HowardK
Reged: 10/20/10
CGE PRO extension for CW shaft new
      #5220317 - 05/13/12 01:51 PM
Does anyone know of some place or somebody who supplies short extension shafts for the CGE PRO's counterweight shaft?
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
Re: CGE PRO extension for CW shaft new [Re: HowardK]
      #5220376 - 05/13/12 02:42 PM
I am not aware of anyone that sells them. You may try the CGE
groups on yahoo. I ended up just adding more weight. I had 88 pounds 4x22 on mine at one point to balance my very heavy guide setup.
HowardK
Reged: 10/20/10
Re: CGE PRO extension for CW shaft new [Re: Whichwayisnorth]
      #5220723 - 05/13/12 06:33 PM
Thanku
There was someone last year making an extension...I forget who
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
      #5414361 - 09/10/12 11:49 PM
Hey.. did anyone ever find an extension for the cge pro counterweight bar?
oo_void
Reged: 11/13/09
Loc: San Francisco, CA
Re: CGE PRO extension for CW shaft new [Re: wolfman_4_ever]
      #5414902 - 09/11/12 10:27 AM
Not sure what size the CGE is, but I have one of these for my CGEM. http://www.scopestuff.com/ss_eqbe.htm
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CGE PRO extension for CW shaft new [Re: oo_void]
      #5415005 - 09/11/12 11:27 AM
The CGE and CGEPro have the same size counterweight bars - 1.25". What I don't know is if the threads on the mounting point for the counterweight bars are the same (ie. can you use a cw bar from a CGE for a CGEPro ... and therefore if someone has a CGE extension does it work on the CGEPro?)
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: CGE PRO extension for CW shaft new [Re: mclewis1]
      #5415038 - 09/11/12 11:41 AM
My guess would be "no." My CGEM DX has a different toe-saver thread (metric) than my Losmandy G11 (SAE). I used to have a complete G11 setup, including a CW shaft extension that threads into the toe-saver end, that's how I know. What I'm not totally certain about is whether the CGE Pro had the same threads as the CGEM DX, but my guess is that it does since they're both coming from the same Chinese source.
mclewis1
Thread Killer
Reged: 02/25/06
Re: CGE PRO extension for CW shaft new [Re: DaveJ]
      #5415061 - 09/11/12 11:59 AM
The original CGE uses a 3/8 x 16 threaded location for the toe saver (and that is same as the Losmandy I believe).
wolfman_4_ever
Reged: 07/15/11
      #5415571 - 09/11/12 03:50 PM
the pro is using a 3/8th-12 it looks like to me.. It's not as fine as the altitude lock knobs which look to be 3/8th-10
I said screw it and retapped the end to 3/8th-16. Now I can put an ADM counterweight bar on the end. The screw on type weights from ADM allows the weights to lock on the end.. The weights also serve as a stopper!!
All I needed was an extra 5lbs. This worked out great and with the different sizes of ADM bars, I can customize the length.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5417085 - 09/12/12 11:24 AM
The CGE mounts were all SAE. The CGE Pro mounts are metric. The toe saver on the CGE Pro (and CGEM DX) are M12-1.75 threads. The threads into the mount are also different (SAE vs. metric).
wolfman_4_ever
Reged: 07/15/11
Re: CGE PRO extension for CW shaft new [Re: EFT]
      #5417409 - 09/12/12 02:21 PM
Thanks Ed.. Should of figured that since it was made in china..
No wonder it was such a dog to tap..
wolfman_4_ever
Reged: 07/15/11
Re: CGE PRO extension for CW shaft [Re: wolfman_4_ever]
      #5423157 - 09/16/12 12:33 AM
17 registered and 26 anonymous users are browsing this forum.
