cclark
Reged: 07/29/08
CGEM DX dec balance issue
      #5402024 - 09/03/12 10:44 PM
I am having an issue getting good balance in declination on my CGEM DX and want to get some feedback. I am currently using an AT8RC (Losmandy size plate) but I saw the same issue with a LX10 tube fitted with an ADM Losmandy plate. Both configurations have a guide scope (AT72ED) mounted on top (using ADM rings) with an ADM counter weight on the bottom front of the dovetail bar.
When I balance in Dec, I put the CW bar parallel to the ground and slide the guide scope back and forth (and the AMD counter weight) until the scope is balanced horizontally. While it is easy to achieve balance in this position, when I move the scope vertical it is very heavy on the saddle knob side of the OTA. I can't seem to find any combination of movements that will get it to balance when the scope is vertical and it seems very heavy to that side (left side if standing behind the scope).
When I was taking the scope down tonight I had a thought. Since the only part of the saddle that moves is the knob side - could it be that the saddle is optimized for a narrower dovetail bar? If both of my bars are wider that what it was designed for, it would appear that that would make the entire scope site a little left of center which could explain what I am seeing.
A quick search brings up some threads of the newer Celestron scopes having slightly narrower dovetails (the extruded ones) which seems to support this idea. I will need to take some measurements with the saddle fully closed vs. open to the width of my devetail to confirm, but I wanted to check and see if anyone else has noticed this before or if I am headed in the wrong direction.
I was wondering if changing to an ADM saddle might fix this (keep the OTA more centered) and help me get a better balance.
Thoughts?
Chris
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: CGEM DX dec balance issue new [Re: cclark]
      #5402499 - 09/04/12 08:22 AM
Thoughts?
Hi Chris,
This will let you in on the secret. Works whether you're side-by-side, vertical, whatever. You must be balanced in all three planes. When you are, then the rig will remain wherever you place it with the clutches released. For side-by-side, this is the best set of instructions.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5402699 - 09/04/12 10:33 AM
Changing the dovetail is not likely to change this. You will notice that even with the scope off of the mount, the saddle is not balanced. You can get a lot closer to balanced with your rig than you can with an SCT since even the focuser on the SCT is not on the centerline.
True balance is not indicated by the OTA staying one place but by the ability to turn the axis freely and not have it stop in any particular position. Frequently, the axes on these mount are not free enough to do this. Thus, from your desciption, I suspect that you are actually not balanced and if you turn the OTA vertical while the RA axis is horizontal you will probably see this.
With all this in mind, perfect balance is rarely a good idea unless you have very high precision gears with virtually no backlash. If you do balance the DEC perfectly, then you are likely to see it bouncing back and forth between the worm teeth. Just as in the RA, keeping the worm teeth loaded is important, it's just more difficult in the DEC because you are not dealing with one side of the meridian or the other. I would recommend that you do a good job of balancing the DEC but not worry about getting it perfect. The little bit of bias provided by the saddle (or finder or other things) does more good than harm.
Jim Romanski
Reged: 01/02/05
Loc: Guilford, Connecticut
Re: CGEM DX dec balance issue new [Re: DaveJ]
      #5403548 - 09/04/12 06:03 PM
This is a very good video. The only issue I have with it is that you would have problems observing with the tube rotated the way it is in the video. This may not be a problem for imaging.
Another way to achieve balance of the tube is to use tube counterweights. This can be used with or without a rotating tube. On my cave 8" Newtonian I have a rotating tube setup but I use it all the time to position the eyepiece in a more comfortable position. My tube is balanced with counterweights so I don't have to depend upon its rotated position for balance.
If it's only a slight imbalance this might not be necessary. Also, as stated a tad of imbalance in the right direction can be a good thing.
cclark
Reged: 07/29/08
Re: CGEM DX dec balance issue new [Re: Jim Romanski]
      #5403827 - 09/04/12 08:44 PM Attachment (33 downloads)
Excellent info!
Dave - That is a great video! It seems that the rotating of the tube would put the center of mass back over the centerline of the mount, which makes sense. That appears to be what my problem is (off center mass).
Ed - Excellent advice as always. I have hypertuned my mount via your kit and It really helped - it moves as sooth a butter now (many thanks for making this available)! I completely agree about the need to keep some weight on the gears, so I am not trying to get it perfect - just less than it is now. It is really heavy to one side. Like you mentioned, I kept the CW bar axis horizontal and after balancing the dec axis horizontally I moved the scope vertical - and it pulls pretty hard back into the horizontal position. I think I have the front/back balance pretty good (as it stays horizontal and doesn't tip toward the camera end or the business end). It is like a weight is hanging off the side of the tube. I was expecting this to improve when I moved from the SCT to the RC for exactly the reasons you mentioned. I was at a loss when it did not.
Jim - also very good points. I had thought about using some type of weight on the other side of the tube to counter the weight, but I want to explore some other options first. I actually tried something like that when I had the same problem with the SCT, but I couldn't get it right (was just trying to get a ballpark with some 1/4 lb weights taped to the side)
I thought about this quite a bit today and did some measurements and experiments today. What I found seemed to confirm my initial thoughts.
Here is what I did:
First
1. measured and marked the dovetail center with a pencil
2. found the center of the saddle as lined up with a yardstick along the CW bar, through the middle of the polar scope hole and past the worm adjustment hole (the best I could get - I think it was very close)
3. Mounted the scope and marked the dovetail where the saddle center passed.
What I observed (in the attached pic) is that the scope is indeed setting about 0.25" off of center. I think with the weight of the RC, guide scope, etc. all setting off center, it is causing the issue I am seeing.
Second
1. After reconfirming my front/back balance horizontally, I rotated the RA back to center and when releasing the dec clutch, the scope falls to the left (viewed from behind - the side to which it is offset).
2. I then loosened the dovetail, moved the saddle 180 degrees (now the knobs are on the right side) and re-attached the scope.
3. As I thought it would, it now falls to the right (because the scope is now off-set to the other side)
If it was the scope that was heavy to one side I would have expected it to continue to fall to the left, but the direction changes with the saddle - so that 0.25" off-set is what I think is causing the problem. If I could get it centered, I could then use the position of the guidescope (or the CW on the underside of the scope) to unbalance in either direction as much as needed to keep the gears meshed, but as it stands it always pulls to one side (and a lot harder than what seems reasonable - but I am not and expert in this - just what it feels like to me)
I think I will investigate a different saddle and see if Anthony (ADM) can confirm the centering of the dovetail in the saddle. If not I may have to try tube weights or just live with it.
Does my little experiment and conclusion seem reasonable? I rather enjoy trying to work some of these things out - just kind of the way I am.
Chris
dksolar3294
Reged: 08/22/12
      #5407711 - 09/07/12 04:02 AM Attachment (16 downloads)
Re: Dec Balance. I frequently use my 3yr old CGEM for AP use with a Meade 10" SN. With guide scope, ccd camera & finder, the payload is easily over 40#. When I first attempted imaging with this setup, I kept seeing an unwanted star shift between consecutive sub-frames. I first blamed this on the autoguider, then the guide program, then flexure, then balance, then the CGEM gears. I experimented with different possible solutions by trial and error for several weeks and still could not figure out what's wrong. The problem was most obvious when aiming at the zenith area and I noticed that when the Dec lock was loosened, the scope immediately stated to rotate. I figured this mystery force was the cause of the ccd star shifting, but still could not understand why. I figured the CGEM had some sort of cam gear. I even wrote Celestron tech support about this. To counter the rotation force, I bought some large fishing weights from WalMart, drilled some mounting holes into the 10"SN mirror frame and then added the weights to counter the rotation force. This did help some, but it was scope position dependent meaning I had to change the weights as the scope was re-aimed - not a practical solution. In frustration, I started taking the scope setup apart piece by piece and noting if there was any change. With the scope totally removed, I mounted & centered a 2' 2"x2" piece of wood on the CGEM saddle plate & added symmetric barbell weights to each end. With this simple setup, I still saw a DEC rotation tendency. Now knowing the problem was the CGEM itself, I pulled out a tape measure and started looking for the saddle plate exact center rotation point, which was found to be 1/4" offset from the Losmandy dovetail plate centerline. This is obviously the same 1/4" that CClark found.
So the moral of this little story is that a 1/4" offset between a scope's longitudinal axis and the projection of the Declination axis centerline is not negligible and can generate a significant moment arm force, especially with larger scope weights. This can cause havoc with the autoguider.
The solution to this was to offset the Losmandy dovetail plate by 1/4" so the Dec axis intersects the scope's longitudinal centerline. The scope could then be balanced normally. The 10"SN tube rings were mounted on a 1/2" oak wood board and then the Losmandy dovetail plate was attached to the other side. Addition photos of the arrangement are posted under YahooGroups/CelestronCGEM/Photos/DKsolar32N94W.
Unfortunately, this did not completely solve the ccd sub-frame star drift problem, so I'm still working on that elusive one.
cclark
Reged: 07/29/08
Re: CGEM DX dec balance issue new [Re: dksolar3294]
      #5408750 - 09/07/12 04:51 PM
Very interesting. Are you using the stock saddle in your new configuration (with the offset spacer)?
I have an ADM saddle on the way and i will post up any new findings after I have it installed on the mount. I did notice that the Losmandy dovetail was not mating very well with the stock saddle and It may be contributing to the offset I am seeing. If I sight down the dovetail and look at the interface with the saddle, it is not fitting well and keeping the dovetail from fully seating - thus keeping the dovetail displaced a bit. I can't tell if it accounts for the full 1/4 inch, but it may be close.
Another reason I decided to go ahead and replace the saddle is after seeing how poorly the dovetail fit the stock saddle, I began to have concerns that it may tip out of the saddle if enough weight is pulling on it. It seemed to grip it pretty well, so it may not be a big deal - just another reason to make the change.
Thanks for the feedback and I am glad you are seeing some success with your fix. If I still need to compensate for any offset after the saddle change, I will try something similar.
Chris
dksolar3294
Reged: 08/22/12
      #5409547 - 09/08/12 03:15 AM Attachment (22 downloads)
I'm using the original CGEM saddle with an ADM standard Losmandy plate. They are both flat and fit well together. When I first got the ADM plate, I was surprised at how thin (1/2") it was. Personally, I would like to see more metal to metal contact. As it is, I just make sure the jaw screws are good & tight.
I took another picture to refresh my memory of how the pieces fit. As I perceive it, the problem is totally due to the saddle. Pretending the mount is setup in the Home position with scope looking at Polaris, the photo view is from the North top looking down to the South. The ADM plate centerline is offset to the West by the ~1/4". If the scope is mounted directly to & centered with the dovetail plate, then the scope will also be offset. For larger scopes, the resulting torque force is substantial. To correct this, the scope needs to be moved laterally towards the East by 1/4" or away from the jaw screws. A solid piece of oak wood is one method for making the offset.
cclark
Reged: 07/29/08
      #5413744 - 09/10/12 05:15 PM
I received my ADM saddle today and just wanted to follow-up and let everyone know my results...
SUCCESS!!!
I installed the saddle, mounted the scope and double checked the centers of the dovetail, saddle, mount centerline and they all matched.
After doing a quick balance of the RA and the Dec (horizontally), I held my breath and loosened the clutch and rotated the OTA vertical - when I let go...no movement - wow. I could push the scope around in dec with the slightest amount of finger pressure (in either direction). There is only the slightest preference for the knob side, but is tiny and that seems normal. This is a huge change from the way it previously behaved. I now feel like I can actually get it balanced (and have some influence on how out of balance I want either axis).
Thanks to everyone for giving me feedback and many good things to ponder while getting this solved.
Chris
Edited by cclark (09/10/12 05:25 PM)
dksolar3294
Reged: 08/22/12
      #5419392 - 09/13/12 02:56 PM
Chris, Thanks for posting what is great news. I haven't looked at ADM's web site lately, so was not even aware they made a CGEM replacement saddle. A new saddle is definitely the way to go to remedy the Dec balance problem.
Don
16 registered and 34 anonymous users are browsing this forum.
