gets here I will probably start a new thread. Or not.
0 registered and 0 anonymous users are browsing this forum.
Moderator: Starman27, Chris Erickson
