APM M.Ludes
Vendor (APM Telescopes)
Reged: 05/01/03
Loc: Germany
Skywatcher - AllView - Multi Purpose Mount
#5419370 - 09/13/12 02:49 PM
The all new Skywatcher AllView - Multi Purpose Computer Mount
The innovative and very versatile, computerized Skywatcher AllView mount with hand controller and tripod is the indispensible companion for all your photographic and visual observation needs.
The AllView can be used for panorama and Still Time Lapse Photography, as a GoTo mount for astronomy or simply a sturdy platform for mounting your spotting scope or binoculars.
Also the AllView mount can be used for your security or surveillance applications.
The AllView can move between two programmable positions and control the camera shutter release. So taking panoramic photographs is very easy.
Astronomy - Photography - Video captureing
AllView Features:
Use your Digital Camera to take Still Time Lapse Photographs Encoders in both axles allows the manuel movement of the mount without loosing the allignment Trigger Controller for electronic shutter release during captureing in panoramic mode Motorized Mount for Video Captureing Hand Controller with more than 42.000 Object Database AllView Head can be attached to most Prosumer Tripods via 3/8" thread
The innovative and highly versatile SkyWatcher AllView motorized robotic mount & tripod is an indipensible companion for all your imaging and observational needs. The AllView can be used for 360° Panoramic or Still Time Lapse photography, Video Capture, a GoTo mount for Astronomy or simply a stable motorized platform for mounting a spottin scope or binoculars.
Take amazing panoramic photographs with your DSLR
The supplied multi function L-bracket will accept most cameras via a standard 1/4" tripod bush, and can orientate the camera in both portrait and landscape mode. The camera is connected to the mount with an electronic shutter release cable for automatic camera control. (Canon-D shutter release cable supplied, but cables for other camera makes / models are readily available). Parameters are entered into the Synscan handset and the mount can then start taking panoramic photos in three different modes; Easy Pano Mode, Preset Pano Mode and Time Lapse Mode. Even full 360° panoramas are possible incorporating everything from the Zenith to the Nadir!
Video Coursing & Time Lapse Mode
In Video Coursing mode, the mount allows you to capture up to 10 hours of video between two user-determined points. The slewing speed is automatically determined by the time the user decides to slew between those points. Similarly, in Time Lapse mode the user can choose a starting and finishing point, and a slewing time up to 10 hours between those points. This feature allows the user to capture a series of still images (up to 65.535) during the slew, and using suitable image processing software, the images can be merged to create time lapse video.
Motorized Mount for Daytime Observations
In its simplest application, the mount can be used as a stable motorized platform to automatically pan your favourite compatible equipment to any desired position. Simply use the Synscan handset to select the speed and the directional buttons to move the mount in altitude and azimuth axes.
Computerized GoTo Mount for Astronomy
Telescopes up to 5 kg can be mounted to either the Vixen-Style dovetail or the supplied L-bracket via a standard 1/4" tripod bush. Longer telescopes can be mounted on the outside of the mounting arm allowing complete freedom of vertical movement. The supplied Synscan handset has a database of over 42.900 celestial objects, and commands the mount to locate and track those objects automatically, allowing you to explore the night sky to your heart´s content. The patented dual-encoder design means the mount can also be moved by hand without losing alignment or positional information.
Delivery contains:
Mount Handcontoller L-Bracket Tripod Canon-D Cable
http://www.apm-telescopes.net/en/Mounts-Tripods/Alt-Azimuth-Mounts/Skywatcher-Acuter-MERLIN-Multi-Functional-Mount1.html
available from stock at APM in Germany
zjc26138
Loved By All
Reged: 02/24/05
Loc: Mingo Junction, Ohio
Re: Skywatcher - AllView - Multi Purpose Mount
[Re: APM M.Ludes]
#5420186 - 09/13/12 11:05 PM
I'm looking for a mount to do some wide field imaging with. This might be the mount to get. It looks interesting. How much to ship to the states?
Edited by zjc26138 (09/13/12 11:07 PM)
frebie
Chief assistant to the assistant chief
Reged: 04/29/08
Loc: Neither here nor there.
[Re: zjc26138]
#5421267 - 09/14/12 04:53 PM
The SkyWatcher All-View mount is readily available in the US from any Celestron/SkyWatcher dealer. Celestron part number is S20150 and retail price is $399.
zjc26138
Loved By All
Reged: 02/24/05
[Re: frebie]
#5421689 - 09/14/12 10:32 PM
Thanks for the info!
Thomas Karpf
Reged: 02/09/09
Loc: Newington, CT
[Re: zjc26138]
#5615502 - 01/10/13 01:06 PM
What cable would be required for the Nikon D5100?
frebie
Reged: 04/29/08
[Re: Thomas Karpf]
#5615777 - 01/10/13 03:55 PM
You probably need to contact Celestron directly for the availability of a Nikon cable. They indicate that cables for cameras other than the Canon are available, but their price list does not show any or list any part numbers for optional cables.
APM M.Ludes
Reged: 05/01/03
Loc: Germany
[Re: Thomas Karpf]
#5616708 - 01/11/13 05:24 AM
Hi Thomas
such cable item nr. is AP-R3N (N3) and cost $ 15
Guy Noir
Reged: 04/27/05
Loc: Stockholm Suburb - Sweden
[Re: APM M.Ludes]
#5783219 - 04/07/13 07:14 AM
I have been looking at this as a travel goto mount for my Astrotech 72mm refractor (about 4kg with diagonal and EP). Questions: 1) how big in diameter are the tripod legs? 2) how tall the point of scope attachment when legs fully retracted, or extended? 3) how long is the tripod when folded up (i.e. can it be taken as carry on ?) how big is te AltAz head (length, width, height) 4) when mounting the scope on the outside of the fork, can a counterweight, or small SLR be attached on the inside of the fork? 5) how much vibration at 4 or 5 kg load is there ? is it ok for visual? Thanks for any replies - i need a travel mount before May 15, so time is of the essence, Cheers and beers, Michael
APM M.Ludes
Reged: 05/01/03
Loc: Germany
[Re: Guy Noir]
#5792051 - 04/11/13 10:17 AM
1. It´s 32 / 25 mm 2. It´s 1330 mm high. 3. The tripod is 750 mm folded, the head is 300 x 260 x 150 mm. 4. Normally not, only a custommade construction could be possible. 5. For visually use it´s OK.
clear skies Markus
Guy Noir
Reged: 04/27/05
[Re: APM M.Ludes]
#5802014 - 04/16/13 05:37 AM
Hallo Markus, danke für die Antwort - mein Teleskop wiegt eigentlich nur 3.4 kg - wäre dass noch leicht genug so dass man jedenfalls bei visueller Benutzung wenigstens nicht zu starke Vibrationen beim Fokusieren hat??? Tschüss Michael
APM M.Ludes
Reged: 05/01/03
Loc: Germany
[Re: Guy Noir]
#5802921 - 04/16/13 03:18 PM
Hi Michael
dieses kleine Gewicht ist für die Montierung wirklich gar kein Problem, geht prima
Guy Noir
Reged: 04/27/05
[Re: APM M.Ludes]
#5802999 - 04/16/13 04:00 PM
hallo Markus - dank Dir wieder für die schnelle Antwort - das hört sich gut an. Muss dann also bald meine Geburtstagswunschliste zusammenstellen :-))) Tschüss, Michael
