submission
Reged: 04/29/11
Loc: NJ , USA
SCB2000 controlled by UNO32 micro processor new
      #5063156 - 02/08/12 11:21 PM Attachment (106 downloads)
Well guys , it actually works .
I got the Samsung SCB2000 setting controls working with my UNO32 (an Arduino platform ) micro processor . Now I can control the Samsung SCB2000 settings with my PC
I got the idea ( and nerve ) From This Post ...
Here is a link to a You Tube Video
showing it in action .
The cool thing is that the UNO32 can be made to work wireless with Blue Tooth ...... AWSUM
Ill post some pics of the wiring as well as the MPIDE sketches .
Kyril
submission
Reged: 04/29/11
Loc: NJ , USA
Re: SCB2000 controlled by UNO32 micro processor new [Re: submission]
      #5063160 - 02/08/12 11:23 PM Attachment (116 downloads)
The wiring 1 , have to watch were the wires run as to not interfear with the plastic switch buttons posts ( tiny hols in PC board .
Edited by submission (02/09/12 12:52 AM)
submission
Reged: 04/29/11
Loc: NJ , USA
      #5063161 - 02/08/12 11:24 PM Attachment (98 downloads)
Wiring 2 ( ground ) I also used HOT GLUE to help hold the tiny wires in place .
Edited by submission (02/08/12 11:27 PM)
submission
Reged: 04/29/11
Loc: NJ , USA
      #5063165 - 02/08/12 11:26 PM Attachment (97 downloads)
Wiring 3 ( inside of housing ) used heat sink tubing to hold wires in place .
Edited by submission (02/08/12 11:28 PM)
submission
Reged: 04/29/11
Loc: NJ , USA
      #5063207 - 02/09/12 12:19 AM
MPIDE sketch ....
.... I need to test this sketch , not sure how the Serial Monitor will handle this ... Im actually making my calls to the UNO32 through my software app.
I will test it and come back and make any changes needed.
// SAMSUNG SCB 2000 Settings control
///// Using the Serial Monitor...
///// Type in a number between these 2 signs ~ /
///// You can change what the numbers do by how you have the wiring hooked up to your controler.
///// So as an example ....
///// ~1/ SCB center button
///// ~2/ SCB up button
///// ~3/ SCB down button
///// ~4/ SCB left button
///// ~5/ SCB right button
/////// I Hope I didn't make this to confussing .
// use any pins you want
int Cam_G = 28;
int Cam_U = 29;
int Cam_D = 30;
int Cam_L = 31;
int Cam_R = 32;
int Values = 0;
void setup(){
// Make all pins OUTPUT
pinMode(Cam_G, OUTPUT);
pinMode(Cam_U, OUTPUT);
pinMode(Cam_D, OUTPUT);
pinMode(Cam_L, OUTPUT);
pinMode(Cam_R, OUTPUT);
// Set the pins HIGH
digitalWrite(Cam_G, HIGH );
digitalWrite(Cam_U, HIGH );
digitalWrite(Cam_D, HIGH );
digitalWrite(Cam_L, HIGH );
digitalWrite(Cam_R, HIGH );
Serial.begin(115200);
void loop()
Service_Serial();
Service_Camera();
void Service_Serial()
static int switchmode = 0;
static int cam_mode = 0;
if ( Serial.available()) {
char ch = Serial.read();
// Read in what camera button we want to activate.
if (ch == '~')
switchmode=1;
cam_mode=0;
// Closing Statement or EOF
else if(ch == '/') switchmode=2;
// Serial in Switch Mode Selection
switch( switchmode ){
case 1:
if(ch >= '0' && ch <= '9')
cam_mode = cam_mode * 10 + ch - '0';
break;
case 2:
Values=cam_mode;
Serial.flush();
break;
// Service our Camera ( a delay set lower dosn't seem to work , Id advise keeping a slower delay time )
void Service_Camera(){
switch( Values ){
case 1:
digitalWrite( Cam_G, LOW );
delay(15);
digitalWrite( Cam_G, HIGH );
Values=0;
break;
case 2:
digitalWrite( Cam_U, LOW );
delay( 15 );
digitalWrite( Cam_U, HIGH );
Values=0;
break;
case 3:
digitalWrite( Cam_D, LOW );
delay( 15 );
digitalWrite( Cam_D, HIGH );
Values=0;
break;
case 4:
digitalWrite( Cam_L, LOW );
delay( 15 );
digitalWrite( Cam_L, HIGH );
Values=0;
break;
case 5:
digitalWrite( Cam_R, LOW );
delay( 15 );
digitalWrite( Cam_R, HIGH );
Values=0;
break;
default: // this is not needed .
break;
Kyril
Edited by submission (02/09/12 12:26 AM)
scout72
Reged: 05/12/08
Loc: SF Bay Area
      #5063459 - 02/09/12 09:18 AM
Nice work- way to DIY- super awesome!
Dragon Man
Reged: 03/07/06
Loc: Snake Valley, Australia
Re: SCB2000 controlled by UNO32 micro processor new [Re: scout72]
      #5065141 - 02/10/12 09:35 AM
Nice work
submission
Reged: 04/29/11
Loc: NJ , USA
      #5065154 - 02/10/12 09:43 AM Attachment (82 downloads)
Of course no project is complet till its been enclosed into one of those black project boxes .... used a CAT5 plug to plug it in , also an analog hand controller could be used or the buttons on the back , the micro processor was just another way of controling it .
Edited by submission (02/10/12 09:43 AM)
Dragon Man
Reged: 03/07/06
      #5065216 - 02/10/12 10:28 AM
That box on the side looks familiar
http://www.cloudynights.com/ubbthreads/attachments/4117152-REMOTE-PROJECT-4.jpg
submission
Reged: 04/29/11
Loc: NJ , USA
Re: SCB2000 controlled by UNO32 micro processor new [Re: Dragon Man]
      #5065444 - 02/10/12 01:12 PM
Wish I could have found a smaller box ... this was all they had in stock .
Also Nice work there Dragon Man ... when I saw your post I was hoping the internals of the SCB2000 were going to be the same .... Nope . I put the project off till I saw the other post ( listed above ) .
The wiring is the same for both cameras I believe , just a different way of conecting to it .
Boston
journeyman
Reged: 03/05/12
      #5364779 - 08/12/12 01:59 PM
spectacular, will that thing work on a mac
I'm still plugging away on my own modifications and would love to include this wireless control of the setting key pad, I found a slightly different system that I think will work but, haven't tried it yet.
I'm waiting for an eye-fi and a usb interface so I can send the image wireless, but the key pad controls, well, you did a great job figuring that out. Thanks.
Cheers
Dan
Edited by Boston (08/12/12 02:16 PM)
geminijk
Reged: 04/03/08
Loc: TN
Re: SCB2000 controlled by UNO32 micro processor new [Re: Boston]
      #5366826 - 08/13/12 04:28 PM
Very cool!
John
Zoomster
Vendor - Clear Sky Adventures
Reged: 01/30/05
Loc: Tampa FL
Re: SCB2000 controlled by UNO32 micro processor new [Re: geminijk]
      #5368016 - 08/14/12 10:13 AM
Nice! I like your wiring job, neat and precise, I work with mil spec wiring so cable routing and dressing are important! Good work, would love to do this with my camera, one day I will.
submission
Reged: 04/29/11
Loc: NJ , USA
Re: SCB2000 controlled by UNO32 micro processor [Re: Zoomster]
      #5370786 - 08/15/12 10:02 PM
Thanks zoomster ,
Im a musican ( guitar player ) and I also wire my own tube amps .. lot different than this though ... 3.5 vdc as to 600 vdc lol
Boston
I think the Pic32 will work with mac .. the IDE that you wright the EPROM with I believe is cross platform compatible ... and the Pic32 only responds to what you tell it to ... so if your MAC has USB .. it should work .
And by the way the Camera is still working great with the Pic32 ... was just out with it the other night ..
Priceless to have it so you can make setting changes while viewing on the PC with out having to touch the Camera or scope .
Gary Z
Reged: 01/26/12
Loc: New Mexico
      #5437361 - 09/24/12 02:00 AM
wow. This looks very interesting! Can anyone tell me how this camera would hook into a 8 SE?
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: SCB2000 controlled by UNO32 micro processor new [Re: Gary Z]
      #5437773 - 09/24/12 10:03 AM
Gary,
The security cams (and the Stellarcam and Mallincam video cameras) use a C mount connection. For one of these security cameras all you'll need is a 1.25" to C mount adapter and the camera will fit wherever you insert a 1.25" eyepiece (diagonal, visual back, flip mirror, etc.).
These adapters are usually available around $20 - $30 from a variety of sources. You can also thread filters and focal reducers onto the front of these adapters.
http://agenaastro.com/blue-fireball-1-25-c-mount-video-camera-adapter.html
Gary Z
Reged: 01/26/12
Loc: New Mexico
Re: SCB2000 controlled by UNO32 micro processor new [Re: mclewis1]
      #5438791 - 09/24/12 09:03 PM
Thank you very much Mark!
2 registered and 7 anonymous users are browsing this forum.
Moderator:  Undermidnight, knuklhdastnmr
