jmiele
Patron Saint?
Reged: 12/04/10
Re: Atlas Deluxe Accessory Tray! new [Re: rmollise]
      #5361584 - 08/10/12 11:49 AM
You could do it by cutting through the back of the off side HC holders (they would still work) and give up the three inside (closest) 2" EP holders. Is this homemade or purchased?
Joe
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: Atlas Deluxe Accessory Tray! new [Re: jgraham]
      #5361642 - 08/10/12 12:35 PM
Ahah. With this tray installed you can't fold the legs in without dropping it off of the center bolt.
That's true but I never did that as I pack the tripod in a bag and put the tray in my case with my mount anyway so it is not an issue in my case, but I could definitely see it interfering with your custom "wheely bar" that you built.
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: Atlas Deluxe Accessory Tray! new [Re: jmiele]
      #5361647 - 08/10/12 12:38 PM
Joe
Hi Joe, this was purchased from Orion. There is a link in about the 3rd response down from the original post.
jmiele
Patron Saint?
Reged: 12/04/10
Re: Atlas Deluxe Accessory Tray! new [Re: rigel123]
      #5361814 - 08/10/12 02:10 PM
Ok thanks. Joe
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #5362460 - 08/10/12 09:07 PM
Warren; that makes sense. Yeah, I like to leave the EQ head attached to the tripod and pick the assembly up as a unit with my Atlas Back-Saver. Still, pretty spiffy.
gmartin02
Reged: 04/11/05
Loc: Santa Clarita, CA
      #5420817 - 09/14/12 12:06 PM
Anyone tried one of these with an AS-GT or CGEM? The tripod spreader from the Atlas looks exactly the same as the one for the Celestron mounts. I also wonder if the Celestron hand controller will fit in the holes made for the SynScan?
Greg
simpleisbetter
Reged: 04/18/11
Re: Atlas Deluxe Accessory Tray! [Re: gmartin02]
      #5420856 - 09/14/12 12:32 PM
Haven't tried one but shouldn't have to. It should work just fine on a CG-5 since it shares the same tripod with the Atlas, and believe the CGEM uses the same one too. And last I looked at them, the hand controllers of the NexStar and Synscan look close enough it should fit in the slot.
19 registered and 32 anonymous users are browsing this forum.
