moynihan
Reged: 07/22/03
Loc: Lake Michigan Watershed
New legs for the Voyager alt-azm new
      #5353402 - 08/05/12 04:10 PM
One of the arms of the spreader bar broke loose from a leg on my Astro-tech Voyager mount. Any suggestions on sources of new legs?
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: New legs for the Voyager alt-azm new [Re: moynihan]
      #5353760 - 08/05/12 08:34 PM
I don't know about a source for just the legs but if you want to replace the whole tripod the mounting point is the same as for any CG-4/5/Orion SVP type of mount. The Voyager becomes a whole new mount when it's mounted on a heavier tripod.
Hermie
Reged: 04/20/05
Loc: Cloudy HKG
Re: New legs for the Voyager alt-azm new [Re: mclewis1]
      #5353932 - 08/05/12 10:49 PM
I never upgraded my voyager while I had it, but I believe Hands On Optics sell wooden replacement legs. This was discussed ages ago somewhere here.
Hermie
moynihan
Reged: 07/22/03
Re: New legs for the Voyager alt-azm new [Re: Hermie]
      #5356525 - 08/07/12 01:53 PM
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #5357444 - 08/08/12 01:02 AM
I purchased this adapter and put it on this tripod. The tall version. That combination works well with the voyager, the mount fits perfectly in this adapter. I did remove the tripod spreader and remounted it up about 6". Where they put it made the tripod unstable.
This tripod is definitely better than the original voyager tripod but not as much as I wanted. I think one of the heavy duty Berlbach tripods would be much better if they didn't cost so much.
Edwin
Reged: 05/16/07
Loc: The Netherlands
Re: New legs for the Voyager alt-azm new [Re: Lane]
      #5357817 - 08/08/12 10:55 AM
I had the same problem and bought a TAL tripod (http://www.grootven.be/productdetails.asp?PID=418). A very sturdy solution for only EUR 64 ! It is much and much more stable then the original tripod.
moynihan
Reged: 07/22/03
Re: New legs for the Voyager alt-azm new [Re: Edwin]
      #5367307 - 08/13/12 08:53 PM
I just took delivery of the Hands on Optics wooden legs. The part of the voyager mount that the a leg screws onto appears a tad (imperceptibly) to wide to slide between the two wood sides of the tripod leg.
Any advice is welcome.
simpleisbetter
Reged: 04/18/11
      #5367474 - 08/13/12 10:30 PM
Sandpaper would be my first thought.
moynihan
Reged: 07/22/03
Re: New legs for the Voyager alt-azm new [Re: simpleisbetter]
      #5374436 - 08/18/12 10:22 AM
Got the legs on. Turned out it took a combination of Saturday a.m., patience, my morning espresso and the angle of attack.
BTW: these legs can raise the center of the Voyager head/saddle about 58" above the ground.
It is always funny the difference the legs make. I put my Wegat-Meade 5" Mak on it. It was very nice on it with the old legs. Now it is "over-mounted" (which is the way i like it )
Kfrank
Reged: 12/20/08
Loc: Northern Colorado
      #5374519 - 08/18/12 11:24 AM
Yep, overmounting is the way to go. Much more enjoyable to use a scope that has no jitter when focusing and damps out immediately when bumped.
I've never quite understood, though, why so many folks are willing to mess with the Voyager when it is marginal for so many common scopes out there. Sure, you can upgrade the legs and accomplish what you want, but why not just consider a better (and more expensive) mount/tripod combo to begin with?
I suspect that for many, it feels like your spending less money if you buy the mount and then buy a better tripod. The old "I have a $300 mount that works great" with no mention made of the $100-200 spent upgrading the tripod.
moynihan
Reged: 07/22/03
Re: New legs for the Voyager alt-azm new [Re: Kfrank]
      #5374566 - 08/18/12 11:56 AM
I had been using the voyager for awhile when the leg failed. Actually like the performance and ergonomics. Very smooth slo-mo controls for planets etc.
I have used it with Refractors (66mm -80mm), the 5" mak, and with a "L" accessory, my PST & ETX 90 OTA.
I do see a Disc Mount in my future though for my larger stuff
OldManInHawaii
Reged: 03/12/12
      #5374734 - 08/18/12 01:45 PM
In defense of those like myself who bought a $300 mount, let me say that this was the first alt-az mount that I've ever purchased, and I didn't know what to expect in terms of vibration levels. After buying my first one, I now have a better idea of what to expect. Also, I'm not as serious in this hobby as the majority of those who frequent this forum, so cost is a more important consideration than for many of those here who spend over $500 for a mount.
I originally came to this forum seeking info on buying a portable replacement for my aged Meade 2080 SCT which could also be used for some terrestrial photography. Since reading these forums, I've gone quite a bit farther into my pocketbook than what I had originally expected and that includes my new $300 mount.
I'd certainly consider buying a heftier mount in the future if I were more serious about this hobby, but I don't think my skeletal system would be too obliging in this respect. What I have now is a compromise that I can live with.
Sorry for getting carried away here.
Goodchild
Reged: 12/31/08
Re: New legs for the Voyager alt-azm new [Re: OldManInHawaii]
      #5374814 - 08/18/12 02:45 PM
I, too, use the Oberwerk wood tripod with my Voyager mount to hold my WO Megrez 90. It is both functional and attractive. I wouldn't hesitate to purchase this setup a second time.
slack
Reged: 05/02/12
      #5374931 - 08/18/12 04:26 PM
Then it might freak you out that I use my Voyager on a tripod that is 9x the cost of the head.
But what similar type of head comes with a great tripod, even at a higher price? None have sticks that I would choose to use, thus I appreciate that many heads are sold without them. I'd pass on most astro tripods. I only care about the head; I'll adapt it to use with tripods I already have.
JimMo
I'd Rather Do It Myself
Reged: 01/08/07
Loc: Under the SE Michigan lightdom...
Re: New legs for the Voyager alt-azm new [Re: slack]
      #5374980 - 08/18/12 05:24 PM
My Voyager sits on a CG5 tripod that I bought for $99 bucks when OPT was blowing them out a few years ago. I sold the OEM tripod on astromart for $55 bucks so for net $44 bucks I have a nice sturdy tripod for it and it's taller than the original to boot.
Starman81
Reged: 03/06/08
Loc: Metro Detroit, MI, USA
Re: New legs for the Voyager alt-azm [Re: Kfrank]
      #5375390 - 08/19/12 12:39 AM
I have a AT Voyager coming in the mail early next week and it is probable that I would have to upgrade the tripod sometime in the future and that's just what I think based on reading comments--I've never used or seen the mount in use before. When you are unable to see equipment in use or 'try before you buy', you end up buying a piece of equipment and upgrading it later. You kind of just have to know for yourself to see if it's something you can live with or that it just won't work out.
22 registered and 39 anonymous users are browsing this forum.
