Privacy Policy |
Please read our Terms
of Service | Signup and
Richard Low
Reged: 11/27/05
Loc: Singapore
Re: Time to Step up to a Better Planetary EP
[Re: Starman1]
#5402914 - 09/04/12 12:34 PM
Simple. I tried an eye patch and, with both eyes open, all I saw was a black field image from my patched eye. I tried a black field mounted on the side of the scope. Both eyes open, all I saw was the black scope. If I squint and close the unused eye, all I see is what the open eye sees. But I've done this for 49 years, so whatever muscles are used are pretty strong. I can observe for 10 hours in a row with one eye closed with no muscle or eye strain whatsoever.
I tried an eye patch but I also see the black field effect, and it is uncomfortable. So I always do monoviewing with one eye closed too, without any strain on my eyes even for all-night 10-hour observing. Maybe I had been too used to this while observing for the last 37 years.
Mike B
Starstruck
Reged: 04/06/05
Loc: shake, rattle, & roll, CA
[Re: Sarkikos]
#5402952 - 09/04/12 01:00 PM
The latter I still don't understand if the observer wants to look at dimmer DSO. <<with a BVer>>
As my buddy Inigo might say: "Lemme 'splain"
But since there's so little space to do so, lemme sum up...  Quote:
It's not just our eyes that are all a little different from each other. We also process and interpret visual data a little differently.
My eyes see DSOs, whether bright, or even dim, much better thru BVers; they appear near 'bout equally bright for me viewed "mono", but also appear much more flat & lacklustre. Eye can only surmise that my own eye-brain additive thing is particularly sensitive.
Now, what baffles me is: Quote:
There I spend most of the time locating and observing DSO toward the LM of my telescope.
Gosh- that's like: 1) brewing a pot of coffee 'cuz you like the aroma... then dumping the whole carafe down the drain... or 2) observing Jupiter's GRS as it barely crests the limb of the planet, then packing the scope up & calling it quits for the nite... or 3) buying a huge tub of super-chunk peanut butter, then straining out & eating only the chunks... because you like nuts!
OTOH, i get a kick outta viewing galaxies, dim or bright, then cruising their immediate area looking for faint "companions". I dig it ALL!
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
[Re: Mike B]
#5403019 - 09/04/12 01:38 PM
Mike B,
I'll let EdZ do the 'splainin':
Re: Equivalent effective aperture with bino
The gist of the 'splainin' is that an 11" scope with a binoviewer will be the equivalent of a 9.2" scope. This is similar to my own experience when binoviewing my 10" and 8" Dobs. There is some detectable loss of light grasp.
Sarkikos
Reged: 12/18/07
[Re: Mike B]
#5403028 - 09/04/12 01:40 PM
Mike B,
Well, I'm not going to travel 50 miles, a two-hour round trip, to spend all night looking at the bright stuff I could have stayed home to see! Now, I'm not saying I don't look at the showcase Messiers and NGC objects, especially if my family is with me. But I'd say at least 80% of the time I'm trying to find those dim beasties I'd have absolutely nil chance of seeing at my red zone home. Even beyond that, I spend most of the 80% locating and observing objects I've never seen before, even at the dark site. To me this is the most logical course of action which makes the best use of my time and resources.
But to each their own. De gustibus non est diputandum.
Mike B
Starstruck
Reged: 04/06/05
[Re: Sarkikos]
#5403164 - 09/04/12 02:47 PM
... an 11" scope with a binoviewer will be the equivalent of a 9.2" scope.
Yup, that's the pie-are-squared aspect of "splitting" the signal to two eyes, from ONE objective.... yet i believe, in Ed Z's most excellent 'splainin', he goes on discuss & describe the "additive" aspect of bringin' TWO eyes to bear on viewing the same object. Here is where i believe the variations in our eye-brain wiring come into play! Seems like i recall that, for Ed Z, it's a few decimals of magnitude grasp lost- on the whole, net sum. Not entire magnitudes, as the aperture "split" & raw numbers might imply.
This squares, roughly, with what my own eyes see... altho i s'pect my own wiring varies (as does everyone's, this way or that ) tending to favor the bino gains where *faintness* is considered. Some of that may be my picking up "movement" better with both eyes, where dim objects are spotted while panning the scope? I dunno... i simply go with what i see.
Yeah, i know whereof you speak! And i s'pect it comes down to niggly details, percentages, & tastes? I might be the same- only at 70%, and "orange" at home. That, and i'm always game to see NEW aspects to old friends... it's been over five years since bumping up from a 10" SCT to a 15" Dob, and i'm STILL not "over" the rush the difference has made- objects bright or dim!
To me this is the most logical course of action...
Observe long & prosper, Mike! I guess for me, when i'm out under the stars, it's like Ellie Arroway (in 'Contact') stating "No words to describe it... they should've sent a poet!"
But whether looking at the *bino* aspect, or the "planetary EP" aspect, it is a multi-faceted equation! For the OP, using an 8" SCT in SoCal, the atmospheric "seeing" in some areas there is legendary- here's a key place to look for increased performance ("planetary" or otherwise ) from one's EPs; watch for better seeing conditions, and/or go find them- like getting away from hot pavement & buildings, vents & rooftops, & finding viewing environments that take particular advantage to the atmo's "laminar flow" coming off the Pacific.
Next would be making efforts to get the SCT thermally stable- perhaps a "CAT-cooler" to get the thermals out of the sealed tube, and the temps of the glass & metal therein to ambient- matching that of the outside air.
So when cooled, collimated, and under good conditions, the individual variations within EP types can now be more clearly seen & appreciated. Then, if the scope's optics are really good, the ultimate nuances of the better EPs can hold sway!
Getting a look thru a variety of scopes, types, and EPs- like at a local/regional star-party, one can begin to see what the variations look like... as well as experience what one's own tastes prefer in EP types & ergonomics. It makes little sense to buy a specialized $400 EP, only to find it's uncomfortable for your personal "software" to look thru!... or is just as blurry in one's scope as a $20 Plossl.
Having followed my own advice (well, that which distilled from months & years of studying thru CN university ), having optimized my scope & viewing prep, i was quite notably blessed by the performance of a truly specialized "Planetary" EP- a 10mm Carl Zeiss Jena Ortho. I could clearly see it perform a half-notch better than some other, excellent glass i'd been using... being compared A-B in the same scope, same time. However, i'm betting any such excellence would've been obscured, if not entirely lost, had i run the same EP comparo in my previous scope, especially when it hadn't reached thermal equilibrium... and/or the atmo conditions were not particularly good.
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
[Re: brianb11213]
#5403278 - 09/04/12 03:35 PM
While the light that reaches each eye is cut in half, the brain does a function called "Summation," in which it adds the light back together. The image is still dimmer than with monovision, but the binocular summation helps your eye do better resolution.
Not with my eye/brain.
I can just about read the bottom line on the optician's eye testing chart with my right (distance dominant) eye alone (with the correct distance correction lens in). With my left eye alone, the bottom two lines are illegible. (This is still "perfect" vision in optical terms). With both eyes together, I can no longer read the bottom line. Overload from the less good signal, I suspect.
I use binoculars for observing brighter variable stars (in the mag. 6 to 9 range). I always leave one eye capped ... because I get a clearer image that way, in fact it enables me to see stars at least half a magnitude fainter. This is despite the loss of (a little more than half) of the light that a beam splitter entails not being a factor when using duplicate objectives. There is NOTHING wrong with the binoculars!
Reducing glare DOES help me see fine detail on planets ... the mechanism doesn't matter but less glass / less surfaces means less scatter, which helps.
Brian, You should be able to focus each eyepiece separately to some extent, even if it's just by pulling one out a little. Once both eyes are in focus, you might have a better experience.
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
[Re: Rick Woods]
#5403402 - 09/04/12 04:37 PM
Neither eye focuses very much any more. And if the balance isn't quite right, I get a thumping headache very quickly. This really interferes with being able to see anything well. It's much more comfortable to be monocular.
Rick Woods
Reged: 01/27/05
[Re: brianb11213]
#5403537 - 09/04/12 05:58 PM
Well, that makes it an easy choice!
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
[Re: Rick Woods]
#5403630 - 09/04/12 07:00 PM
I was going to say though too, the diopters allow each eye to reach focus independent of the other. Give it another chance Brian, you may find this actually works once each eyepiece is properly focused (like walking around with both eyes open).
I agree with everything Eddgie says, the binos are the way to go for detailed planetary. You gotta have good binos though to reach high magnification, you are not guaranteed good results with a Chinese cloneviewer at 200X.
Dan Finnerty
Reged: 09/11/11
Loc: Pasadena, CA
[Re: Mike B]
#5404220 - 09/05/12 12:59 AM
Yes, i know. I'm right-handed & right-eyed. Yet my oldest son, who is VERY similar to me in many, many ways- and is right-handed, is left-eye dominant. Took us a while to figure that out (as a child he was having a very difficult time aiming an air-rifle... till we discovered the *why*!)
I've worked as a volunteer instructor at our local public archery range, which gives free lessons to first-time archers. A vital part of the first-time training session is testing for eye dominance, along the lines of Don's test. The only difference is that you have the student hold out their hands, make a small aperture and look at the instructors face. Which ever eye the instructor sees is the dominant eye. Very simple and reliable test.
Cross-dominance (opposite dominant hand from dominant eye) is fairly common, maybe 5% occurence (utterly non-scientific. That would make a great grammer-school science fair project...) My stepson is right-handed but left-eye dominant. When he switched, he immediately improved his shooting. I have heard that there has never been a U.S. national shooting champion who shot cross-dominant. There have been successful archers, but that is because they had some physical impedement that required shooting on one side or the other.
It took Foster several weeks to get comfortable with left-handed shooting, but now years later he does not even think about. He got his Army sharp-shooter ribbon left handed, and then just for fun re-qualified right-handed. Ambi-occular?
Non-dominance is a much rarer occurence. Less than 1% I would guess, perhaps much less. It is infrequent enough that when an instructor discovers a student with no eye dominance, they will often call over the other instructors to see for themselves.
Sarkikos
Reged: 12/18/07
[Re: Dan Finnerty]
#5404399 - 09/05/12 07:06 AM
The prescriptions for my eyes are significantly different from each other. My left eye is obviously more nearsighted. I have to adjust the diopters on my old Burgess binoviewer nearly to the maximum difference between the two sides. But it's doable.
Luckily, even though this is a "cheap" Chinese bino that I bought used, the collimation appears to be right on and I have no problem merging the two images. I take it regularly up to about 300x. I even pushed it to 600x for Mars a few months ago when the apparent diameter was only about seven arcsec.
I usually keep the magnification between 200x and 250x, especially for Jupiter. The clear aperture is only 20mm, which limits me to eyepieces with field stops no wider than 23mm. But that's OK, because I don't use the binoviewer for wide-field views of DSO. I have ES 100 degree eyepieces for that.
franzmetcalf
Reged: 06/21/11
Loc: Washed out Los Angeles
[Re: Sarkikos]
#5405712 - 09/05/12 10:36 PM
Again chiming in with another big thank-you to everyone for this fascinating thread. I'm pretty convinced I want to try the binoviewer experience. Don, I will be coming up to Mt. Pinos when I can convince my family or friends. It's just exactly an hour from my house without traffic. And, Tammiji, I'm half an hour away from Oak Canyon and I will try to come to the star party on the 15th and find you and your EPs! That is just perfect, I think, before I sink several hundred dollars into this craziness. But I must say that Eddgie.
Meanwhile, I'll ask more questions, maybe over in the binoviewer forum.
Thanks so much,
Franz
Rick Woods
Reged: 01/27/05
[Re: franzmetcalf]
#5405758 - 09/05/12 11:13 PM
Franz, If you try inexpensive binos and they work well, then you're in business, and getting off cheap! If they don't work well, though, try really good ones before giving up on the whole idea.
howard929
Member
Reged: 01/02/11
Loc: Low End of High Ground
[Re: Rick Woods]
#5406315 - 09/06/12 10:36 AM
Really cheap guy here. If I bought cheap binos and thought they worked well, I wouldn't know what "working well" really means since I have nothing to compare them to. FWIW, instead I'm planning on the Baaders that Eddgie suggested.
Hey. This turned into a pretty useful bino thread. LIKE.
Eddgie
Reged: 02/01/06
[Re: howard929]
#5406414 - 09/06/12 11:44 AM
Please remember this... No matter what you use, the best way to improve your planetary performance is not with eyepeices or binoviewers... It is to develop patience.
All of my best sightings have been made on nights of less than perfect seeing, and involved very long periods of intense focus on the target.
And it is not enough just to look at the target. You have to look at very specific points on the target. If you want to see a small oval on Jupiter, you can't look at Jupiter. You have to look at the point on Jupiter where you are most likley to see small ovals.
And you have to wait for it.
This is what makes the binoviewer so important to observing. It makes the time that you are waiting for that oval to pop into view more comfortable, so you can look longer.
There is too much detail on Jupiter to take in all at once. You really have to explore it in 10 arc second squares. This is just so much easier with binovision.
So, just like with expensive eyepeices, don't expect Binoviewers to suddenly make all kinds of new detail appear. It simply doesn't work that way. Pick a point on your target and look at that point. Study it closely, and detail will start to emerge.
Good luck. I think you will enjoy your binoviewers. They will work well even with relatively inexpensive Plossls. I have some Vixen NPLs that were inexpensive and quite good. There are other excellent choices out there as well.
Please be sure to post in the Binoviewer forum or on the Solar System forums when you have had a chance to use them. I am sure you will enjoy them.
Rick Woods
Reged: 01/27/05
[Re: howard929]
#5406487 - 09/06/12 12:39 PM
You might also consider the Vernonscope binoviewer. My information is that the Baader is made by a company in Czechoslovakia from a Zeiss design. The Vernonscope is actually made by Carl Zeiss. The VS unit has better polish, but the Baader has a larger prism. So if you plan to use eyepieces with larger field stops, go with the Baader; otherwise the VS is the one. I can attest to the superb quality of the VS unit.
CollinofAlabama
Reged: 11/24/03
Loc: Lubbock, Texas, USA
[Re: franzmetcalf]
#5407308 - 09/06/12 09:27 PM
I'm with David Hederich. My vision is completely non-binocular, with one eye seeing everything close up (does ALL my reading, except of far away signs), while the other does ALL my distance vision. Been this way since childhood. Not only do I not need glasses nor find this uncomfortable, I actually possess some corrective glasses (for my 'bad' eye with nearsightedness) that cause headaches an all manner of discomfort and unpleasantness when I try to view thru them. I do not like binoculars at all. Besides the fact that focusing them to work for me makes me uncomfortable, the next guy will curse me to no end to fix the bizarre focus of one of the lenses compared to the perfect focus of the other. Binoviewers are NOT for everyone. My understanding is Jim Barnett has vision like mine and Hederich's.
Oh yeah, Daniel Mounsey's article is, in fact, way old and out of date. In fact, he even published something of a retraction regarding what I'd recommend you get. He slammed the TV Nagler T6 in his review, but later ate some crow on the subject. The TV Nagler T6's are the same as the high performing TV Plossls, with a MUCH bigger field, a WHOLE lot more eye relief than anybody's low-glass eyepiece, and a low weight that will let you move between a T6 and a plossl or ortho with ease in a delicately balanced small refractor. But with a C8SE, 16 and 12mm Brandons, along with a good Barlow, might be the best combo for planetary.
Good luck
Sarkikos
Reged: 12/18/07
[Re: Eddgie]
#5407785 - 09/07/12 06:43 AM
Eddgie,
... and etc. ...
Sarkikos
Reged: 12/18/07
[Re: Sarkikos]
#5407803 - 09/07/12 07:08 AM
I recently picked up another Brandon 12mm. This will be my first Brandon bino pair. I'll finally see for myself how good they are for planets. I'm curious to see if I'll like them better than my pair of AT Paradigm 12mm. I might end up selling one of the Paradigms. No matter what, I'll probably keep both of the Brandon 12's.
20 registered and 32 anonymous users are browsing this forum.
Moderator: ausastronomer, Scott in NC, iceblaze
