Odell
Reged: 04/29/12
Loc: Florida
Finder Scope Bracket for Intes MK67 Deluxe
#5406334 - 09/06/12 10:46 AM
I just purchased an MK67 Deluxe
(http://www.cloudynights.com/classifieds/showproduct.php?product=64070&sort=&cat=11&page=4).
My difficulty is that I am too inexperienced to identify the hardware needed to mount a finder onto the existing mount point on this scope. If one looks just below the Orion scope there is what appears to be a mount point for a bracket. If someone could point me in the right direction for mounting a finder scope to this point I would be deeply grateful.
TIA
Ian
Edited by Odell (09/06/12 06:37 PM)
titanio
Reged: 02/15/09
Loc: Alicante, Spain
Re: Finder Scope Bracket for Intes MN67 Deluxe
[Re: Odell]
#5406460 - 09/06/12 12:25 PM
MK67 ?
Toni
Odell
Reged: 04/29/12
Loc: Florida
[Re: titanio]
#5407033 - 09/06/12 06:36 PM
Yea Sorry MK67...
It's doubly embarrassing when it's in your sig
Ian
TONGKW
Reged: 01/16/07
[Re: Odell]
#5407436 - 09/06/12 10:44 PM Attachment (22 downloads)
The finder bracket for the Intes MK67 is of special design. Unfortunately I cannot find any other manufacturer’s finder bracket that fits the MK67.
K W TONG C8+CG5 GT, TSA102+HEQ5 PRO, MK67+Voyager, NexStar 6SE, C5+Mizar K, WO ZS80FD+Kenko NES, Megrez 72FD+Kenko KDS, Mini Borg 50, PST
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
[Re: Odell]
#5407440 - 09/06/12 10:48 PM
Ian,
What is the distance between the 2 screws that are in the first picture below the piggybacked scope? You re correct, I believe that that is where you would mount the guide scope.
Mkofski
Reged: 07/19/11
[Re: Mkofski]
#5407451 - 09/06/12 10:56 PM
Much less elegant, but you can add a ring to the OTA and mount a finder on it. Or use one of the non-magnifying finders that have a adhesive base that just sticks to the OTA.
Odell
Reged: 04/29/12
Loc: Florida
[Re: Mkofski]
#5407561 - 09/07/12 12:11 AM
@KW Tong: Thanks KW, I am of the same opinion that this is a specially made bracket.
@Mike: I'm traveling over the weekend and have the scope in the back of my vehicle. I'll measure the width between the screws when I get to my destination on Monday. Also,as there are rings that I have my plate mounted to, there may be a solution there. There is a top plate spanning the rings, but I haven't yet sussed out the spacing of two holes that have been drilled and tapped into it. I agree that may be the way I'll have to approach this short of having a machine shop manufacture something. I'm resisting an adhesive solution (something about my aberrant personality abhors adhesives on scopes) but resistance may be futile.
TONGKW
Reged: 01/16/07
[Re: Odell]
#5407759 - 09/07/12 05:55 AM Attachment (16 downloads)
I have just carried out some investigation as to what other finder bases that can be used on my MK67. After removing the existing mounting block, I find the Dovetail mounting base for finder scope from Orion can be used on my MK67. Is is now possible to use the many straight or right-angled finders from Orion or from other manufacturers. http://www.telescope.com/Accessories/Telescope-Finder-Scopes/Orion-Dovetail-Mounting-Bases-for-Finder-Scopes/pc/-1/c/3/sc/49/e/41.uts
Odell
Reged: 04/29/12
Loc: Florida
[Re: TONGKW]
#5408846 - 09/07/12 06:01 PM
THAT is an admirable piece of research KW. Thanks for going out of your way on my problem.
You have my gratitude.
Ian
Waxing Gibbous
Reged: 11/19/10
Loc: Victoria, Australia
[Re: Odell]
#5409732 - 09/08/12 09:17 AM
APM in Germany should be able to provide you with one, as they are the principal source for I-M scopes outside Russia.
Failing that, I'm using a a set of Stellarvue brackets and rings on my I-M 815 Mak with no issues at all.
Edited by Waxing Gibbous (09/08/12 09:19 AM)
Odell
Reged: 04/29/12
Loc: Florida
[Re: Waxing Gibbous]
#5411175 - 09/09/12 05:23 AM
Thank you professor.
